M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > New MPE exhaust options
      05-02-2017, 10:31 PM   #67
BSMF87
BSMF87's Avatar
140
Drives: M2 BSM 6SPD
Anybody try wiring the switch to always on?
      05-03-2017, 01:50 AM   #68
BishUK
BishUK's Avatar
440
Drives: M2 DCT LBB
Originally Posted by Artemis View Post
My MPE (2016 - original version) also features a master switch.
Though under the boot cover, so a hassle to reach if you got luggage inside the boot.
Does that master switch still exist in the 2017 upgrade ?
Yes, same module and same master switch in 2017 model.
      05-03-2017, 08:48 AM   #69
McPurrs
The deuce gets loose
290
Drives: '17 M2 BSM 6MT
Originally Posted by Deutsches Blut View Post
Based on my understanding of the process, you still can. You just have to push the red button after starting the vehicle and use the BT to put it into track mode when you wish.
Correct, which means you already decided to before you went out driving around. That is intent and would absolve BMW from any legal issues should someone fight a noise ticket since they now have a system in place where you cannot 'accidentally' open the valves without meaning to.
      05-03-2017, 09:14 AM   #70
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
I think we need more electrical engineers in this forum.
This little red button should be easy to defeat. I am not too worried about it.
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      05-03-2017, 11:07 AM   #71
Darekme
Poland
42
Drives: M2 LCI
You dont need engineer, all you need is just 10 ft of cable, one beer and move that bloody button in the cabin, e.g. below a/c panel.
      05-03-2017, 12:05 PM   #72
David1
David1's Avatar
Drives: 09 E92 09 X5
Why do you even need to install the stupid button or even the Bluetooth stuff? Can't you just install the exhaust and let the exhaust valve functionality work as stock? May not be as good as having the valve open all the time but close.
      05-03-2017, 12:11 PM   #73
CommitConfirm
475
Drives: The Bus
You don't need an electrical engineer. High school level will suffice.
      05-03-2017, 01:05 PM   #74
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
Can you do a DIY?
      05-03-2017, 01:17 PM   #75
omasou
omasou's Avatar
Drives: BMWs
2023 BMW S1000RR  [0.50]
2022 BMW F900XR  [3.00]
2022 BMW X6 40i  [0.50]
2020 BMW M2C  [9.50]
If you have the tool and the connector pin into the button is the same type as the connector pin into the car connector you should be able to follow the wire into the button, take it out of the button connector, follow the other wire out of the button, remove that wire from it's connector at the car end and insert the first wire.
Is there a reason this would not work?
EDIT: tools like these stop you from boogering up the connectors and pins...
http://www.unofficialbmw.com/all/ele...tact_pins.html
https://www.ecstuning.com/b-schwaben...FQMDaQod-wkFBw
      05-03-2017, 01:42 PM   #76
gavinsan
Drives: F82 M4
I had my installer try to fit the exhaust minus the button in the boot but sadly without the red button connected and pushed the bluetooth controller will not open the valves
      05-03-2017, 02:17 PM   #77
David1
David1's Avatar
I also mean not hook up the Bluetooth. Just leave all the electronics alone and let the comfort/sport button work as it does on the stock exhaust.
      05-03-2017, 02:21 PM   #78
gavinsan
Drives: F82 M4
Yes you can do this for sure but seems a waste as the only way to open the valves is with the bluetooth so you end up with an exhaust that is on a quieter valve closed mode permanantly.
It does sound good like this but track mode is such an animal you won't want to never have it available .
The sport button only gives a few burbles when you lift off the gas and does not open the valves like in the M3/4
      05-03-2017, 02:27 PM   #79
David1
David1's Avatar
So the valve control and wiring is different? Could swap the electronics from the stock valve to the MPE valve then and have it work like stock?
      05-03-2017, 03:07 PM   #80
omasou
omasou's Avatar
Drives: BMWs
2020 BMW M2C  [9.50]
Has everyone seen this post... http://f87.bimmerpost.com/forums/sho....php?t=1231404
Funny the F80 does sound like a boat
Interesting but not giving up my garage door openers.
http://www.cgprecision.com/cms/index...egory=19726366
      05-03-2017, 05:48 PM   #81
F15X
Ridin Slow
F15X's Avatar
Drives: F15 & G01
This is very simple to get around, either bypassing permanently and having the switch basically act like a toggle instead of a momentary. If not it will need to be set up with a 12v relay that triggers for a short time on power up. (Acting like the momentary button and wired to the same pins.
I don't have an m2 I have an m3 so if someone brings a car to the Tampa/sarasota Florida area hey maybe even Miami I will create and deploy a $50 solution to this problem I promise you
And yes, I have my masters in electrical engineering
      05-03-2017, 06:00 PM   #82
Deutsches Blut
82
Drives: 2012 335i E92 M Sport / 2008 C
Good point. My dealer had me sign a waiver eliminating them from any liability. I don't understand getting tickets for loud exhausts when you have plenty of Harley's on the road considerably louder. They even market that as a safety feature.
      05-03-2017, 10:50 PM   #83
Enriquezar1
Drives: 2017 BMW M2 LBB
Besides the red button in the trunk. Any difference with the design, quality and performance of the revised MPE with the previous version?
      05-03-2017, 10:52 PM   #84
ried
ried's Avatar
Drives: F31, F80
Does the revised MPE have a different part number, or is it still 18302412432?
      05-04-2017, 12:39 AM   #85
MR_M2
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
I am getting the MPE installed by the dealer tomorrow. I hope I don't get the red pimple. Wish me luck
      05-04-2017, 05:34 AM   #86
Semi-Poor
Semi-Poor's Avatar
Drives: 2017 M2 Coupe
Please advise as to any changes besides red button and photos, please.
2017 M2 Coupe Black Sapphire Metallic
      05-04-2017, 09:53 AM   #87
gavinsan
Drives: F82 M4
No changes sadly other than red button .
Exhaust still vibrates on cold start at the tailpipes and makes a funky noise .
      05-04-2017, 10:34 AM   #88
MR_M2
BMW M2  [0.00]
BMW X7 M50i  [0.00]
I am trying to get the old MPE before it goes out of stock.
