06-25-2020, 04:05 PM | #199 | |
Rep 55
I'm pretty sure the E92 and M2 weigh the same (actually just looked, they both weigh ~3400 when weighed by actual owners with 1/4 tank of gas) and similar size....the M2 definitely has more torque down low, but I dont know if its actually useable. It might turn out that the M2 can only put down the same amount of torque as the M3 without blowing the tires off... I'd love to compare data on an STU E92 vs an STU M2 on the same course and see...hopefully we'll have a chance to!
2017 M2| I make poor decisions| Devin@tirerack.com ext 4197
06-25-2020, 05:00 PM | #200 | |
Rep 1,366
And I hope so! Data would definitely be interesting. My car has had St* weight reduction and is finally down to 3450 after weighing last week, but it's not a lightweight spec, so maybe a stripper e9x would be closer to the M2.
#ladydriven Heavy-spec M3 // KW Clubsports // AA x-pipe // Gintani muffler // Macht-Schnell intake // Gintani tune // OMP Seats // Too Many Apex Wheels // Stoptech ST-60 // Cobalt Friction brake pads |
06-26-2020, 12:53 PM | #201 |
Rep 3,695
SafariEdition already knows all this, but just linking over to TireRack's new Extreme Performance Summer tire review: https://f87.bimmerpost.com/forums/sh...9#post26363369
06-26-2020, 02:50 PM | #202 | |
Rep 55
The goodyears in the size we tested is slower compared to the larger sizes. 265+ get a tread design change that puts them on pace with the other 200tw tires, and is the size that I and my co-driver (FS national champion) are running on my car, and they are really....really good.
06-26-2020, 03:31 PM | #203 | |
Rep 3,695
Hardcore7136.50 |
07-13-2020, 06:58 PM | #204 |
Rep 55
FYI, someone was able to stuff 295/30R18's on the front of their BS set up M2. So for anyone that WANTS to do it... It's possible. With that being said, I wouldn't recommend it. Unless you get camber and wiser wheels, you're just gonna be setting cash on fire.
But in STU however.... I'm coming for you Kelse92 |
Kelse921131.50 |
07-13-2020, 07:36 PM | #205 | |
Rep 1,366
07-14-2020, 06:08 AM | #206 |
Rep 55
Man an e92 with 315's would be a force to be reckoned with... I hope you can make it happen! Maybe with a really big spacer? 🤔
07-14-2020, 09:12 AM | #207 |
Rep 3,695
You all are nuts. I like it tho!
If someone can make the 295/30/18 on a 10.5” wheel work upfront, and 315/30/18 on a 11” wheel in the back, I’m game. Should be easy enough to get the rear to work. The front will be the challenge on a lowered car. |
07-14-2020, 12:57 PM | #208 |
Rep 55
Yeah, lowered I'm not sure about. Tyspeed did it with their M2 race car, so it should be possible. But we know 295's fit at stock height with the stock suspension and wheels, so I would guess with camber and the right spacers t should work with a lowered car....gonna find out next year haha
07-14-2020, 05:06 PM | #209 |
Rep 1,263
The things you do in Solo 2 to go faster :-) Back in the day around 2003-2004 I had my E36M3 modified in BSP to mount 285/30 Hoosiers. Just a couple years later some of the Nat drivers were fitting 315's!
Sure it can be done, and I've not put the time into what might work under the F87 chassis. On my E36 we used E46 fenders, which were cut and grafted on the body. After the wheel wells were all cut up :-) I'm not chasing trophies anymore but I certainly understand the bug
SafariEdition40.50 CrashFL137.50 |
07-29-2020, 12:45 AM | #211 | ||
Rep 163
18 LBB M2
08-04-2020, 06:24 AM | #212 |
Rep 189
08-05-2020, 12:01 PM | #213 | |
Rep 55
Theres a new proposal out that looks like its being accepted to put the M2 (non-comp) into STU next year....so I'll either be doing that, or LPSP ESP
08-05-2020, 12:36 PM | #214 |
Rep 189
That doesn't do me any good. It's kind of a moot point, though; there's not much competition in STU in our region.
08-05-2020, 01:12 PM | #215 | |
Rep 55
Theres some competition in STU semi-locally in Chicago...I'm in a pretty good spot in BS as I have Mike Leeder (previous DS national champ) in my class locally and Tony Chow (FS national champ) co-driving with me....trying to convince Leeder to take his Camaro to STU with me when I go
08-05-2020, 11:53 PM | #216 |
Rep 163
Damn very interesting. Not running a bigger front sway bar right now but I'll have to look at running the 265/285-35s then.
18 LBB M2
08-10-2020, 10:10 PM | #217 | |
Rep 92
In STU trim the car should be able to develop more power and certainly more torque than the M3, so at the same weight with similar tires it should be a better choice?
2011.5 E92 M3 - Gone but not forgotten
2018 F87 M2 - The new hotness |
08-13-2020, 08:09 PM | #218 | |
1448
Rep 1,414
Oh wait - might have misread this. Thought you meant the front |
09-06-2020, 10:39 PM | #219 |
Rep 76
Has anyone ran the 265-35/18 and 295-35/18 setup with the Ohlins R&T?
Any one want to chime in on the offsets they are running? Also surprised to see no one running the Brembo GTS brake setup, most discussions have always been about the Essex/AP brakes. |
09-07-2020, 06:05 AM | #220 | |
Rep 624
265/30-19 and 295/30-19 and 265/35-18 square Always 10" ET40 at the rear and identical rims with 20mm spacer in front. Both 18" and 19". With 20mm spacer it is VERY close to the height adjustable parts on the R&T front strut. Yeah I know, I really need wider rims for 295 rears but it works. |
Rundskop148.00 |
