M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      09-03-2018, 06:57 PM   #1937
mvigod
mvigod's Avatar
Drives: 2021 X5M
Originally Posted by TheAMackAttack View Post
Hey guys maybe a simple answer since this is all new to me but I plugged in the Veepak OBD BlueTooth (BimmerCode now recommends Bluetooth? Unless I'm reading their recommended OBDs thing wrong) and when I plugged it in and turn on Bimmerlink on my iPad (and then later on my iphone--both in airplane mode) it said to connect to the OBD's Wifi network and when I would try to do that I would get error messages on my iPad or phone.
Any idea what I'm doing wrong. I'm sure it's something super simple...
I think you have to go into settings on the bimmercode app and change it from Wi-Fi to Bluetooth
      09-03-2018, 07:11 PM   #1938
TheAMackAttack
Drives: 2016 M2 LBB DCT
Yup... you're right about that. Hoping it works now. Thanks!!
      09-07-2018, 08:16 AM   #1939
NotSooFast
On the Go!
NotSooFast's Avatar
Drives: Just a few!
One of the most interesting threads / forums I have come across. I started reading and jumped over directly from page 30 as I had a question.
- Anyone adjust the vibration intensity of the steering wheel for LDW (Lane Departure Warning)?
      09-08-2018, 05:08 PM   #1940
Bassta
Drives: F34 335 XDrive
Hi, friends!
1. How to make DRLs turn off in position 0 and in AUTO position work on? I have so far only turned them off at all, in 0 or auto (return it back).
2. How do I close all windows when I close the car through comfortable access (single press)?
3. How to make that when I close the auto flashing turn signals under the mirrors?
My car F34
I understand this app is no read and can not delete errors?
Thanks, and sorry for my bad english...
      09-12-2018, 02:15 AM   #1941
rouxeny
Living the aloha
rouxeny's Avatar
Drives: 2017 LBB M2
I brought my 2017 in for its one year service. He dealer identified an error with ASD coding and recoded the control unit. The “latest ISID software” was used for programming.
ASD is now on, and my all my prior Bimmercode coding is gone. Saved seat positions are also gone.
I reloaded Bimmercode today. The ASD module is now grayed out and states “no data” so i’m Not sure I can turn it off anymore. The easy entry seats coding is also no longer available as it was described around page 60.
I would recommend if you bring your car to the dealer, ask them not to recode anything.
I do not believe my istep changed.
      09-12-2018, 06:34 AM   #1942
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
I reloaded Bimmercoade today. The ASD module is now greed out and states “no data” so i’m Not sure I can turn it off anymore. The easy entry seats coding is also no longer available as it was described around page 60.
One of the problems is that if your car is under warranty, and BMW determines you need a software update, you pretty much have to take the update. I mean, you can try and fight it, but in the end, I usually relent under threats of pulling the warranty if the update isnt done. . Which is the main reason I bypassed ASD with the harness rather than facing what you are. A lot of people favor the coding, but to me, bypassing is the path with less potential resistance. When the warranty is up, I'll consider coding, but not until. Kind of depends on how customer friendly your dealer is. Mine isnt that friendly!
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
      09-12-2018, 10:59 AM   #1943
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
Originally Posted by Rupes View Post
Without being too cynical - it appears from the discount code on his site that there may be a referral fee / commission on the Veepak model. Not to say it isn't better, but also worth mentioning.
Does anyone have the link for this?
2018 M2 LLB DCT DP Custom Exhaust
2018 Accord Sport Platinum White Pearl
2013 Mini Cooper S Hardtop Pepper White
2006 M Roadster
      09-12-2018, 11:03 AM   #1944
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
Which adapter can be continously plugged into obd port and does turn on and goes into standby automatically?
      09-12-2018, 11:03 AM   #1945
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
NVM found it
http://www.bimmercodeapp.com/adapter/
2006 M Roadster
      09-12-2018, 05:49 PM   #1946
asta
Drives: 2019 M2C
I was curious about this too. I haven't begun to experiment with this app, which I got to turn off ASD, but I'm curious what standard or "must do" tweaks M2 drivers are doing.
      09-13-2018, 05:40 PM   #1947
cptobvious
cptobvious's Avatar
Drives: M2C HS DCT
Originally Posted by carl44 View Post
Just picked it up tonight .wanted to turn off ASD won't connect ? Does it work on the m2c? Carl
Carl, did you ever get Bimmercode to work on ASD? I just connected using the Veepeak OBDCheck Bluetooth 4.0 adapter and it gives me the ability to change nearly everything in the car.
The ONE thing I can't seem to change is ASD. It simply says, "Code not available" when I choose ASD.
Did you run into the same problem? And, if so, and were able to overcome, how did you overcome?
Thank you!
      09-13-2018, 05:47 PM   #1948
AndrewC1989
AndrewC1989's Avatar
Drives: 2015 328d xDrive
Thank you!
Worst case scenario:
https://technicpnp.com/product/asd-bypass-harness/
cptobvious2531.50
Hankdoll135.50
      09-13-2018, 06:43 PM   #1949
pz619
Drives: F87 M2C 6MT, Tesla 3
I would email them. The developer is quite responsive when I asked a question a few years back.
cptobvious2531.50
      09-13-2018, 07:05 PM   #1950
carl44
Drives: M2C
Bimmerlink worked for me .
Bimmer code wouldn't?? carl
cptobvious2531.50
      09-13-2018, 07:11 PM   #1951
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
@cptobvious it shows a screen like this doesn't it? If so you can just select "off". [IMG][/IMG]
///M2 - 2018 LBB DCT
cptobvious2531.50
      09-13-2018, 07:38 PM   #1952
cptobvious
cptobvious's Avatar
Drives: M2C HS DCT
Bimmerlink worked! Bimmercode doesn't seem to work - under the ASD section it says, "No coding available."
Thank you again so much, Carl! The terrible drone at 2000 RPM is now gone!
Alec0285.00
3tekcorps826.00
      09-13-2018, 07:43 PM   #1953
carl44
Drives: M2C
Glad to help,turning ASD off seems to make a bigger difference than it did in my OG?
carl
      09-13-2018, 09:41 PM   #1954
Protatomonster
Drives: Kia Stinger 2018
Which device did you go with to do it? Considering buying one before I get delivery.
      09-13-2018, 09:43 PM   #1955
nomoracin
Drives: Porsche GTS 4.0
You have to pay for bimmerlink?
      09-13-2018, 09:47 PM   #1956
AndrewC1989
Yes, it's a separate app. Same developer but different uses and features.
Bimmerlink is also iOS only while Bimmercode is available for both apple and android.
http://bimmercodeapp.com/
http://www.bimmerlink.com/
      09-13-2018, 09:49 PM   #1957
cptobvious
cptobvious's Avatar
Drives: M2C HS DCT
I bought the Veepeak OBDCheck Bluetooth 4.0 adapter. If you go to bimmercodeapp.com and click on the link for adapters, there's an Amazon promo code for this one that gets you 20% off. Heck, here's the link:
http://bimmercodeapp.com/adapter/
TProfit81.50
      09-13-2018, 10:02 PM   #1958
cptobvious
cptobvious's Avatar
Drives: M2C HS DCT
I'm super happy that I can turn ASD on and off now. I can understand why purists hate ASD. But, as someone coming to performance cars with zero previous history and zero preconceptions, I do have to say that there are pro's in addition to the con's.
Reasons to turn ASD off:
1. I can now use the car as a daily driver and as an all-around family car. Before, I told my wife that there was no way we could ever use the car to do a long road trip - we'd be deaf by the end of the vacation. With ASD off, the car is as quiet as my 328i.
2. If you want to be able to have conversations with other people in the car, you will want ASD off.
3. There's a horrible drone at around 2000 RPM if you're holding steady on the throttle. So, you know, if you're going 70-80mph on the freeway, you're going to have this migraine inducing drone in your ears the entire time.
Reasons to keep ASD on:
1. ASD will make you feel like you're in the cockpit of a fighter jet when you're in Sport+ throttle setting and S3 transmission setting.
2. The increased noise is actually a really good shift indicator. Driving on switchbacks, I'll often shift into 2nd and take full advantage of engine breaking on some of the hairpin turns. And with ASD on, you KNOW when you need to shift up, because your ears are in so much pain, you better do it before they burst. When I was driving along in our neighborhood with ASD off, I wasn't really paying attention, looked down, and I was already above 5000 RPM. Car's as quiet as a mouse with ASD off!
3. Again... fighter jet...
I suspect that I'll turn off ASD whenever I'm commuting or taking the kids to the grandparents or whatever. I'll keep ASD on whenever I'm doing my weekend warrior thing in the mountains.
nomoracin759.00
TProfit81.50
