BMW M2 Forum > BMW M2 CS Model > M2 CS Dyno - 491ps / 484 hp Stock (from Sport Auto)
      08-20-2020, 04:40 PM   #23
KevM2
KevM2's Avatar
BMW M2 Competition  [0.00]
  [0.00]
I wonder if they give their press cars a different tune for more hp 🤔
      08-20-2020, 06:41 PM   #24
jmg
jmg's Avatar
18663
Drives: G82 M4C X-Drive
2022 G82 M4C X-Drive  [9.85]
2018 F80 M3 CS  [9.87]
2019 i3 BEV  [0.00]
Originally Posted by CanAutM3 View Post
Originally Posted by jmg View Post
Most probably not. You would have to put them on the same dyno to be sure since dyno's aren't absolute. They all give different readings and should only really be compared to other cars on the same dyno.
So far ring times show that the M3/4 CS is still faster. M2 CS is in the 1:50's while the M3/4 CS is in the 1:30's. 20 seconds faster. Whether that is due to power is up to interpretation.
Not really. Comparing apples-to-apples, AMS/SA supertest results the M4cs and M2cs are within 1 second of each other (both in the 7:42). It has to be noted that the M4cs was tested on a rather hot day and the M2cs was tested on the faster repaved 'ring, but nonetheless, I expect the M2cs and M4cs to be very close in terms of performance.
That's what I'm saying. I don't think the M2 CS has more power. If anything slightly less if their ring times were that separated (depending on tires, weather, driver etc of course).
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
IG: Raging_G82
      08-20-2020, 06:45 PM   #25
CanAutM3
General
CanAutM3's Avatar
21115
Drives: 2021 911 turbo
My point is that the M4cs is not much faster (if at all) than the M2cs...
I agree, the M2cs does not make more power than the the M4cs. However, the slight power and torque deficit of the M2cs is made up by its lighter weight.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black
MDuckie93.00
      08-20-2020, 08:08 PM   #26
jdub486
Drives: 19' M2C dct/ e90 335d dd
Is this wheel horsepower or crank?
Has to be crank.
      08-20-2020, 08:16 PM   #27
infinitekidM2C
infinitekidM2C's Avatar
Drives: 2019 M2 Competition
What are BMW thinking? Gonna spin that crank hub!!
cheveux401.50
      08-20-2020, 11:06 PM   #28
CanAutM3
General
CanAutM3's Avatar
21115
Has to be crank.
Crank.
Maha dyno figure crank hp by measuring drivetrain loss. Blue line is measured whp, green line is drivetrain loss, red line is calculated crank hp (red=blue+green).
Poochie9104.50
sdhotwn2128.50
      08-21-2020, 07:25 AM   #29
M3GymNut
Drives: 2021 M3Comp
Guess the price tag seems even less of a concern after these results.
      08-21-2020, 09:52 AM   #30
Hegge
880
Drives: 2020 BMW M2 CS
I agree with this. The CS will be a special car for those who are lucky enough to get an allocation. Just as long as they don't pay $30K over MSRP, which is new 911 Carrera S base price.
RPM33612.00
      08-21-2020, 05:09 PM   #31
Big boi m5
Drives: 135i
Originally Posted by EXE46 View Post
Originally Posted by buzzybee View Post
dam thats wild
cant wait till these hit the used car market
Where it will cost more than new. This is BMW most desirable modern M car.
It's low volume and still pretty heavy, for the cost, it's sort of a parting gift M2 lovers. Personally I'd say just get a M2 race?
Anyway amazing 15 years later the economy car based M is putting out power equal to the top of the line M5
      08-21-2020, 08:06 PM   #32
Jimjamz
Jimjamz's Avatar
4571
Drives: G81 M3 Touring (Frozen Black)
Originally Posted by LLNM4 View Post
It's just a tune.... the M4 GTS same S55 gives you 500hp
Stage II from Alex alpine or BM3 are more impressive.
Can not justify the price... i will wait for the G82 m4
Wasn't the GTS water-cooled? I think any tune can whack up hp but doing it with confidence to maintain a warranty is another thing altogether. I understand the CS has altered cooling and air circulation in the engine bay?
      08-22-2020, 11:58 AM   #33
CanAutM3
General
CanAutM3's Avatar
21115
The GTS has water injection in the intake to be able to maintain boost as IAT increases.
That's the thing with aftermarket tunes, they simply tap in the thermodynamic margin the S55 has. On stock tunes, the engine keep making peak power throughout an entire track session because it has sufficient thermodynamic margin to sustain the power despite the higher IAT. Aggressive aftermarket tunes are great for highway pulls, but will revert back to stock power levels after a few laps around a track.
dmboone254972.00
      08-23-2020, 08:42 AM   #34
jdub486
What do we think about torque? M4 CS is rated at 442 lb feet but the m2 CS at only 406.
      08-23-2020, 09:19 AM   #35
medphysdave
medphysdave's Avatar
Drives: M2 CS | 85 of 592
We think it's 36 lb ft less.
Poochie9104.50
hansomatic-2500.00
      08-23-2020, 09:40 AM   #36
MadBimmeRad
MadBimmeRad's Avatar
7122
Drives: M235i, 420i, and now the M2 CS
dam thats wild
I could not have said it any better myself
M2CS,
The second coming of ///M!
      08-23-2020, 09:51 AM   #37
CanAutM3
General
CanAutM3's Avatar
21115
As posted previously, this is consistent with the dyno AMS/SA charts, the M2cs showed ~590N-m while the M4cs showed ~640N-m, ~9% more just as the official rating.
      08-23-2020, 11:56 AM   #38
Ragged Edge
Ragged Edge's Avatar
365
Drives: '16F80,TR6,Defender,PA23-250T
2016 BMW M3  [0.00]
Can you give us an apples to apples weight comparison?
From what I understand, despite being marginally larger, the F80/82 was ever so slightly lighter.
      08-23-2020, 01:43 PM   #39
CanAutM3
General
CanAutM3's Avatar
21115
It's all in this thread
If you look at the screenshots from the M2cs and M4cs dynos, the weight of each car is also posted:
M2cs: 1588kg
M4cs: 1609kg
M4cs is lighter than M2C but heavier than M2cs
      08-23-2020, 03:06 PM   #40
F87EVO
F87EVO's Avatar
Cyprus
4031
Drives: BMW F87 M2 CS (6MT)
M2cs: 1588kg
M4cs: 1609kg
https://www.pistonheads.com/news/ph-...k-review/42864
M2 CS - with 6MT and CCB - 1525kg.
Sometimes, the simplest recipes, done well, with quality ingredients, are the tastiest, - evo Car of the Year 2020
2020 BMW F87 M2 CS - 6MT - Misano Blue Metallic
      08-23-2020, 04:13 PM   #41
CanAutM3
General
CanAutM3's Avatar
21115
Originally Posted by Turbomeister View Post
1550kg is the DIN spec weight for a 6MT, they just deducted 25kg for the CCB. It's not actual measured weight.
The M2cs weighed by AMS/SA is a DCT with irons.
      08-23-2020, 04:13 PM   #42
F87EVO
F87EVO's Avatar
Cyprus
4031
That's the DIN spec weight, not an actual measured weight.
Isnt the Din weight the actual car weight ? EU curb weight includes the driver - 75kg more . Not all the drivers weight 75kg thought.
      08-23-2020, 04:17 PM   #43
CanAutM3
General
CanAutM3's Avatar
21115
It's a "spec" weight, for certification purposes, different cars will have different weights depending on options. The DIN spec weight of the M4 when it was released was 1497kg, you'll be hard pressed to find an example that is that light. That's why I prefer to rely on actual weighing from "trustable" publications.
F87EVO4031.00
clee1982797.50
      08-24-2020, 07:14 AM   #44
BSM2C
Drives: 2020 BMW M2 Competition
Is this level of output attainable in a 2020 M2C? I've heard of a few tunes out their but I'm fairly ignorant.
