05-08-2020, 06:12 PM | #1 |
Rep 843
Phone Mount Recommendations?
What's everyone using in their cars for phone mounts?
I've been researching this for a while and found the vent-mounted ones to be a mixed bag, where some can scratch/damage the vents; for the suction-mounted ones, quite a few of them are gigantic and way too big, and often have residue issues. |
05-09-2020, 05:37 PM | #2 |
Lurker
103
Rep 186
From my post in the wireless charger thread...
https://www.ipitaka.com/collections/...irelesscharger I use the CD slot model, but they have suction cup and vent options as well. Works great, fast charges wirelessly. Message me if you want a discount link. |
MMMBRAP975.50 |
05-17-2020, 04:35 AM | #3 |
Rep 62
Drives: 19 M2C HS, 20 X3MC PB
I use one of these on my M2C.
https://www.aliexpress.com/item/3299...27424c4d9i42QS It works alright, the good thing is the it mount tightly behind the panel. Although the screw may dig, you don't noticed it due to how it clamps in behind the vents. I do wish the magnet was a bit stronger. I have had my phone fly off the magnet once on an emergency brake. So your mileage may vary. |
05-17-2020, 07:57 AM | #4 |
Rep 3,006
When needed I use the Airframe. https://www.kenu.com
The people damaging their vents are trying to rotate the mount while in the vent and expecting the vent not to break. But normally I put the phone in the charger and use CarPlay which stops me from unnecessarily playing with the phone while driving. |
ROASTM163.50 |
05-17-2020, 02:41 PM | #5 |
Rep 500
This works well. I placed the magnetic plate on the inside of the phone's case, instead of on the phone itself. No problems.
SCOSCHE MMWSM-XCES0 MagicMount Select Magnetic Suction Cup Mount Holder for Mobile Devices, Black https://www.amazon.com/dp/B07V8LCNNK/ |
05-17-2020, 04:16 PM | #6 | |
6634
Rep 4,145
Drives: '18 M2 6MT
05-17-2020, 06:36 PM | #8 | |
Rep 3,006
05-17-2020, 06:51 PM | #9 | |
Rep 62
The plate to the vent is very secure. No issues there. The plate contains holding the metal ball is very secure. No issues there. There's the adapter piece that goes in between the metal ball and the phone's back plate. I find that the magnetic force is not quite strong enough there and it can sometime cause the phone to pivot about. Lastly is the adapter piece to the phone's back black, I find it a bit too weak. So yeah, I'm going to look for other better quality products and replace the from the metal ball or the adapter piece onwards and try and retrofit something better. |
VisualEcho6633.50 |
05-17-2020, 06:52 PM | #10 |
6634
Rep 4,145
Drives: '18 M2 6MT
If you look close you can see that they screw inwards. I imagine if there was any damage inside the vent it wouldn't be visible. Very elegant solution IMO, just wondering about the magnet strength. Of course, I only have a 6, so it might be fine.
05-31-2020, 02:06 PM | #12 |
Rep 47
Drives: 2017 BMW M2
I use the WeatherTech "cupfone" it's a really good solution if you don't mind using one of your cup holders. it's adjustable to fit any cup holder size or any phone size. I found it really nice because the magnet ones i've used in the past can sometimes block the vent, or the idrive. This has been a great solution for me for the past year!
https://www.weathertech.com/weathert...pfone/cupfone/ |
06-02-2020, 04:14 PM | #13 |
Rep 2,363
Drives: 2018 BMW M2 & 2024 BMW X1 M35i
Found one of these a while ago and am very happy with it. Paid more for it but have since found it on ebay for like 25 bucks.
Follow my builds:
The Racecar (2018 M2 - M0010): Build Thread | @_m0010 The Daily (2024 X1 M35i - X001M35):Build Thread | @_x001m35 |
06-02-2020, 06:42 PM | #14 | |
Remove Before Flight
6822
Rep 1,611
TIA-- R. |
06-02-2020, 06:52 PM | #15 | ||
Rep 47
Drives: 2017 BMW M2
06-02-2020, 07:46 PM | #16 | |
Rep 249
Last edited by ROASTM; 06-02-2020 at 07:46 PM.. Reason: Didn't notice the last person to reply was referencing the WT mount. |
06-03-2020, 08:44 AM | #17 |
Rep 4,551
Drives: 2015 328d xDrive
Currently using this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 I like it a lot, even though it blocks a vent and some buttons. |
NYC Bimmer259.50 |
06-08-2020, 04:05 AM | #18 |
I INDIC8
612
Rep 1,286
Drives: 2018 LBB M2, 6MT
It's been mentioned once already, but Kuda base + Proclip is IMO the best. Click for the fullsized / original source link where you can pick higher resolution to zoom in...
MMMBRAP975.50 |
06-08-2020, 09:34 AM | #19 |
Rep 843
06-09-2020, 04:18 PM | #20 |
I INDIC8
612
Rep 1,286
Here are the Kuda base install instructions. (this is for LCI-style interior, 2018+)
You have to pull off the carbon fiber / vent trim first, pry tool + yank. That then allows you to pull off the shiny black plastic trim (there are two screws on it, I think torx), then you pry / yank. One "leg" of the Kuda base is screwed straight into plastic (hidden behind trim, like supporting framework plastic that nobody will ever see) with a self-tapping screw. I can't remember if the button panel itself had to be unscrewed to do this, I don't think so. If it does, that's just a few more torx screws. The other screw is behind the glove box door. You open the box, line up the other "leg" from the Kuda base piece, and drive the screw into plastic when everything fits how you like. So yeah, there will be one little screw hole visible inside the glove box if I ever take it out... didn't bother me much given how nice it looks when it's installed. You could probably even get away with it on a lease since I doubt anybody would go looking for that hole in the glove box. The Proclip just screws into the Kuda base with its own self tapping screws. The Kuda base is just factory-looking leather wrapped over fiberglass and plastic. I actually have a Proclip "quick release" piece attached to the Kuda base, so when/if I change phones and need a different phone holder, I can simply swap that portion out without needing to unscrew anything (I was worried about longterm longevity of the fiberglass and leather on the Kuda base if I had to add/remove screws a lot). Any of the Proclip phone holders that use a "swivel base" just slide right into that quick release and lock in. My sole complaint is that passengers (my wife) have a bit of a hard time reaching the heated seat button, although some of that is also the charging cable coming out of the bottom of the dock. I have the quick detach portion mounted about as high up on the Kuda base as it could go. I could possibly rig up something to raise the phone higher using other Proclip parts, but it doesn't affect me at all so I just let my wife live with it.
I'm an IT guy by trade and tech nerd by choice. I like HPDEs, parts of US Hwy 129, NC 28, and the Cherohala Skyway. I'm also a fan of aural pleasure. Last edited by ZPrime; 06-09-2020 at 04:31 PM.. |
MMMBRAP975.50 |
06-19-2020, 02:51 PM | #21 |
Rear Admiral
1485
Rep 1,706
Drives: Bavarian Milk Wagon
I used the kuda in my F80 (with added Scosche magnet) and it worked great.
Decided a different route with the M2c, brodit proclip with 3d printed mount attached (thanks Megator) |
06-26-2020, 03:49 PM | #22 |
I INDIC8
612
Rep 1,286
I used that exact proclip base mount in the past, but I don't like how it partially blocks the one vent and I also don't like how it kinda slides around a bit. It's not completely terrible though.
Kankles1484.50 |
