01-21-2022, 12:53 AM | #1 |
Rep 184
Drives: 2017 BMW M3 Competition (LCII)
Changing out the spark plugs
Hi all,
Back again with a new video. This time changing out the spark plugs on the M2: Hope this entertains/helps you. Regards, TheHunterHofman |
01-21-2022, 12:03 PM | #2 |
662
Rep 1,276
*** TAX SALE *** Get Cashback When You Order This Month! ** Check Out Our Sale Section!
Phone 725-221-5267 || website www.x-ph.com |
TheHunterHofman237.00 |
01-22-2022, 02:20 AM | #4 | |
Rep 7,431
1) it can leak and get onto the tips of the plugs causing misfires. 2) antiseize is a torque multiplier which can cause stripping of threads in the spark plug wells or even breaking of the spark plug. 3) Bosch plugs and NGK plugs are all plated or coated with a metallic compound resistent to corrosion or siezing so you do not need to add anything to prevent siezure the plugs are already designed with this inmind. a) bosch nickle plates their plugs to eliminate corrosion and siezure and specifically says no anti-sieze is required: https://www.boschautoparts.ca/docume...20Brochure.pdf b) NGK uses a special trivalent zinc chromate shell plating that eliminate corrosion or siezure to the head again eliminating the need for antisieze. https://ngksparkplugs.com/en/resourc...ut-spark-plugs So the conclusion is that antisieze on most modern day plugs (generally the "chrome" plated ones are designed for use without antisieze and that is pretty much all plugs these days) is an obsolete and outdated practice that does more harm than good.
///MPhatic13864.00 |
01-22-2022, 09:28 AM | #5 |
Rep 1,659
Drives: 2022 WRX World Rally Blue
Nice video as always!!
Would it be a problem to remove all the black pieces in the windshield area, including the center one, and then remove the noise insulation foam?
Rick
01-22-2022, 01:25 PM | #6 | ||
Rep 184
01-22-2022, 01:31 PM | #7 | |
Rep 184
