03-22-2020, 02:38 PM | #1343 |
Rep 139
03-24-2020, 12:54 AM | #1344 |
Rep 68
Update
I called BMW Genius and they said my car couldn't get CarPlay. Wouldn't explain why.
How is this possible for a 2018 car? Are there any other options since I would quite like to have Carplay. I'm hoping to not make any big hardware modifications to the car and didnt think I'd need to. |
03-24-2020, 02:01 AM | #1345 | |
Luxury at the redline :)
9105
Rep 7,563
Your BMW Genius is not that informed on the facts. |
03-24-2020, 11:15 AM | #1346 |
Rep 3,054
03-24-2020, 12:30 PM | #1347 | |
Rep 3,968
If/when you get this working - I'd love to know your thoughts. I personally thought that I wasted $300 on Carplay (my dealer warned me, but I did not listen). Not implemented well in BMWs IMHO.
03-24-2020, 12:50 PM | #1348 | |
Rep 68
Dealership says they can't do anything at this stage to retrofit headunits. Said I could look at aftermarket solutions but that it would void the headunit warranty so not something they can recommend. I might look into Bimmertech but this whole situation has been quite frustrating. I'm coming from a 2016 VW GTI that has it setup seamlessly so having to do this stuff on the side in a 2018 BMW seems really stupid. |
03-24-2020, 04:23 PM | #1349 | |
9105
Rep 7,563
https://www.bimmer-tech.net/blog/ite...it-in-your-bmw https://juicelp-dev.s3.amazonaws.com...y+-+Launch.pdf |
03-24-2020, 11:02 PM | #1350 | |
Rep 68
Even Bimmertech is saying CarPlay is possible but I'd have to install a WiFi antenna, which I'm not sure I want to do since it always opening up the interior trim and accessing the head unit, etc. |
03-25-2020, 12:28 AM | #1351 | ||
9105
Rep 7,563
Since this unit comes with CarPlay preparation, the necessary hardware already comes installed standard, which consists of Wi-Fi antenna, which is also used to communicate with Screen Mirroring feature, with some Android phones. When you choose to add CarPlay after purchase, BMW provision is activation via their ConnectDrive portal. Certain aspects of the CarPlay function uses the vehicles build-in 4G LTE connection, which is standard in US/Canada spec vehicles, in addition to your personal phone data. I suggest you call ConnectDrive Canada (1-800-493-4070) directly and find out if they can activate it OTD. Maybe there is some regional restriction that I'm not aware of but as far as the required hardware goes, it's all there and ready to go, as outline by this official document below that was privy to sales franchise dealerships. |
03-25-2020, 12:37 AM | #1352 | |||
Rep 68
I'm open to calling them again but I've had 2 sources within BMW telling me my car isn't compatible (after checking my VIN) which makes the chances of that being not true less likely. Wish me luck tho |
Poochie9104.50 |
03-25-2020, 12:42 AM | #1353 | ||||
9105
Rep 7,563
This is first case where I'm hearing it's not available especially on an M2, which comes with the top-tier headunit as a standard option. I hope it works out for you |
03-25-2020, 08:28 AM | #1354 | |
Rep 3,514
I've only found 3 useful things: Message notifications Apple Music (Included with my Verizon mobile service or I would not pay for it) Waze If not for Apple Music I would use iDrive. CarPlay has more bugs. I kinda cringe with every iOS update as the last one caused intermittent connection problems. |
doug_9992541.50 |
04-27-2020, 03:41 AM | #1355 | |
Rep 13
For BMW activation you MUST have had a factory fitted wifi antenna (in UK this was part of Enhanced blue tooth). However if you use aftermarket activation (I'd recommend Kubax on here) you can do this WITHOUT a wifi antenna, see my post on pistonheads. In the end I decided to install Wifi antenna which does improve speed and stability of Carplay. However was really easy to do - see my experience below! With a 2018 M2 you might be able to activate carplay with a simple USB stick, dependant on how new your iDrive software is. If your iDrive is too new to allow the USB activation then you have to go down the eNET cable route (enet cables are about $15)- Also easy if you have a PC with ethernet port (I used a mac and virtual PC) https://f87.bimmerpost.com/forums/sh....php?t=1674016 & here for carplay activation (bimmerpost thread on same seems to have vanished!) https://www.pistonheads.com/gassing/...=181&t=1844380 Last edited by hoganscrogan; 04-27-2020 at 03:54 AM.. |
05-02-2020, 02:28 AM | #1356 |
Rep 11
CarPlay and WiFi aerial
Hi, Looking to install CarPlay
1. Is the links on eBay working well? (Ones you download to a usb) 2. What WiFi aerial do I need to get on ebay(link please) (car is 2017 pre-lci) Thanks |
05-02-2020, 05:14 PM | #1357 | |
Rep 567
And heres a good Wifi antenna https://www.ebay.com/itm/252975706813 |
05-02-2020, 11:09 PM | #1358 | |
Rep 117
I've got a 2018 M2 and there's no CarPlay! What a joke, you reckon it can be fitted in the LCI models? Cos the dealer says it can only be done from factory of which I doubt.
Instagram: m2rs4_official
Proud owner of Amelia & Rae. Yes, I named my vehicles 2018 BMW M2 LCI (Wedge Performance Tuned + Pure Turbo Stg 2 Upgrade) 2019 Audi RS4 Advant |
05-03-2020, 07:48 AM | #1359 | |
Rep 3,054
Thanks
Apple CarPlay Fullscreen for NBTEVO / ENTRYNAV2 / Anti-Dazzle F/G
CS FLASH G8X /GTS FLASH F8X / F8X Ultimate PACK / NBTEVO iDrive 6 FLASH iDrive Firmware Update + CarPlay Fullscreen -> Video Process Visit BIMMER-REMOTE.com - 10% OFF with BIMMERPOST_10 promocode info@bimmer-remote.com or PM |
m2rs4_official95.50 |
05-03-2020, 08:07 AM | #1360 | ||
Rep 117
05-04-2020, 05:15 AM | #1361 |
Rep 11
Hi,
I have a pre lci 2017 m2 without CarPlay. Noticed an eBay post for installing CarPlay via a usb for 30£, is this working? Another thing, I read I should get a WiFi aerial, different products on eBay, which one should I get? Link would be helpful! Thanks. PFA |
05-04-2020, 03:51 PM | #1362 | ||||
Rep 11
SPSE93112.50 |
05-08-2020, 03:59 PM | #1363 |
Rep 97
Another happy customer here of kubax86
Installation was super easy. The instructions say the procedure should take 6-7mins. Mine literally took 2 mins. Easy, fast and efficient. Can't recommend kubax86 more. Notice to all new installers: after installing I recommend parking the car, locking it and let it settle. At first my CarPlay felt a bit slow - glitchy. After a few hours coming back to the car it worked flawlessly. |
Shahaf291163.00 mzcp2675.00 |
05-20-2020, 12:10 PM | #1364 |
Everyday I'm shuffling
449
Rep 1,098
Good taste in cars.
Tags |
apple bmw, carplay |
