M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > ☛ MHD Flasher F Series (F87) discussion ☚
      01-07-2019, 09:59 PM   #199
Daleb
Originally Posted by Bee Pee View Post
Hi DB & HNY,
Datalogging will show the output but surely won't show enough to reverse engineer custom tuned input parameters ?
BP
Happy new year to you too👍🏻
Exactly, so I canít see a reason for them not to use bm3 considering they are listed as a custom tuner too.
      01-31-2019, 09:26 AM   #200
MHD Tuning
MHD Tuning's Avatar
Germany
1696
Drives: M3F80#M5F90#340iF31#SupraA90
Originally Posted by Tricki View Post
Tried OTS E20 map. Gotta say I'm pretty impressed.
How high was your ambient temp?
A water methanol injection works very nice on the M2s and will give you a nice bump in power.
Tricki199.00
      02-01-2019, 07:11 AM   #201
Bee Pee
1421
Drives: AW M2 DCT
Taken from Mlite FB group - M135i n55 EWG
https://www.facebook.com/photo.php?f...MlQCJN69pwb6ZA
Slightly different ambient temps/pressure will effect but not a bad result for half a bottle of boostane to a tank of 99RON - 410/605 power/torque jumps to 427/643
Fettled M135i EB AT - gone but not forgotten:
AW M2 DCT
      02-01-2019, 08:10 AM   #202
MHD Tuning
MHD Tuning's Avatar
Germany
1696
Very nice results - thank you for sharing.
      02-01-2019, 09:28 PM   #203
designatedposter
Drives: m235i
Can you share the engine logs? What was different between the runs with and without booster? Timing and/or boost? Was it running the same tune?
M235i rwd 6mt
      02-01-2019, 11:14 PM   #204
SeanWRT
SeanWRT's Avatar
2728
Drives: E90 M3 & F87 M2
Bee Pee, thanks for sharing I mean it.
But I really hate all these random dyno graphs posted by some random ignorant. This 410hp->427hp show what octane can change but all it tells is a 4% hp improvement from the octane. It'd be the same thing to show 310hp->323hp, except that they would have no one come to rave about the numbers.
It's been almost 3 years. Still very few people post before and after result, no mention of it being back to back pulls.
Lemania 2320
FSociety3469.00
      02-02-2019, 09:08 AM   #205
Bee Pee
1421
Drives: AW M2 DCT
Sorry I can't post logs as this is not my car. Perhaps you can ask the owner via FB ?
AW M2 DCT
      02-02-2019, 09:19 AM   #206
Bee Pee
1421
Drives: AW M2 DCT
Sean
Cheers & noted re 4% bump in peak power. My observations between MHD stg2 / 99RON to stg2+/99RON + Boostane on the same car are:-
- a useful bump in torque;
- far more consistent curve shapes for both power and torque;
- good gains throughout are evident by significant increase in areas under both power/torque.
BP
AW M2 DCT
      05-05-2019, 10:30 AM   #207
Yellowflash21
Slovenia
354
Hi folks,
Would someone be willing to honestly share your opinion so far with MHD stage2+ tune, and did you run it on track without any issue?
If there were any issue so far with this tune, how did you sort them?
I'm strongly considering to go with MHD due to flashing practicality compared with bootmod3.
Honestly, I got bit scared how many people had issue with initial car flashing and so many agent/software updates.
As, who wants to be stuck in the garage underground without wifi connection.
Maybe I'm mistaking regard bootmod3 but anyway any experience would be more than welcome.
      05-07-2019, 10:13 AM   #208
MHD Tuning
MHD Tuning's Avatar
Germany
1696
Originally Posted by Yellowflash21 View Post
Hi folks,
Most of our discussion is in the F30 section.
https://f30.bimmerpost.com/forums/sh....php?t=1450585
We have many satisfied M2 customers all around the world.
Feel free to ask us if you have any questions.
      05-12-2019, 03:30 AM   #209
Cristian135
Drives: Bmw m2
I just loaded stage 2+ 98oct fbo, pure entry, miltek dcel 200cel, charge pipe and boost pipe ftp, intercooler do88 and it works very well and smooth power delivery, the only thing weird is that in comfort mode and sport mode, does not mute the exhaust sound like in stock
      05-17-2019, 06:12 PM   #210
MVersi
XSS11V
122
Drives: M2 LCI - Mineral Grey
As most android phones are USB-C, has anyone used a converter from micro-USB?
M2 LCI DCT - Wagner IC and catted DP, Milltek exhaust, BMS intake, JB4 Map2
      05-17-2019, 08:46 PM   #211
switlikbob
Chuggin' Along
switlikbob's Avatar
Drives: 2017 LBB ///M2
All you need is on OTG cable or converter adapter. Search Amazon.
      05-23-2019, 11:59 AM   #212
MHD Tuning
MHD Tuning's Avatar
Germany
1696
You have plenty OTG USBC and OTG MicroUSB adapters on Amazon.
Just donít stack two adapters in row, this does not work.
      05-28-2019, 08:52 PM   #213
F87source
F87source's Avatar
759
Drives: 2017 Bmw M2 6mt
Good to know
Follow me on Instagram @f87source
      06-14-2019, 02:47 PM   #214
MHD Tuning
MHD Tuning's Avatar
Germany
1696
Today's update brings many nice things to the MHD F+G Series users:
- N55 EWG: added full e85 Stager 1 and 2 maps.
- N55 / B58 / N13 : added coolant flash option (Performance and Track).
- N55 / N13 / M2 N55 : added start up roar (noticeable with cold start deactivated).
- B58: allow burble on OPF cars.
- Full M3/M4 CS and M2C support, including OPF delete option
- Added CS / GTS trans flash for M2 N55, M2C, M3, M4
- various fixes for Burble and exhaust flap open on sport.
The Stage 1 and 2 full e85 maps for N55 EWG will produce a relatively flat torque, with max power near redline. With those maps no need to mix every fill up! And they are the most powerful Stage 1 and 2 maps. No 2+ full e85 map is doable due to fueling limitations.
Another nice feature for N55, B58 and N13 cars: We found a way to bring the M switchable coolant feature to non-M cars. With the coolant flash option activated, the coolant target will be 95c in eco / comfort instead of 106c+. If you switch to sport mode (or comfort + transmission in S or M), the coolant target will be 85c with performance or 80c with track option selected. This allows the engine to run cooler and oil temperature will also benefit from that significantly. We also changed many fan settings to further improve how quick the system reacts to the different modes, this also helps to reduce the IAT and under hood temps when staging at a drag strip or slow city driving.
The M3, M4, M2 N55 and M2 Competition owners now have the much anticipated CS & GTS TCU flash available through MHD (M2C only CS) - this is a free update included in the Flasher License.
We also added full support for recent euro spec S55 cars equipped with a OPF / GPF (plus delete option)
      06-17-2019, 07:32 AM   #215
M&M
M&M's Avatar
South Africa
100
Drives: Boosted Beemers!
HI I flashed the GTS TCU flash on an N55 M2. It worked bit doesn't feel good. If I flash to stock will it flash the correct stock flash back?
      06-25-2019, 08:36 AM   #216
MHD Tuning
MHD Tuning's Avatar
Germany
1696
Yes of course, but what does not feel good?
      06-25-2019, 12:48 PM   #217
M&M
M&M's Avatar
South Africa
100
I was weird and slow and showed C1.
      08-05-2019, 03:19 AM   #218
Jungman
Drives: bmw m2 lci
Today I mapped my GTS TCU for my car, N55 M2. Then my instrumental panel which initially showed D1 now changed to C1. Even when I converted to sports plus, my car changes shift during low RPM. Also when I accelerate, my down shift doesn't work. I feel like original comfort mode is way faster and better. So I changed it back to stock map. How should I fix this problem?
      08-05-2019, 05:45 AM   #219
Jungman
Drives: bmw m2 lci
and today I drove my car with TCU stock map but it is significantly differerent from original stock map. My car is extremely weird now. I need to solve this problem as soon as possible.
      08-10-2019, 07:07 AM   #220
MVersi
XSS11V
122
I have a Wagner catted DP and IC and BMS intake on my M2 LCI and just flashed the 98RON Stage 2+ tune on the car today. I've only driven it short distances and not WOT yet due to traffic. I'll get to test it out on a long drive tomorrow.
I also have a JB4 attached but it is on Map 0, which I am only using on my iPhone for the gauges.
Are other Australian cars here ok on the 98RON tune (I always fill BP Ultimate 98) or are you using 95RON tune?
Tags
flash, mhd, tune
Copyright ©2000 - 2020, vBulletin Solutions Inc.
