BMW M2 Forum > BMW M2 Discussions > Great steering for all OG/LCI M2!!! :-)
      05-16-2019, 09:12 PM   #45
ONDEMAND
oooooo
ONDEMAND's Avatar
53
Drives: with 3 pedals
Originally Posted by atlas View Post
Has anyone with the new ISTEP software reflashed BM3?
Curious about this. Car is currently at the dealer and at least some updates are being done along with a replacement telecom module. SA says they are updating “the whole car” but Half the SA’s don’t know their ass from a whole in the ground and I assume it’s just flapping gums for the average concerned bmw driver.
I’ll check BM3 as soon as I get the car back next week
Ikester192124.00
      05-22-2019, 04:58 PM   #46
Franzino
Franzino's Avatar
Belgium
860
Drives: M2 MY17 / Alpine A110 MY19
Originally Posted by outerbelt View Post
I had my ISTEP upgraded to the latest version (NBT_EVO Q) a couple weeks ago at the dealer and wanted to chime in on the differences I felt. Thanks to widetyres for the info and background going back to the mid-2018 updates.
All differences are vs. my previous ISTEP version (NBT_EVO M) which was programmed in late 2017.
- Steering feel in comfort, sport, and sport+ is definitely lighter. The car darts faster now. In the previous NBT_EVO M version, comfort was light, but there was a noticeable heaviness to Sport/Sport +.
- Might be my imagination or placebo, but road feel has improved.
- Car will pull harder in Comfort - again, might be a placebo or due to the throttle adoption reset values.
Separate topic but by updating the ISTEP to Q, I was able to enable full-screen CarPlay which is a bonus. I believe versions N,O,P are also eligible for the hack - you need to use a USB or ESYS cable (depending on ISTEP version) and have someone code it for you. A fellow out of the UK helped do it and it was done and over with in about 5 minutes.
So my OG (pre LCI) M2 went in for warranty work (new clutch + DAB/FM problem) and I asked all the latest software updates on every area...which they did (they said). Honestly; steering feel in comfort vs sport feels the same in heaviness at first sight (side note; it was two week ago I drove my M2 and I got it back today). So this is a picture from my software version...does this mean I have the same ISTEP update as talked in this topic...and also how could I get the full Apple car play screen? Or are those both updates (better steering + full screen Carplay) maybe only for USA updates and not EU?
Thanks
      05-22-2019, 05:54 PM   #47
skillz1318
6MT User
62
Drives: 17 M2 6MT
Yes I think Q is latest and should have improved steering and ability to “hack” full screen CarPlay. I just had my 2017 updated last week and definitely notice an improvement in steering and throttle unless just placebo effect.
      05-22-2019, 05:59 PM   #48
Franzino
Franzino's Avatar
Belgium
860
Ok...the full screen is a hack, I get it.
      05-23-2019, 09:06 AM   #49
skillz1318
6MT User
62
Drives: 17 M2 6MT
Yeah; I was considering it, but I am worried I will miss the split-screen view. I wish you could enable/disable full screen carplay within idrive settings.
AndrewC198910931.00
      05-23-2019, 12:28 PM   #50
pit1
Drives: F87 M2
I just requested mine to be updated yesterday. My SA is awesome. He and the tech scoured the update list and found nothing about steering. He agreed to push it anyway under my other iPhone reliability complaint. They agreed sometimes other updates are hidden.
No noticeable change, albeit a tad lighter and more direct, but also had alignment performed so my results are confounded.
      05-23-2019, 01:34 PM   #51
Franzino
Franzino's Avatar
Belgium
860
Same story here...nothing about steering they said 🤷🏻*♂️
      05-28-2019, 04:21 PM   #52
Io
Belgium
338
Drives: BMW M2 LCI DCT LBB
Upgrade from NBT_EVO M to NBT_EVO Q done today on my late-2017 LCI. I confirm that the steering is strongly improved: it is lighter and more precise in Sport and Sport+, and less floating in Comfort. And the ASD seems to be turned off totally. Thank you, BMW! ��
      05-28-2019, 07:51 PM   #53
Franzino
Franzino's Avatar
Belgium
860
Maybe it's an LCI thing or that I did not drive my M2 for two weeks when it was at my dealer for some work and software update. Like I said; I did not notice any big changes in steering feel....but maybe I did not notice it because two weeks passed by and talking about ASD...this is always full off on my car (with a ASD off cable).
So does your sofware version looks the same a mine?
      05-29-2019, 12:13 AM   #54
widetyres
279
Drives: M3 E92 DCT, 2012
Great that you have found the benefits.
The asd on mine came back over a few days. I have now coded it to the "UL" volume setting (power class) and it's absolutely fine at that low setting.
      05-29-2019, 04:03 AM   #55
Rondavouz
Drives: Bmw M2
Will the update to the latest Q lock the possibility to use BM3 and similar?
      05-29-2019, 05:45 AM   #56
Io
Belgium
338
Indeed! But apparently, they did not upgrade my GPS Europe map
      05-29-2019, 05:58 AM   #57
Franzino
Franzino's Avatar
Belgium
860
That is easy to do yourself I you have payed for the option. They updated everything on my car because I have realy bad FM/DAB reception and the dealer said the only thing they can do is update everything. They can not change the headunit under warranty because the headunit does not give any fault codes. On the M2 there is no seperate FM/DAB antenna they say at the dealer? Result is still bad FM and DAB reception....
      05-30-2019, 12:16 AM   #58
champignon
Disrupter
champignon's Avatar
Drives: 1M;Z3M Cp;135is Vert, 996TT
Originally Posted by akkando View Post
My dealer wants 250 for an oil change because it's an M (n55).
I told them that ridiculous. Won't budge though.
My 2003 Porsche Turbo gets its oil changed at the dealer in Idaho for about $280. It's a hugely bigger job with the Turbo because the oil needs to be drained from multiple ports (4, I think).
At full bore, my BMW dealer charges, I think, $130, however there is always a coupon for under $100.
Find another dealer or move!
Disappointing People for Two Centuries; 3 Pedal Fanatic
      06-05-2019, 12:37 PM   #59
Franzino
Franzino's Avatar
Belgium
860
UPDATE!
So…the first time I drove my pre LCI MY 17 M2 with sofware NBTevo_Q18491I was after I did not drive ithe car for two weeks. At the first sight I could not feel that much difference then 2 weeks before. Probably because there was a two weeks time frame between dropping the car and getting it back (in the meantime a drove a horrible X1).
So now I drove a (not updated) M2 LCI MY18 (20.000km) vs my (updated )pre LCI MY17 (60.000km) on the same day…back to back (both manual).
When driving with my own M2 straight after the M2 LCI I could notice the following things:
Gearbox: My gearbox is more notchy then the one of the LCI I drove. Has nothing to do with the update I know, maybe it's because of the lower mileage or the easier life that the LCI car had? I drive mine hard and also occasionally on track.
PDC: Reverse keeps beeping fixed and works like in every other car.
MDM: A little more slip.
Engine: A little less turbolag (feels like a little less aggressive power delivery).
Steering: I don’t think the steering is now absolute great, but it’s certaintly better. There’s is also more vibration felt from changes in road surfaces, but it still feels a little dead in the middle. I did not notice big differences in steering weight like before update.
      06-06-2019, 01:34 PM   #60
Franzino
Franzino's Avatar
Belgium
860
After updating to NBTevo_Q18491I do other people feel the M2 power delivery is less aggressive? Or is it just in my head
      06-06-2019, 02:07 PM   #61
skillz1318
6MT User
62
Drives: 17 M2 6MT
Power delivery doesn't feel less aggressive to me...
Throttle response in comfort does seem more aggressive.
      06-17-2019, 06:32 AM   #62
squixs
Germany
109
Drives: BMW M2 Competition
I've Pxxxx software on my 18 OG M2, can someone confirm that the steering is improved in the Q software in respect to the P software?
      06-17-2019, 04:43 PM   #63
Neutrino
Belgium
13
Drives: 2018 LCI M2
Hey guys.... in a few days I should be getting my 2018 LCI M2 and based on this thread I am trying to convince the dealer to install the latest sw update before I pick up the car
The sales rep seemed a bit confused about my request, thought i was talking about the GPS software
Hopefully I've clarified what I want in the last email, we'll see what happens
PS. glad to see a bunch of fellow Belgians here
      07-14-2019, 09:08 AM   #64
maliderosF87
Drives: F87
Hello, Mainly referring to OG/LCI owners here:
I have seen this thread about the potentially better steering feel you get from the newest ISTEP (F-020-????) but what else is included for the og/lci m2?
If is also includes the improved differential and mdm mode that comes in the M2 competition, allowing more slippage and improved traction,then its a no brainer
Can anyone confirm ?
If one is to flash it through an AD, can I still Apply Bootmod3 parameters on top?
Cause I heard that some of the newer
ISTEP versions are restricting new third party parameters from being implemented.
Thanks mates
      07-14-2019, 10:18 AM   #65
Franzino
Franzino's Avatar
Belgium
860
Correct! See a couple of posts above....
      08-15-2019, 03:18 PM   #66
widetyres
279
Originally Posted by matty_f View Post
I don’t think I’d call the steering great, but it’s certaintly better.
Your right, it wasn't great, just a little bit better. However, if you want a significant bump in steering feel, check out this thread re GTS coding:
https://f87.bimmerpost.com/forums/sh....php?t=1643977
