02-08-2019, 05:28 PM | #1 |
Rep 54
Fume Smell after acceleration with open window
Hi guys,
following Situation. Most of the times when I do pulls with turbo spool, I get a slightly fume smell in the cabin when getting of the pedal(about 5 to 10 secs later) I don't smell anything with closed windows. Window is about 5 cm open. Car was 2nd time at the dealer and nothing is detectable. Anyone has the same issue? Br Mark Last edited by fordnox; 02-08-2019 at 05:45 PM.. |
02-08-2019, 05:36 PM | #2 |
Rep 845
Only thing I can think of is a leak in the connection between joints in the hot side of your drivetrain. Do you hear any unusual rattles when you accelerate?
Instagram: @Project_F87
02-08-2019, 05:39 PM | #3 |
Rep 54
02-08-2019, 05:44 PM | #5 |
Rep 54
02-08-2019, 06:15 PM | #6 |
Rep 81
Hopefully our low-hanging muffler is not causing a "venturing effect" and throwing exhaust fumes back to front of car 🤧
kpham189.50 allthatisntnow377.00 |
02-08-2019, 09:53 PM | #9 |
Rep 81
Ahaaa! It does have that type of smell. I have 1400 miles, so just started driving it a bit harder😇. Sorta remember that smell when I worked on aircraft back in my USAF days.
02-20-2019, 04:58 PM | #12 |
Rep 18
Just curious if you ever got anywhere with working this out. I saw this thread a few weeks ago before picking mine up and now I have I’m definitely finding the same thing. Smells like grease or fishy glue...
02-21-2019, 11:37 PM | #15 |
Rep 14
BMW has been using some very strong smelling sunroof track lube for the past few years.
I’d almost guarantee that this is what you are smelling while the sunroof is open. |
02-22-2019, 07:03 AM | #16 |
Rep 350
A few of us noticed a "wax like" smell during break in of our LCI's. It pretty much went away over time. Definitely not a gas smell...
03-18-2019, 05:41 AM | #18 |
Rep 54
the smell is getting better.
but i just found this fault Code: 190F03: 0x190F03 Tankentlüftungssytem: gesperrt nach Umprogrammierung in short Words: the fuel tank ventilation is locked due to programming… any idea? |
04-03-2019, 07:40 PM | #19 |
Rep 81
After 3 months and 2,600 miles, smell is still an issue (when sunroof is open or partially open). If it's sunroof lube, I am hoping the warmer weather helps resolve. Can't smell anything when car is not moving, with engine running (under hood and under/behind vehicle.
04-05-2019, 07:26 AM | #20 |
Rep 356
Was going to start a thread on this too.
There is an obvious greasy smell when cruising around with windows down. I noticed the same thing on my previous '17 M2, so it's something unique to the chassis, not just the M2C. It's kind of unpleasant and totally unnoticeable when windows are up. I play with setting A/C to on/off, but there isn't a noticeable difference. Edit: For reference, my '17 and '19 both were slicktops. |
04-05-2019, 11:46 AM | #21 |
Rep 439
I also have this. Seems to come on strong when I "get on it" a bit. Oil temps seem to be normal so I'm guessing its a break-in smell?
