03-01-2019, 09:13 AM | #23 |
Rep 2,956
I imagine most of the leaks are pretty small and the coolant ends up vaporizing in the intake stroke.
03-01-2019, 11:55 AM | #24 |
Rep 5,364
I wonder if these leaks are the reason why the new S58 motor puts the air/liquid cooler vertical and on the side of the motor and not the top like on the S55. By doing that, it greatly reduces the chances straight liquid going into the intake manifold. With the S58, the liquid would be more like a mist.
03-18-2019, 12:56 PM | #26 |
Rep 929
For sure but it's still a rare problem. But my OCD will cost me an upgraded aftermarket charge-cooler and an upgraded front oil cooler guard shortly after taking delivery
///M Houbi1653.00 |
03-18-2019, 01:09 PM | #27 | |
4069
Rep 1,970
Will the aftermarket charge cooler void warranty? |
03-18-2019, 01:14 PM | #28 | |
Rep 1,237
Drives: M2 Competition
Ride her HARD during the warranty period! Regarding your (our) OCD -> don't forget about the spun crank hub! Chances seem to be high that if at all, it (SCH) will happen sooner than later. And as long as all is covered by warranty mucho bueno... If the crank hub does not slip during the warranty period chances are very high it will never happen at all.
KevM2721.50 |
03-18-2019, 01:16 PM | #29 |
Rep 1,237
In Switzerland, of course yes...
Another reason not to modify during warranty period
03-18-2019, 01:26 PM | #30 |
4069
Rep 1,970
03-18-2019, 01:58 PM | #31 | ||
Rep 929
03-18-2019, 02:11 PM | #32 | |
4069
Rep 1,970
03-18-2019, 04:16 PM | #33 | ||
Rep 929
03-18-2019, 04:23 PM | #34 |
4069
Rep 1,970
03-19-2019, 07:39 AM | #35 |
Rep 1,759
I don't understand the rationale in changing the cooler during warranty.
If it leaks BMW will replace it with a new one. If the leak causes engine failure then BMW will either rebuild it or give you a new engine replacement. All the aftermarket cooler will do is to lighten up your wallet (during warranty period) and give BMW a chance to deny your engine warranty if the aftermarket cooler s somehow faulty and caused engine issues. |
prompt292.00 |
03-19-2019, 08:06 AM | #36 | |
4069
Rep 1,970
09-06-2022, 09:33 AM | #37 |
Rep 139
Drives: '20 BMW F87 M2C
Reviving an old thread here. It seems that I'm experiencing the same failure as mentioned in this thread.
Took the car to the track this past weekend and received the drivetrain malfunction error after a few hot laps. Immediately noticed a lost of power (not full limp mode), mainly a lack of boost. Pitted, turned off the car and waited a little, turned the car back on and the error was gone. Went back out on the track and the error came back. I ended up reading the code and it was indeed P10B0. I checked the coolant levels, the main reservoir was fine, the expansion reservoir or whatever it's called (smaller one, top of the charge cooler) was low. I checked for leaks but couldn't find anything. I topped it off with some distilled water, cleared the code and took the car out again on the next session. Error came back and so I called it a day. Guessing that the leak is internal. Code has since been gone and I was able to drive it back home. Talked to an indy near me and he immediately suggested it was an internal leak and suggested an aftermarket upgrade. Car is a 2020 with only ~10k miles. I have an appointment with the dealer this Thursday for them to take a look. Since the car is under warranty, I'd rather have the dealer replace it first, than plan on upgrading it after warranty is out. Will keep ya'll posted after I bring the car in. |
09-06-2022, 02:17 PM | #38 | |
Rep 1,322
It would be nice to know why it happens. |
09-06-2022, 07:07 PM | #39 |
Rep 7,294
09-07-2022, 12:51 PM | #40 | |
Rep 929
I've noticed many get topped off at the dealership to a point much above max… that might be a reason too |
09-08-2022, 02:24 PM | #41 |
Rep 139
Update: dealership confirmed that there is a leak and the TMIC will need to be replaced. Unfortunately, they don't have one in stock and it's going to take several weeks for them to source.
Per the tech, it seems the leak only occurs under heavy load / when hot. They're ordering the part and I'll bring the car back in when they have it. I plan on upgrading to aftermarket but might as well use the warranty while I still have it. They gave me a whole jug of coolant meanwhile. Fingers crossed it comes in time before my track event in a few weeks. |
09-08-2022, 02:30 PM | #42 | |
Rep 754
2006 Z4 M Roadster Black/Imola Red, FBO VF-Engineering, e85 Flex Fuel-Sold
2012 BMW 135i N55 DCT Alpine White/Coral Red, FBO, TBI, Full e85, JB4 BEF-Sold 2006 Z4 M Roadster Black/Black-Sold 2021 M2 Competition DCT Hockenheim Silver |
09-09-2022, 03:09 AM | #43 | |
Rep 929
09-09-2022, 12:48 PM | #44 | |
Rep 139
Not opposed to buying those other things later, just really no need for it now, especially with everything still under warranty. Maybe I could just buy now and install.. Then remove/replace with stock when I bring it in for normal servicing. Just afraid the dealer might say something about the warranty. |
