M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      07-27-2017, 07:46 PM   #859
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
Drives: BMW 2017 M2 07/16 Build
Originally Posted by vp View Post
Originally Posted by jimmy9980 View Post
It must be the bmw servers ? Pretty bad it has been going on for 2 weeks now
It?s the new ?Connected+? feature
Who knows one others user said it had something to do with the ATT Service.
I think its there servers it responding right maybe overwhelmed lol
Current
Waiting 2022 G80 M3 AWD Comp Brooklyn Grey
2004 E46 M3 White
END OF LIFE = 2017 M2 07/16 Build, 2014 M5 05/14 Build, 2008 M3 ESS Supercharged, BMW 2003 M3, BMW 2001 325ci
      07-28-2017, 12:26 PM   #860
Black-Demon
Drives: BMW F31 318Da M
Is it possible to code the sport auto transmition?
My car has the normal auto transmition (coded as 205). Is it possible to change it to 2TB version wih the app?
      07-28-2017, 03:32 PM   #861
McGary911
McGary911's Avatar
Drives: 2017 LBB M2 DCT
I now have rear fog lights, thanks to bimmercode and a good post on how to mod the headlight switch so the foglight button on the lower left will work.
FEM_BODY / 3060 LCEMaster 1C / NSL_Verbaut = Verbaut
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_output = nsl_l
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_L_Function = nebelschlusslicht
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_output = nsl_r
REM / 3063 LCELampMapping 2 / Mapping_Nebelschlussl_R_Function = nebelschlusslicht
That's all it took. It worked the first time.
Some buy the headlight switch that already has the fog button, but it's easy to mod your existing one. I kind of like the stealth of having no symbol on the button. Excellent thread on how to do that here.
http://f30.bimmerpost.com/forums/sho...d.php?t=877278
2017 LBB ///M2 DCT
2013 Porsche Boxster S
Em-too279.50
      07-28-2017, 04:50 PM   #862
Em-too
Em-too's Avatar
Drives: 2016 M2
Pretty sweet!
      07-28-2017, 05:27 PM   #863
lax01
Drives: 2017 M2
Updated here
Em-too279.50
V.Smurf163.00
      07-28-2017, 05:31 PM   #864
Em-too
Em-too's Avatar
Drives: 2016 M2
Originally Posted by lax01 View Post
Updated here
Note- Some of the settings are in the rear electronic module and one is in FEM
      07-28-2017, 05:52 PM   #865
lax01
Drives: 2017 M2
Updated with the other link too...didn't realize physical modification was needed as well
Em-too279.50
      07-30-2017, 12:53 AM   #866
ried
ried's Avatar
Drives: F31, F80
Coded the comfort seat access tonight. Works perfectly.
      07-30-2017, 02:34 AM   #867
V.Smurf
V.Smurf's Avatar
163
Drives: M2 LBB DCT (LCI) | X3 30i
Hi lax01,
Updated here
I'm not sure if you saw this post elsewhere in the forum, but I don't see the auto start/stop feature in the document ...?
Originally Posted by hoyasaxa View Post
You guys on about auto start / stop:
1) in the US it remembers your choice by default.
2) abroad, it can be changed easily by coding
Code:
Auto Start/Stop Default OFF:
	3023
TCM_MSA_DEFAULT_OFF			set to: aktiv
Auto Start/Stop Remember Last Setting:
	3023
TCM_MSA_MEMORY				set to: aktiv
http://www.bmwesys.com/guides/BMW%20...%20series.docx
      07-30-2017, 10:44 PM   #868
lax01
Drives: 2017 M2
Originally Posted by V.Smurf View Post
Hi lax01,
Thanks - updated. Noted its only for ROW
V.Smurf163.00
      08-01-2017, 05:48 PM   #869
V.Smurf
V.Smurf's Avatar
163
Hi Folks,
Originally Posted by ried View Post
The iCar 2 is available for $18.50 on Amazon.
Being based in AU, I'm unable to order the adapter from Amazon But I did a search on eBay and it looks like they are available there.
Has anyone purchased these adapters via eBay ... and if so, what is the experience..? I'm mindful of copies/clones that may not work so well with the application
Thanks!
      08-02-2017, 01:11 AM   #870
johanva
johanva's Avatar
Drives: BMW M2 MY2018
Hi Folks,
Thanks!
Bought mine from OBDSCANNER on amazon:
https://www.amazon.de/gp/product/B01...1_E_Asin_Title
I received it last week but it doesn't work. Think the item is broken. Sending it back hope to get a new one that does work.
      08-02-2017, 06:08 AM   #871
wenklaw
Drives: m2
Ive coded ID6 lite which works fine however has anyone managed to figure out how to rearrange the tiles?
Mine rearranged themselves today, it was:
'audio/music' - 'communications' - 'map'
now its
'communications' - 'audio/music' - 'map'
It doesn't really matter but I would like to move them if I could.
      08-02-2017, 08:00 AM   #872
ZM2
Drives: 2017 LBB M2
now its
      08-02-2017, 08:59 AM   #873
jimmy9980
BMW DRIVER ///M
jimmy9980's Avatar
The online apps started working again as of today
Current
2004 E46 M3 White
      08-02-2017, 09:45 AM   #874
wenklaw
Drives: m2
Originally Posted by ZM2 View Post
Thanks for that but I forgot to mention I have a pre LCI M2 (My17) without a touch screen.
      08-02-2017, 02:12 PM   #875
Stilakazam
Drives: 2017 M2
now its
press the Menu button so it shows all 6 tiles, then select a tile to move and move the controller left and right to shift the tile left and right.
ried791.50
McGary911472.00
      08-03-2017, 08:34 AM   #876
wenklaw
Drives: m2
I did try something like this but struggled to 'select' a tile, I can highlight it obviously using the controller but don't see an option to select a tile as such, what button selects tile?
      08-03-2017, 01:13 PM   #877
zenmaster
Drives: '17 M2
Can you use Bimmercode to determine the current i-step version?
      08-03-2017, 03:39 PM   #878
Stilakazam
Drives: 2017 M2
you turn the dial so it is highlighted, sorry my worded could have been better, once you highlight a tile, you bump the controller left and right to move that tile. Can only be done at a stop I think as well.
      08-04-2017, 10:42 AM   #879
arwin
Drives: 2017 AW M2
I had to revert to idrive 5 as 6 lite with the 5 series (or 3 series?) car graphic was just to much for my OCD to cope with and to be honest I don't really see much, if any benefit. If it has the 2 series car graphic I would've kept it though.
I have coded so far
Video in motion - not tested yet
Stop Start - remember last setting, so off remains off - Worth the cost of the app and adaptor on its own
One touch close folding mirrors
Door handle lights on reverse - not tested
Head unit off on door opening
EDIT:
If I code ID6 lite and then change the 'my vehicle' setting to display detailed information the graphic of the car is no more, you just get details of MPG etc, result, I can live with that as actually ID6 with the multi live tiles is an improvement on ID5 for my usage.
I've basically coded the same thing on my car this morning but the only thing I can confirm that is working is the headunit turning off with the door opening.
I saw a M Lap Timer app option in bimmercode and I activated it, but where is that supposed to show up?
Also, for the folding mirrors, it's supposed to fold when I use the key fob to lock the car, right? And then open when i unlock using the key fob as well?
Mine doesn't seem to be doing anything when I lock/unlock with the key fob
      08-04-2017, 10:51 AM   #880
arwin
Drives: 2017 AW M2
Nm. I figured out the closing mirrors. I had to set the comfort closing delay to no delay. Folding mirrors working!
