M2 Technical Topics > Cosmetic Maintenance (Wash/Wax/Detailing/Exterior Restoration & Repairs) > Ceramic Coating + Wheels + Cleaning Question
      05-05-2019, 05:41 PM   #1
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
I've been watching a few, ok too many, YouTube videos.
In one the fellow was testing different ceramic coatings to see how well they held up. His methodology was to hit the coatings with harsher and harsher chemicals. Well the final chemical he used was IronX which strip almost all of the ceramic coating that was left.
For my wheels, I use Sonax wheel cleaner which I'm assuming has a similar chemical in it b/c it turns pink when applied.
So while waiting for my M2C to arrive, I purchased a set of BMW 763 M and some GYEON Rim.
My question is...If I apply the ceramic coating to the wheels and brake calipers will the Sonax strip it off?
TIA.
      05-05-2019, 05:47 PM   #2
nioh_lbbm2
nioh_lbbm2's Avatar
1717
what ceramic coating products were they testing in the videos you watched? True ceramic coats or "ceramic" coats like a spray on wax?
The true coats shouldn't be stripped but the "ceramic" sprays definitely will. Those aren't durable at all
omasou2088.00
      05-05-2019, 06:35 PM   #3
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
You were right, see told you I watched too many videos. They were Meguiar's Hybrid Ceramic Wax VS P&S Bead Maker VS Adam's Ceramic Spray Coating. So they can't be expected to last.
Though will a product like Sonax wheel cleaner "significantly" diminish the life of a DYI product like GYEON Rim?
      05-05-2019, 07:07 PM   #4
Anthony1s
756
Drives: 2018 Mineral Grey M2
Hmm, interesting theory. I've had my wheels ceramic coated with Carpro Cquartz (4 coats of it) and it's like it's not even there when I wash the wheels. I wonder if it's a chemical from one of the automatic car washes I go to that stripped it. Or the 2-3 times I used Black Magic No Scrub Wheel Cleaner on them.
I've also had my windows treated with Carpro Flyby Forte and that lasted only a few months. I've been theorizing it's the BMW washer fluid that degraded the coating. Because it's only degraded where my wipers hit. And my 2007 Saab was treated with the same coating at the same time and still is going strong, but I use RainX washer fluid in it.
      05-05-2019, 07:49 PM   #5
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Curious.. Why bother using harsh chemicals if you're ceramic coating your wheels. Shouldn't the dust just rinse off?
Motorcity BMWCCA Member
Instagram | YouTube
      05-05-2019, 09:57 PM   #6
nioh_lbbm2
nioh_lbbm2's Avatar
1717
What i've found with my own ceramic coated wheels is that they make cleaning easier but they don't prevent brake dust and grime from sticking to the wheels. You don't need to use a powerful brake cleaner every time you wash your wheels unless you're neglecting them for weeks.
I use regular car wash shampoo weekly and my wheels remain easy to clean and water still beads.
It is possible for the contaminants to embed in the wheels even if you have them coated so perhaps your wheels need some iron remover for a thorough decon wash and you should see the water beading effects of the ceramic coat again.
omasou2088.00
      05-05-2019, 10:37 PM   #7
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I think it will help but doubt it will be 100%
      04-26-2020, 06:44 PM   #8
Detailers Domain
Detailers Domain's Avatar
Drives: 20 M2C / 22 X3MC
over time all cleaners will take down the ceramic coating, best way to deal with it, is to clean as normal but change it up use ceramic friendly products.
plan on coating your rims every year or so. this is what we tell our customers as the wheels will take on a ton of abuse from braking --> heat ---> dirt and dust --> and cleaning.
omasou2088.00
      04-28-2020, 01:08 PM   #9
2PUTT
Drives: F87
sample pic of my ceramic coated wheel (Nanolex) wheel after a few months of use. everything wiped right off (like buttah). my build thread is in my sig. feel free to checkout the products and steps i used.
good luck!
      04-28-2020, 02:44 PM   #10
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
I was very skeptical coating wheels and thought it a complete waste of time b/c in my experience the hot metallic pieces from the pads melt into the clear coat. Even so I decided to try Gyeon Rim as I had nothing to loose. I don't drive the car all year long so my experience may not be typical.
When I wash the car the brake dust washes off with normal car wash. No more Sonex required. This alone makes the effort well worth with. If you do this yourself it's amazing how rough the new wheels are and how smooth they are after the coating is applied. It literally fills tiny pores in the finish.
When it gets a bit warmer I'll take the wheels off and have a closer look but I'm a very happy customer.
At the same time I applied Gyeon Pure (1 step) to the paint and again it makes cleaning the car a breeze. This was a brand new car straight from the dealer. I can't imagine correcting the paint and applying a 2 step. Props to the detailers that do this work, you deserve your fee.
Since the two products worked so well, I decided to try Gyeon View on the windows though my past experience with RainX has not been very positive. I will continue to use this on the side and rear windows but not the front window. The bugs seems to stick a bit better and the wipers and wiper fluid do not remove them. Though when I wash the car they come right off.
So 2 1/2 out of three isn't too bad.
Thanks to everyone for talking about these products and pushing me over the edge to try them.
      04-29-2020, 01:53 PM   #11
tenkies
Drives: 2017 M2 LBB 6MT
I used Gyeon rim on my TE37. I did 2 coats and find that not everything washes off easily with just soap and pressure washing. I have to use a wheel woolie to get some parts clean. Part of this issue is most likely do to the textured paint on the wheel but I was expecting a little better results. I did coat the lug nuts as well and they seem to get clean with the power washer though.
