08-15-2018, 08:23 AM | #1894 |
Rep 681
I believe 5 is only available on the earlier cars. I can only do up to 3 on my 5/2017 build. I'd rather have 5 myself, or at least the option.
08-15-2018, 10:17 AM | #1895 |
Rep 247
08-15-2018, 11:17 PM | #1897 |
Rep 276
Do you guys know if there is a way to code out or disable the rear view autodim? I have 5% rear tint so it's not needed and actually it still dims when cars are behind me at night making it really dark.
2010 AW E90 335i M Sport
2012 GTR 2017 STi Limited 2018 LBB M2 DCT |
08-16-2018, 09:54 PM | #1898 |
Rep 130
08-17-2018, 07:35 AM | #1899 |
Rep 6
Sat Belt Warning
I disabled my seatbelt warning - under ECUs *Advanced Crash Safety Module and then it is the first item in the menu, (Seat belt reminder driver seat)
08-18-2018, 04:22 PM | #1901 |
Rep 326
Drives: 2021 X5M
I just got the Veepeak OBD Bluetooth adapter ( https://amzn.to/2OLXzyN ). I was wondering if anyone has used this one yet. It got high ratings on Bimmercode website. It's like 28 bucks normally but I was lucky when I went to buy it they had a lightning deal on amazon for this yesterday and was 22 bucks! Good timing!
I had the old Vgate iCar 2 before which relied on wifi. This one seems much better using Low Energy Bluetooth. Supposed to have a faster transfer rate and more reliable. Bimmercode also highly recommended the Kiwi 3 OBD adapter ( https://amzn.to/2vVhfcK ) but that one is 98 bucks. Is the Kiwi 3 worth the extra 70 bucks over the Veepeak? Anyone have experience with both and can discuss how they compare? I'm getting ready to code my son's '18 3 series! Also after coding should I always go in and clear out all error codes as a best practice? I think I did this last year on my X5 but wasn't sure if same applied on newer 3 series. If clearing codes is necessary should I do it after all coding is complete or do it after each module is coded? Or is it ok either method? Thanks. |
08-18-2018, 07:07 PM | #1902 |
Rep 34
Does anyone know if it is possible to change the graphic of the car that appears under the rev and speedo? It is a white/grey colour and I would love to make mine LBB!
08-19-2018, 05:04 AM | #1903 |
Rep 2,577
Hi guys, if dealer updates me to latest Istep and reset all my codings, can I just load the BimmerCode saved file to recover codings?
BTW mine is a M2 MY2017, why I want the latest Istep is because I found WOT shift in S+ mode is rough enough to flash the traction light every single time. I heard newer version software is smoother in S+ shift. Doesn't hurt to give a try. Will report back. Anyone help with my question?
Lemania 2320
08-19-2018, 10:42 AM | #1904 |
Rep 14
This thread has been SO helpful...thanks to all that have contributed.
Small problem: I used Bimmercode to "Open doors at ignition shutoff", but it only unlocks the driver door. Is there a solution that opens BOTH doors? thanks again, Dave |
08-21-2018, 04:49 PM | #1905 |
Rep 1,418
Not in my car atm but that may be in your idrive settings. It may be set to unlock only driver door?
08-23-2018, 03:08 PM | #1906 |
Rep 326
Drives: 2021 X5M
08-23-2018, 03:15 PM | #1908 |
Rep 326
Drives: 2021 X5M
08-24-2018, 12:48 AM | #1911 |
Rep 6,635
08-24-2018, 01:36 PM | #1912 |
4143
Rep 6,926
08-25-2018, 08:13 AM | #1913 |
Rep 239
Drives: 2021 M2C
08-25-2018, 08:34 AM | #1914 |
Rep 276
