04-23-2019, 02:47 PM | #23 | ||
Rep 488
It is absolutely amazing what the updates bring to the car - honestly, you'll be blown away. I have now gone one stage further and coded the car to m4 gts steering and traction control - wow! truly amazing what 20 mins with a laptop can do! |
04-25-2019, 09:07 AM | #24 |
on restriction from buying more cars
239
Rep 186
I got the update. First thing I noticed was the ASD. Previously I couldn’t tell what sounds were coming from the car and what what coming from the speakers. Car is definitely quieter inside as there’s less fake sound being pumped in. I guess I never realized how fake the sound was. I kind of miss it, but I think I like a more honest sound. Maybe it just means it’s downpipe time.
I don’t think I’d call the steering great, but it’s certaintly better. There’s more vibration felt from changes in road surfaces but it still feels a little dead inside. I was probably setting my expectations too high and wishing for something closer to the nervous darting feeling of a hydraulic Porsche 997, where the road pulls wheel around slightly as it undulates beneath the car. The weight seems a little different too, but that could be placebo and I’m neither here nor there about it. But the best part of the update are the nannies. They wait a little longer before kicking in and the car is much more playful in sport+. To me that makes the whole update worth it. Last edited by matty_f; 04-27-2019 at 01:13 AM.. |
04-25-2019, 09:57 AM | #25 | |
Rep 4,551
Drives: 2015 328d xDrive
https://f87.bimmerpost.com/forums/sh...43&postcount=8 |
NYC Bimmer259.50 bsaez40.00 |
04-25-2019, 05:00 PM | #26 |
Rep 1,389
So with my manual I can't lose really, more playful traction (I have been surprised how controlled this car is in general even in sport +), better steering.
ASD quieter, sometimes it seems obviously fake to me sometimes I like it, either way got a 300cell milltek downpipe coming How to outside BMW to do it though. Am I entitled to just ask for it as I have warranty? |
04-26-2019, 05:05 AM | #27 | ||
Rep 488
I'd expect 1hr labour charge, but its money well spent. |
04-30-2019, 11:15 AM | #28 | |||
Rep 488
I am going to investigate coding it off/down. Quote:
For some, the level of feel will be too much and they may prefer hiding some of the NVH, but if you are a Porsche fan (I have had one, plus 2 x Lotus Elises, so do appreciate good steering), then this mod is definitely for you! :-) You can also very easily check if this steering is for you - with the F020-19-03-530 update (or later) applied, simply drive for a bit with DSC disabled (long press) - the M2 will switch into quite a raw mode for the steering - the M4 GTS coding in Sport+ is very close to this (not quite a raw, but very close). Note for others: Having the F020-19-03-530 update (or later) is important - BMW seem to have finally managed to provide steering feel at the same time as weight, which was something unsuccessful on previous versions - previously as the modes added weight (e.g. as moving to more sporty driving modes), then the feel was sacrificed - not any more. :-) Last edited by widetyres; 04-30-2019 at 11:21 AM.. |
05-05-2019, 07:18 PM | #32 |
Rep 521
trying to see what steps i need to take to get this done. does ISTEP update with the software updates you find from bmw.com when you enter your VIN? my SA couldn't answer that question, but told me to try updating the software via USB first
05-05-2019, 09:00 PM | #33 | |
"It's so choice...I highly rec. picking one up"-FB
48
Rep 133
https://f87.bimmerpost.com/forums/sh...8#post23774038 Last edited by baturbo; 05-09-2019 at 11:37 PM.. |
05-06-2019, 01:43 AM | #34 |
Rep 488
Do you mean with the updated ISTEP, or with the gts?
The gts coding adds quite a bit of weight compared to the others coding options. Feels excellent! For f087cs coding there was no change with this ISTEP (as compared to f020-18-07-xxx). Difficult to gauge for the default F087 coding as I hadn't run it for so long (as used to prefer f087cs option). It is a bit lighter than f087cs. |
05-06-2019, 01:55 AM | #35 | |
Rep 2,577
Let's not confuse heavy steering with good steering, especially at the electrically assisted steering age. In fact, a lot better handling cars (All 991 variants, Alfa Romeo QV & etc) have noticeably lighter steering and they feel great. I actually wish for a lighter steering with our Ms, so with the street driving, low speed turn would be a lot easier. And believe it or not, the car would feel nimbler.
Lemania 2320
05-06-2019, 09:37 AM | #36 |
Rep 29
I had my ISTEP upgraded to the latest version (NBT_EVO Q) a couple weeks ago at the dealer and wanted to chime in on the differences I felt. Thanks to widetyres for the info and background going back to the mid-2018 updates.
All differences are vs. my previous ISTEP version (NBT_EVO M) which was programmed in late 2017. - Steering feel in comfort, sport, and sport+ is definitely lighter. The car darts faster now. In the previous NBT_EVO M version, comfort was light, but there was a noticeable heaviness to Sport/Sport +. - Might be my imagination or placebo, but road feel has improved. - Car will pull harder in Comfort - again, might be a placebo or due to the throttle adoption reset values. Separate topic but by updating the ISTEP to Q, I was able to enable full-screen CarPlay which is a bonus. I believe versions N,O,P are also eligible for the hack - you need to use a USB or ESYS cable (depending on ISTEP version) and have someone code it for you. A fellow out of the UK helped do it and it was done and over with in about 5 minutes. |
05-06-2019, 03:19 PM | #38 | |||
Rep 488
I'm glad to report that my Ms is happy with the new GTS coding though - it's no heavier than her 2011 Merc C Class (whereas before the M2C steering was considerably lighter - can't have that!). |
05-06-2019, 05:17 PM | #39 | |
Rep 1,608
Boostm3
05-06-2019, 08:11 PM | #40 |
16568
Rep 8,425
That's almost always the case.
Nothing really surprising about hearing that.
05-09-2019, 08:53 AM | #41 |
Rep 53
Drives: 2017 M2 LBB DCT
I just checked with my dealer about this, and they said unless there was a fault code that justified the software upgrade under warranty, it would be 2 hours at $155/hr. Not sure it's worth $310.
2017 LBB ///M2 | DCT, Exec, CarPlay | MP Black Kidneys, Carbon Spoiler, Side Skirts, Mirror Caps, Side Markers, Stainless Pedals
JB+ | IND M2 Badge | Acexxon Rear Slats | Pinnacle Stratos 35% Tint |
05-09-2019, 11:15 AM | #42 | |
Rep 488
I'd you have an lci, then main changes are to steering. You may be able to get 90% of the benefit though by coding your car to the m2c option. |
05-09-2019, 10:41 PM | #43 | ||
Rep 521
05-09-2019, 11:37 PM | #44 |
48
Rep 133
wanofakind01282.00 |
