M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > BimmerCode Problem??
      06-05-2020, 07:38 AM   #1
Rick4345
Rick4345's Avatar
472
Drives: 2022 WRX World Rally Blue
Hi,
I'm using BimmerCode and so far pretty happy with it.
I've used it on my F31 and F87.
I had a problem on my F87. It wouldn't read the HU_NBT_EVO module. I thought this was strange because I had no problems on my F31.
Any ideas??
Thanks in advance!!
Rick
      06-05-2020, 11:44 AM   #2
Abrunho
Drives: M2 Competition
I have the same issue since the dealer updated my Headunit to NBTevo_U. When I reported it (last April) Stephan Gauch (from BimmerCode) replied: “Hi,
will be fixed with the next app update.”
      06-05-2020, 11:46 AM   #3
Rick4345
Rick4345's Avatar
472
Originally Posted by Abrunho View Post
I have the same issue since the dealer updated my Headunit to NBTevo_U. When I reported it (last April) Stephan Gauch (from BimmerCode) replied: "Hi,
will be fixed with the next app update."
Apparently not. I use ESys when I can. I can access it that way.
I thought this would be a good thing for convenience if nothing else. Especially since some of the Windows 10 updates have been flaky to say the least.
Rick
      06-05-2020, 12:41 PM   #4
Abrunho
Same here...
I was trying to code both SPA_KOMBISELECT_DISABLE to nicht active in KOMBI L7_MID (menu 3003 / 3003_0_0_32 in E-Sys) and SPA_CHECKBOX to active in HU_NBT (menu 3001 EXBOX), to enable an option in iDrive settings, underneath Displays and Instrument panel to disable the gear shift indicator (that isn’t active in European M2Cs) and had to use E-Sys, because I couldn’t get BimmerCode to read the HU module...
      06-07-2020, 05:08 PM   #5
Raymondo1234
Raymondo1234's Avatar
Drives: 2016 M235xi
Same here.....updated to nbt evo 6 from 4, coded it to work perfectly. Where BimmerCode previously worked for the 4, it errors out on the 6. All other parts still work.
