M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Dyno Results 2019 BMW M2 Competition 6MT
      03-02-2019, 08:16 PM   #67
brad65ford
Drives: 2022 M3
following along, was hopefully to see higher numbers with just a tune but I know im greedy. Also we all know dyno numbers can be a place where people like to fight back and forth but I rather talk about 1/4 mph numbers and see what going on. Especially if you have a dragy or other device just run it before and after and see what type of times your running period.
      03-03-2019, 04:49 AM   #68
Kelvin1000
Drives: 2019 BMW M2 Competition MT Hoc
I think the CS and Stage 1 Dyno numbers at the wheels are pretty good when you consider it was almost 90 degrees with high humidity during testing:
      03-03-2019, 11:26 AM   #69
jdub486
Drives: 19' M2C dct/ e90 335d dd
OP if head back to the dyno I’d love to see results with around 2 gallons of e85 mixed in with rest 93 pump. I bet you pick up 10-15 whp and the car will run better in the high heat. Thanks for being the first to post these results!
      09-29-2019, 05:56 AM   #70
Kelvin1000
I have been testing out the CS+ Map lately on my otherwise stock M2 Competition.
I love the benefits of the Stage 1 top end but I also like the linear naturally aspirated power delivery of the CS+ since a lot of the low end excess torque is somewhat unusable for me.
Am I better off doing boots reductions to Stage 1 or going with the CS+ which I assume accomplishes the same task but is tuned professionally by PTF?
Does the CS+ have the same top end as the Stage 1 or is the Stage 1 still stronger towards redline? This can help me make my choice.
My only concern is that the CS+ Map seems to still be in (BETA) several months after the last revision. Not sure why it’s still labeled that way...?
Overall, the BM3 is working perfectly and is one of the best mods you can do to this car.
Thanks to all in advance!
      10-03-2019, 05:46 PM   #71
Kelvin1000
Update:
I asked the following question to the PTF folks:
Am I better off doing BBG reductions to Stage 1 or going with the CS+ which I assume accomplishes the same task but is tuned professionally by PTF?
This was their reply:
Stage 1 is way stronger. You can do it on the Stage 1 as the CS+ is already limited from 'factory'
      10-17-2019, 11:03 AM   #72
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
Are the CS, CS+ and Stage 1 pre-built maps that all come with a BM3 license? Besides having the license what else do you need to flash the car, I assume a Windows laptop and some sort of USB to OBD2 cable?
      10-17-2019, 11:31 AM   #73
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
All the Stage 0 maps (ZCP, CS, CS+ etc.) are free and you get one free OTS map, which can be a Stage 1 or Stage 2 for a specific octane (e.g. Stage 1 91oct, Stage 1 93oct, Stage 2 91oct, Stage 2 93oct, Stage 2 E30, Stage 2 Race gas etc.). So you get to choose one of these with your free map credit. Or you can pay an extra $100 to unlock all OTS maps. All you need is a Windows or Mac laptop and an OBD cable (same cable that is used to code the car). There is also another alternative if you don't want to use a laptop, called OBD agent device. It connects to the car via the OBD ENET cable and has WIFI to connect to the BM3 servers over your phone's internet. In other words, you can change maps via your phone as long as you have this small device in the car with you. Here's more info on that:
https://www.protuningfreaks.com/prod...a-all-f-series
      10-19-2019, 09:28 PM   #74
CosmosMpower
2051
What if you buy someone's license 2nd hand do you just get whatever free OTS map they chose originally plus the Stage 0 maps?
Also it can only be transferred once right? The second owner can't resell.
      10-19-2019, 10:00 PM   #75
M-Pilot
M-Pilot's Avatar
When you buy used, you get to choose your own free OTS map. However, as you said, you cannot sell the license again. Only the original buyer can resell the license. I bought mine used and chose my own free OTS map, which was totally different from what the seller had on his account. I chose stage 1 91oct as my free map but the seller had stage 2 93ct as his free map. Just to clarify, I don't have access to his free map. I only have Stage 0 maps and and my Stage 1 91oct map available on my account. Basically when you buy used, it's no different than buying a brand new license except you just can't sell it again. I paid $350 for my used license btw.
Kankles1484.50
      10-20-2019, 11:01 AM   #76
Kelvin1000
I am still trying to find the best way to attain the linear "naturally aspirated" power delivery of the CS+ map but with maximum power at the top end.
Any guidance or opinions on doing boost reductions to Stage 1 versus going with the CS+ map and calling it a day?
      10-22-2019, 01:44 PM   #77
CosmosMpower
2051
Seems like it's about the same value to buy a new one and resell for 350 or so vs. buying a used one for that. A new license is what, 600 on sale?
      10-22-2019, 01:54 PM   #78
M-Pilot
M-Pilot's Avatar
Yes, there isn't that much of a difference. You can probably find a new license for around $550 and sell it in the future for $350. It would cost you $200 overall vs buying a used one for $300-$350. I just didn't want to deal with selling it in the future and just pulled the trigger on a used license.
      01-21-2020, 05:00 PM   #79
Trakrzy
Waiting for the Point By
Trakrzy's Avatar
4
Drives: a few cars
Are there any documented dyno sheets on stage 2 bootmod M2C's?
      01-28-2020, 08:13 PM   #80
DaFish
DaFish's Avatar
158
Drives: 2014 435iX, FBO
Originally Posted by Kelvin1000 View Post
02-16-2019: Baseline Dyno Results
100% stock with no mods
Stock Map
93 Octane
Single large fan
Closed and open hood
85 degrees with Florida humidity
Did you have to get your DME unlocked first, or just buy the BM3, flash and go?
2020 M2 Competition HS, DCT, 763s, Carbon: splitter, side skirt, grill, diffuser, wing
Previous: 2014 BMW F32 435iX - JB4, MHD Flash, BMS Meth Kit, ER Intercooler, intake, catless DPs, KW Streets, 437M Reps with 245/35 and 275/30 Michelin PSS 4S
      01-28-2020, 10:02 PM   #81
Kelvin1000
Just flash and go.
I have already been to the dealer twice for service and I can still flash the car without any issues.
I just set up the appointments for the weekends when they are less likely to attempt software updates.
Kankles1484.50
      08-08-2020, 01:24 PM   #82
M Fifty
844
Drives: M2 & 330CI
Noting that Torque is what the butt dyno detects, all the plots above show it tailing off from 4,500rpm. Whether that's a limitation of the turbo or the cooling system is unclear.
      10-20-2021, 07:27 AM   #83
GmizM2c
Drives: Bmw m2c
Hey guys I have a 2019 m2c that came off the assembly line in late 18.
Anyone have issues running the cs or cs+ map? Any codes thrown? Any mechanical hiccups? I still have a year left on warranty and I'm contemplating. I also heard that there is a way to wipe the DME in the event something does happen drive it and bring it back to the dealer for warranty work. Anyone have experience with this? I'm on the fence and I really don't want to exceed either of these maps, not looking to spend tires or lose the overall dynamic of the car just add a little more thrust
      10-20-2021, 07:48 AM   #84
Enabled
Drives: 328xd Wagon, M2 Competition
Firstly, there is no way to "wipe" that the car has been tuned over OBD. The dealer will be able to tell, even if you revert back to stock. It would take very in depth data editing on bench to hide that the car had been flashed/tuned before.
Secondly, the S55 can take 440 to 500+ hp just fine mechanically, it's very common in so many users.
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp
-2016 Mini Cooper S, MT. Many plans.
Others:
-E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe.
      10-20-2021, 09:01 AM   #85
GmizM2c
Drives: Bmw m2c
So the only way to avoid flagging is to avoid computer diags?
Which is not practical
      10-20-2021, 12:23 PM   #86
Enabled
It all depends on the pickiness of your dealer, the dealer tech, and how much of a risk you're willing to accept. Most dealer techs will not care and will turn a blind eye.
But if there is engine damage (very unlikely when tuned within reason) from something potentially tune related, then the data collected will be used to attempt backing out of honoring warranty repairs.
Others:
      12-01-2021, 03:22 PM   #87
SOM2C
Drives: F87 M2C, E39 M5
I was considering going with the Carbahn tune from Mr. Dinan, but now I am really considering going this route instead. The flexibility you get with Bootmod is very attractive. I see this post is almost 3 years old now, any update from the OP? How is the car now? Any regrets? Thanks in advance!
      12-01-2021, 03:44 PM   #88
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
I've been running BM3 stage 1 and then stage 2 with DPs since the car was a few months old in 2019.
It's just turned 3 years old, 18,000 miles, not a single problem. It only does enthusiastic fast drives really, no DD duties. Warranty is up now so no concerns about that.
Warm it up, drive with mechanical sympathy and change the oil regular and you'll be just fine, bar some odd random failure.
SOM2C10.50
