04-01-2021, 05:04 PM | #45 | |
Rep 85
KW clubsports don't have amazing clearance and camber adjustment runs out at -3 |
04-13-2021, 05:40 PM | #46 |
Rep 174
By any chance do you have the bolts torque specs and how long it take it?
MY02 S2000 > MY11 STI > MY01 E46 M3 > MY05 S2000 > MY06 911 C2S > MY88 944 TURBO S > MY17 STI > MY17 SS 1LE > C7 GS w/ ZO7 package > MY18 ZL1 >MY20 F87> MY17 F80 ZCP> MY18 Subaru STi Type RA > MY13 E92 "Stripper"
12-30-2021, 11:49 PM | #47 |
Rep 8
Weird camber issue
So I just installed these new hubs to get more camber on my 21 m2c. Had my local Bmw indie shop do the work. In front, the base alignment camber was -1.0 on the left and -1.5 on the right. They played with it on the alignment rack for 2 hours after the install and could only get -1.3 on the left now and -1.8 on the right. So both sides improved -.3 but we thought we would get -.5. We can’t figure out why the left won’t adjust as much as the right. Toe on both sides is .01 in so basically 0. Thoughts? Car is completely stock with stock wheels other than the new hubs. Tires are 255/35/19 on front and 275/35/19 on back. AO52s. Thanks in advance.
12-31-2021, 03:33 AM | #48 |
844
Rep 1,962
.5 degrees difference between the two sides sounds like a lot - how did you have the car ballasted?
Update: Also, what were the rear settings measured at? Have you got a before and after print out you could take a picture of and post? |
12-31-2021, 03:42 AM | #49 | |
Rep 303
I am super pleased with my hubs and hated the NVH with Milway 'street' camber plates |
Bee Pee1779.00 |
12-31-2021, 12:23 PM | #51 |
Rep 8
https://f87.bimmerpost.com/forums/al...ictureid=83301
https://f87.bimmerpost.com/forums/al...ictureid=83302 Here are the alignment before and after specs. I also have the old knuckles/hubs for sale here if anyone is interested: https://www.m3post.com/forums/showth...3#post28415753 Last edited by joejenie; 12-31-2021 at 02:55 PM.. |
01-26-2022, 10:31 AM | #52 |
Rep 8
No one has seen this problem?
So no one has seen this problem where the left side is different than the right? Surprising actuallly. I guess I'll take it to the dealer (tried a BMW inde shop who installed the nuckes but he couldn't figure it out). Any thoughts woudl be appreciated.
01-26-2022, 10:42 AM | #53 |
Rep 3,842
I'm sure you've already thought of it, but do you know the car's full history? Sometimes cars have damage before delivery and are repaired at the receiving port.
01-27-2022, 12:20 AM | #54 |
Rep 8
No clue on this information. I bought the car used with 5k miles on it. So who knows what it could be. All I can do is take it to a dealer at this point I guess.
10-25-2022, 05:56 PM | #55 |
Rep 354
Any news on this? In my case it's either going this route or just doing camber plates and calling it a day.
03-06-2023, 09:21 PM | #56 | |
Rep 24
I read this posts last year and went ahead with the mod on an M2C (CS knuckles, hubs, M performance HAS) and somehow missed this question. I am experiencing rubbing of the front tire on the spring, using 19” Apex Wheels with 255/35/19 Tires. I put a 5 mm spacer which is the most that the replaced wheel stud kit will take. Visually there is (minimal) clearance but still there’s ocassional rubbing. Any idea what else to do? Wider spacer with longer studs? I love the wheels, I love the suspension. I dont have camber plates the camber was achieved with lowering and the CS knuckles and I am pleased except of course for this issue. Thank in advance! Last edited by azacad; 03-06-2023 at 10:12 PM.. Reason: Clarification |
03-07-2023, 01:41 AM | #57 |
Rep 303
Assume you are ET 28 ? I run 9.5 ET 22 with -ve camber hubs, you might be better off with say 7.5mm Turner motorsport spacer, they are hub centric
If you can see where the tyre is rubbing a little file or Dremel just to take 1-2mm off that section might be a consideration (Not tube obviously but height plate) |
azacad6.00 |
03-07-2023, 09:11 PM | #58 | |
Rep 24
The thing is even with the 5mm I get rubbing. And dont worry about taking the Dremel to the height adjuster… the tire has been wearing it down on its own. 😆 Probably the reason it is now only “ocassional”. It has not affected its function (yet). The spring also has its paint worn at the contact point. It still is a safety concern for me. I wrote to Bimmerworld and the very knowledgeable Randolph King wrote back a very detailed description on spacers, stud length and safety. What I will do is determine if 7.5 is still good for the studs I have and go from there. Don’t want to push it outwards too much either. Thanks! |
03-08-2023, 12:36 PM | #59 | |
Rep 8,165
03-08-2023, 05:59 PM | #60 |
Rep 24
Ohh boy… glad you asked I was under the impression it was more negative but this is what I found after the CS knuckles and the lowered suspension and alignement.
Surprisingly I have not destroyed the front tires (at the track) so I am likely driving around the problem... they do of course wear the outer shoulders more. Last edited by azacad; 03-08-2023 at 06:01 PM.. Reason: Correction |
03-10-2023, 03:52 PM | #61 | |
Rep 8,165
03-12-2023, 12:56 PM | #62 |
Rep 24
To be clear I dont have measurements BEFORE the CS knuckles and HAS. From what I read baseline stock is between 1.2 to max 1.5? So probably I did gain front camber. My “baseline” with knuckles installed and HAS lowered is below. Further alignment yields no front neg camber gain which makes sense if there is no real further adjustability. Not so for the rear I did gain there. I was hoping for closer to -2.5 front without camber plates but this is in line with what others with similar parts have.
07-09-2023, 11:01 PM | #63 |
Rep 1,389
This mod sounds cool and won't drastically affect tyre wear for the commuting?
With regard to recommendations to cut threads for new or old bearings being used what does this mean? Tapping the holes.? I know expensive but don't need -3 camber and it's OE. Would work with my B16s? (lowered but still -1.26 and -1.3 L/R camber) Cheers |
07-10-2023, 03:24 AM | #64 | |
Rep 4,517
Yes - can confirm even tyre wear for DD. When swapping over wheel bearing housing these are held in with single use bolts so just need fresh bolts to fit existing front hub bearings into camber correction hub carriers. Should be ok with B16 - I’ve had these installed for a long time with MP c/overs and zero issues.
Current '22 X3M LCI.. |
07-10-2023, 03:19 PM | #65 | |
Rep 1,389
Hear you re new bolts being needed, sounds good. Did you go 255/275 in the end as that is what I am running, no rubbing up front? Presumably I would still otherwise align the car to Litchfield spec albeit with the half degree additional camber? |
07-19-2023, 10:22 AM | #66 | |
Rep 4,517
Litchfield alignment with extra front camber will no doubt work well
