M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Recommendations to Ceramic My 788M Wheels
      03-18-2020, 04:02 PM   #1
msdss
msdss's Avatar
Drives: Alpine White 2020 BMW M2C
I've had enough... 4,000 miles in, and these wheels are just so frustrating to keep clean. It takes me longer to clean my wheels than it does the rest of the exterior and interior combined. And that's just getting the surface dirt off. The barrels are still totally fucked. I would like to ceramic coat these wheels in hopes that it will take most of the frustration out of cleaning them.
Can some folks out there recommend a good DIY kit for ceramic coating these? I've never done it before, but it can't be that hard.
      03-18-2020, 04:23 PM   #2
HazChem
HazChem's Avatar
Drives: 2019 BSM M2C
I’m going to use Gtechniq C5 Wheel Armour for mine when I change over to my summer wheels. I used it for my winter wheels and it worked pretty well. Made it I easier to clean although I still need to spend time with a soapy microfiber mitt to get all the dirt and grime. It won’t completely eliminate the frustration due to all the nooks and crannies but it should make it a bit easier.
msdss497.50
      03-19-2020, 01:23 PM   #3
hlm2c
Drives: M2C
Sounds like a good excuse for new wheels
msdss497.50
Conissah1576.00
      03-19-2020, 04:00 PM   #4
Vulpe
Vulpe's Avatar
280
Drives: F87 M2C
The best thing to do really is to get simpler wheels. I personally don't see how ceramic coating wheels makes it any less work to properly clean. I still coated my new wheels but it's not like just spraying it with water, pressure washer or otherwise, will clean it 100%. You still have to contact wash every part of the wheel whether it's been coated or not.
The only real difference I see on paint or wheels when it's been coated is it looks a bit different and it's more hydrophobic. I guess it makes it easier for when I use a leaf blower to help dry the car.
msdss497.50
Bobh5952.00
      03-20-2020, 02:21 PM   #5
rjd598
Drives: F30 340i
2016 BMW 340i  [0.00]
It sounds like you don't have the proper tools, but I'm just assuming. The stock M2C wheels do look like a pain to clean, but ceramic coating them will definitely help. The recommendations on getting a different set of wheels is honestly the best method unless you're in love with the stock wheels for some reason.
Remember there is no such thing as a spray on and rinse off product for paint or wheels. Agitation will always be needed unless you're washing your car every single day and it sits in some sort of bubble.
msdss497.50
KevinM2935.50
      03-21-2020, 12:41 PM   #6
2PUTT
Drives: F87
Here are the results after I used Nanolex from DetailersDomain.com. Feel free to look at my build thread to see the process on how I cleaned and then applied the ceramic coating.
https://f87.bimmerpost.com/forums/sh...5&postcount=61
msdss497.50
      03-24-2020, 02:19 PM   #7
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Agree. I use this mitt + a medium Wheel Wooly for the barrels. Less than 5 min per wheel.
https://www.amazon.com/Detailers-Pre...077282&sr=8-23
https://www.amazon.com/ABN-Car-Wheel...5077422&sr=8-6
GL!
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
rjd5981769.50
      03-28-2020, 09:51 AM   #8
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I put Gtechniq C5 Wheel Armour on my 788 wheels and now they are much much easier to keep clean. I highly recommend doing this. It's easy to apply, but your really need to do the prep right. (I coated the barrels and face of each wheel)
www.ReTuneTheDeTune.com
msdss497.50
      04-10-2020, 03:09 PM   #9
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
I did the same. It certainly does not make them a rinse and go but definitely easier to clean than without. Did two solid coats.
      05-03-2020, 03:23 AM   #10
sharpmoney
Drives: NA
how do you guys clean the barrels of the 788s? take the wheel off??
      05-03-2020, 08:16 AM   #11
HazChem
HazChem's Avatar
I use an EZ Detail Brush. Works well except in front wheel where it can’t get under the brake caliper.
      05-03-2020, 09:28 AM   #12
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I used Gyeon Rim on my 763M
      05-05-2020, 11:01 PM   #13
msdss
msdss's Avatar
I take the wheels off.
      05-06-2020, 08:12 AM   #14
thoang
Drives: M2 Competition
[IMG][/IMG]
Just had my rims powdercoated and took the opportunity to apply 2 coats of Gyeon Rim.
Took bloody ages but hopefully will save some time keeping them clean
msdss497.50
      05-18-2020, 10:50 PM   #15
tropicatango
tropicatango's Avatar
437
Drives: Bmw f87 M2c hockenheim silver
Originally Posted by thoang View Post
[IMG][/IMG]
What is this color ? Pictures on car ?
      05-18-2020, 10:52 PM   #16
thoang
[IMG][/IMG]
[IMG][/IMG]
Dark bronze
Moflow2484.50
      07-22-2020, 03:17 PM   #17
RocketBoots
RocketBoots's Avatar
Drives: Horse Drawn Carriage
Dark bronze
I think that's the exact color of the brake dust! That plus the Gyeon Rim = NEVER cleaning the wheels! Bloody brilliant!
