M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Dyno Results 2019 BMW M2 Competition 6MT
      02-18-2019, 07:24 PM   #23
2PUTT
Drives: F87
What gear was used during the pulls?
      02-18-2019, 07:39 PM   #24
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
Originally Posted by Kelvin1000 View Post
Actually, I already did the CS flash earlier today.
It was an incredibly simple and intuitive process and only took me about 15 minutes from start to finish to register the license and get the software system up and running on the laptop.
Flashing it for the first time took about 5 minutes because it has to open up the ECU. After that, it flashes the maps in less than 1 minute.
Now the car pulls much harder all the way to redline with the CS map and actually feels a lot like a naturally aspirated high revving engine. It truly transforms the car.
Other benefits are that gear shifts are smoother (particularly first to second gear) and I find that the exhaust is also a bit more aggressive.
Overall, I couldn't be happier so far with the Boostmod3 setup and easy of use. Light years ahead of other bench flashes and piggybacks in my opinion.
I will go back to the dyno in the next couple of days to try out the CS map and probably the Stage 1 map.
Do you have a 6MT or DCT?
      02-18-2019, 07:52 PM   #25
Inuyasha
“One finds limits by pushing them”
Inuyasha's Avatar
123
Drives: M2C
Impressive
MY2019 M2C
Street Bike: Honda Grom. Track Bikes: 02 SV650/09 R6
"It is a shame for a man to grow old without seeing the beauty and strength of which his body is capable"
      02-18-2019, 08:03 PM   #26
Kelvin1000
Drives: 2019 BMW M2 Competition MT Hoc
4th gear pulls for all
      02-18-2019, 08:04 PM   #27
Kelvin1000
6MT with 1,500 miles.
      02-18-2019, 08:08 PM   #28
Kelvin1000
Originally Posted by jdub486 View Post
Excellent results on the cs map! I bet the car feels much faster. Although interesting that the stock m2c map peaks higher. Does the CS map feels as linear as the m2c map?
I'd love to see results with 1.5-2 gallons of e85 in the tank to make sure full timing is being hit and to offset the Florida heat.
02-23-2019: Stage 0+ CS and Stage 1 Dyno Results:
100% stock hardware with no physical mods
93 Octane
Three medium fans with one directly in front of the intercooler
Closed hood
I tested the car in a different shop that has a better Dyno facility. Still suboptimal testing conditions of 88+ degrees and high humidity but better cooling fans this time.
CS Map (full adaptation):
428.54 WHP
436.05 WTQ
Stage 1 Map (only two pulls of adaptation):
464.63 WHP
498.59 WTQ
Hope this helps some of you!
Appreciate 4
BlkSVT388.50
Madmat50.00
CSBM52715.00
GassBoy33.00
      02-18-2019, 08:13 PM   #29
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
I need that CS map period! Thanks for sharing these dyno run comparisons. Very helpful
BAN_M2C4171.00
      02-18-2019, 08:15 PM   #30
chmura
chmura's Avatar
1558
So do you need a laptop to install the bootmod3 CS map? Problem is I don’t have a laptop. When my laptop broke I decided to get a desktop instead.
Any alternatives?
      02-18-2019, 08:18 PM   #31
Kelvin1000
Just trying to do my part to give back to this awesome community that has taught me so much during these last few weeks!
      02-18-2019, 08:19 PM   #32
Kelvin1000
Any alternatives?
There sure is:
https://www.protuningfreaks.com/prod...a-all-f-series
      02-18-2019, 08:26 PM   #33
Kelvin1000
Maybe the next trip to the Dyno will involve a comparison of the CS vs CS+ vs GTS tunes and hopefully I can perform these test when it's not 95 degrees...
akkando5861.50
CSBM52715.00
      02-18-2019, 11:09 PM   #34
chmura
chmura's Avatar
1558
Thank you. I didn’t know that was available.
What’s the most popular method to use OBD agent or laptop?
Can the bootmod3 OBD agent be use on multiple cars? Say me and a buddy buy 2 bootmod3 tune licenses but only want to buy 1 OBD agent. Can we use it on both cars?
      02-19-2019, 01:57 AM   #35
Commanderwiggin
Commanderwiggin's Avatar
2048
Drives: M2C - X3M - Turbo E46 M3 - 45E
I think you need to hitup a different dyno...there's something screwy going on. Looks like they didn't hook up the spark pickup and they synced rpm at the wrong point. If that's not the case then there's something up with your car.
575RWHP F87 M2C - ECUTEK RACEROM with flex fuel tuning by Bend Calibration
1000+RWHP E46 M3, Lab22 Built Turbo S54, Bend Calibration Tuned - BMW Half Mile Record Holder
      02-19-2019, 04:44 AM   #36
Kelvin1000
Why do you think that's the case?
The Dyno operator did floor it at different RPMs to start the various logs but other than that?
      02-19-2019, 04:59 AM   #37
Commanderwiggin
2048
The crossing of HP and Torque at 5200 isn't smooth with the Stage1 curve. Also all the graphs are seemingly low in my opinion for a dynojet as the M2C's have typically made around 400whp STD on dynojets on 91 in 80+ degree heat. If another place is available to you I'd check it out and also ensure the dyno operator hooks up to rpm and keeps the kickdown - down.
Regardless there's no question the car is making more power.
      02-19-2019, 09:19 AM   #38
twboy1999
Drives: 1994 honda accord
Thanks for doing pulls on different maps
Very useful factual data
      02-19-2019, 03:23 PM   #39
CosmosMpower
CosmosMpower's Avatar
2051
Drives: F87c, GT3, MK7 GTI
How is the CS map only making 425 rwhp when that's what a stock 15 M3/M4 dynos on a dynojet? Was guessing it would be around 450 whp and the stage 1 would be closer to 480 whp.
      02-19-2019, 04:05 PM   #40
doughboy
doughboy's Avatar
1543
Drives: 2018 M2 Comp 6MT
Any alternatives?
Desktop is just fine, you could get a long ethernet extension to reach the car, but really its better to be in the same room as the car while your working on it.
I use a laptop but I have a 15m rugged ethernet extension so I can put the laptop on the work bench and sit properly in the garage when coding / diagnostics etc, much better than trying to balance a laptop on the centre armrest...
Hardware OBD agent is neat, but pricey.
      02-19-2019, 04:10 PM   #41
doughboy
doughboy's Avatar
1543
OP - many thanks for these informative dyno runs
      02-19-2019, 04:27 PM   #42
nomoracin
Drives: Porsche GTS 4.0
I don't know much about dynos...like it's so confusing to me how different dynos give higher/lower values, but I think the thing to take away is how much gains there are.
Like, maybe...
Dyno 1 stock could be 400
Dyno 1 CS could be 440
Dyno 1 Stage 1 could be 480
And
Dyno 2 stock could be 380
Dyno 2 CS could be 420
Dyno 2 Stage 1 could be 460
You know what I mean?
...not sure if this is the right way of thinking about it, but that's how I interpret it.
      02-19-2019, 05:17 PM   #43
nomoracin
Like, maybe...
And
      02-19-2019, 06:39 PM   #44
BlkSVT
Drives: 2019 M2c BSM, 2020 MB GLC63
Thanks for posting this! Really helpful info
Just curious, what is 93 octane in FL? Is it 100% gas, or Ethanol-laced E10 like most of the Midwest?
