M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      08-25-2018, 09:46 AM   #1915
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
Originally Posted by imyourmaster View Post
It does work. My dealer flashed a bunch of codes on my M2C when I took delivery. He did not do ASD though.
Your dealer uses bimmercode?
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
AndrewC198910931.00
      08-25-2018, 10:50 AM   #1916
imyourmaster
imyourmaster's Avatar
Drives: 2021 M2C
2021 BMW M2C  [0.00]
What type of plug in do you have? I can't get it to connect . Worked on my old m2. Thanks carl
I don't know what kind of plug he used but it was a wireless adapter that plugs into the OBD port.
My SA has the app and adaptor which he uses on his own car. He offed to code mine when I picked it up free of charge. Solid guy.
Kankles1484.50
      08-25-2018, 02:04 PM   #1917
M3_WC
Drives: M3
You’ve got a cool SA. Not many will do coding, let alone even know anything about it.
      08-26-2018, 11:35 AM   #1918
The Ferret
The Ferret's Avatar
14
Bimmercode Settings
So today I logged in and coded a few things. Car is a manual Pre LCI facelift. Just wondered what cool things people have done or any questions people may have that could be answered here. I would like to have indicator lights on all the time but can't figure out how for example. All comments and helpful suggestions welcome. Cheers fellow Code lovers
      08-27-2018, 10:17 AM   #1919
BIGW0RM
You got my money?
BIGW0RM's Avatar
Drives: Ice Cream Truck
2022 BMW M3  [9.50]
Originally Posted by ChrisK View Post
Unfortunately, no. I tried different options via expert mode and I can't get ASD back on. I will wait for a fix.
Did you ever end up fixing it? How did you get it back on? I have same problem.
2022 G80 M3 Competition X / 2020 Range Rover Sport P525 / 2023 Ford Raptor
      08-27-2018, 10:30 AM   #1920
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I had gotten a software update from the dealer, and that restored everything. This is why I am going with the ASD bypass cable this time.
www.ReTuneTheDeTune.com
BIGW0RM3154.50
      08-27-2018, 10:51 AM   #1921
Cacou
13
Drives: F90
I have the same problem. I just connected Bimmercode and did not even make any change to the coding. I can't download map updates.
Any solution to restore NAV? Thanks.
      08-27-2018, 10:20 PM   #1922
imyourmaster
Drives: 2021 M2C
2021 BMW M2C  [0.00]
Originally Posted by mvigod View Post
Originally Posted by ///M Houbi View Post
Anyone any reports for bimmercode on a M2 Competition?
Good question. Came here to find same thing. Just got my M2 a few days ago and want to code a few things but don't want to start if not supported yet. Does anyone know yet? thanks.
My SA used Bimmercode on my M2C when I picked it up from the dealership. Worked like a charm.
mvigod181.50
TF24.50
      08-28-2018, 11:43 PM   #1923
TheAMackAttack
Drives: 2016 M2 LBB DCT
Hi all - Random question: Do you keep your OBD device plugged in 24/7 or only when doing some changes? It sounds like there is a potential to drain the battery but it would also be nice to have plugged in for quick changes with the exhaust or ASD, etc.
      08-29-2018, 12:55 AM   #1924
izzyM2
izzyM2's Avatar
706
Drives: 24’M2/21ID.4/21’MacanGTS
Mine is always plugged. Never had an issue. I have to remember to pull it out before dealer services.
      08-29-2018, 01:07 AM   #1925
TheAMackAttack
And which OBD do you use? How often do you drive? I'll probably only drive my car a few times a month wondering if that would drain the battery or if I'd be good.
      08-29-2018, 02:04 PM   #1926
imyourmaster
Drives: 2021 M2C
2021 BMW M2C  [0.00]
It does not have to be plugged in 24/7. After the codes have been flashed you can safely unplug it until the next time you wish to make changes.
      08-29-2018, 05:19 PM   #1927
///M Houbi
///M Houbi's Avatar
Switzerland
1655
Drives: M2 Competition
But if you want to use it permanently with an app like Bimmerlink?
      08-29-2018, 07:49 PM   #1928
BJM2018
18
Drives: 2018 M2 DCT
Hopefully this has not been asked before, but can it reduce the time to power all off? Have an 18 M2 and after installing a mirrortap into the rain sensor power, after closing the door, it can take up to 14 minutes to power down?
      08-29-2018, 09:09 PM   #1929
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
I grabbed power from the auto dimmer in the rear view and it goes off right after you shut off the motor. Might want to change the wire you're tapping to do the same...
///M2 - 2018 LBB DCT
      08-30-2018, 12:09 PM   #1930
imyourmaster
Drives: 2021 M2C
2021 BMW M2C  [0.00]
You don't need to run the app permanently. You only use the app while you are coding. After the new codes are flashed you close the app and unplug the adapter from the OBD port.
      09-01-2018, 01:31 AM   #1931
BJM2018
18
Drives: 2018 M2 DCT
Not sure which connector is the auto dimmer but I assume it is the larger one. I did tap into first but was getting intermittent power, so then went to the smaller rain sensor one.
      09-01-2018, 02:03 AM   #1932
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
Intermittent? Maybe you needed to use a bigger blade from the mirror tap kit? Sounds more like a connection problem than a source problem. I kept upping blade sizes until they wouldn't fit, then went back down 1 size and lodged it firmly into the molex.
      09-01-2018, 01:30 PM   #1933
BJM2018
18
Drives: 2018 M2 DCT
Ya I dont know why it happened, I have used mirrortaps before in other cars, with no issues and the one I purchased was direct from their website for this specific car. I thought maybe when I pulled the large connector out I may have possibly disconnected it when putting it back but both clicked in properly so not really sure...
      09-01-2018, 01:49 PM   #1934
larry.beck
larry.beck's Avatar
2018 BMW M2  [0.00]
I used the mirrortap kit that comes with 4 pairs of different sized blades - is that what you have as well?
      09-01-2018, 01:54 PM   #1935
BJM2018
18
Drives: 2018 M2 DCT
Yes I had the existing one with the 4 pairs, and because I didn't want to do it again, I also purchased the exact one also..
      09-03-2018, 06:25 PM   #1936
TheAMackAttack
Hey guys maybe a simple answer since this is all new to me but I plugged in the Veepak OBD BlueTooth (BimmerCode now recommends Bluetooth? Unless I'm reading their recommended OBDs thing wrong) and when I plugged it in and turn on Bimmerlink on my iPad (and then later on my iphone--both in airplane mode) it said to connect to the OBD's Wifi network and when I would try to do that I would get error messages on my iPad or phone.
Any idea what I'm doing wrong. I'm sure it's something super simple...
