M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Anyone using the M2 OEM wheels as Winter setup?
      12-11-2018, 11:46 AM   #1
X54TH
Member
X54TH's Avatar
899
Drives: 2019 X5 40i M Sport
My son is picking up his M2 on Saturday. We have to figure out his Winter setup. We are now looking to take his 19" OEM wheels and turn them into the Winter setup. Do you think the 19" OEM wheels could survive the Canadian winters? We are pretty diligent in keeping a clean car throughout the year. Your thoughts on the OEM wheels for Winter are appreciated and if you are using them for the winter, what size tires did you go with?
M-Azing19.50
      12-11-2018, 12:17 PM   #2
dubzz24
dubzz24's Avatar
117
Drives: 2022 M3 Comp xDrive
Yup! I'm using the OEM 19's for winter and will be using M3/M4 style 513m 18" wheels in the summer. I plan on tracking the car next year so the 18" summer wheels will be better for that, plus I love the looks of them.
The winter tires I'm running have a bit of a stretch to them on the wide OEM rims - 225/40r19 front and 255/35r19 rear. I'd probably recommend going with stock size tires on the stock rims as they'd add a bit more protection at the slight trade-off of a marginally worse snow and ice traction. I only bought them because the price was right (Bridgestone Blizzaks brand new unmounted for $600 CDN).
X54TH899.00
      12-11-2018, 12:24 PM   #3
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
I'm doing the same, though I'm running a wider setup to help protect the wheels.
Running 265 35 19 blizzaks all around.
X54TH899.00
      12-11-2018, 02:30 PM   #4
X54TH
Member
X54TH's Avatar
899
Guys, what size are the OEM tires?
      12-11-2018, 02:31 PM   #5
X54TH
Member
X54TH's Avatar
899
Car looks great!!!
My son was looking at that colour first.
      12-11-2018, 02:34 PM   #6
X54TH
Member
X54TH's Avatar
899
I think this is the OEM setup 788M 19" M Light alloy wheels with Michelin PSS in 245/35 & 265/35
      12-11-2018, 03:24 PM   #7
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
265/35r19 in the back
245/35r19 in the front
      12-11-2018, 04:28 PM   #8
RAM_F30_F87
RAM_F30_F87's Avatar
Check out combinations at https://www.tirerack.com/snow/Winter...8&autoModClar=
X54TH899.00
      12-11-2018, 06:15 PM   #9
M-Azing
Antonito
20
Drives: BMW 335i
I am using standard set up (staggered 245 front/265 rear on 19s) for winter with replica black 437 wheels on Pirelli Sottozero II , only winter tires in stock size, worked great last winter in Toronto and looks awesome; fantastic handling on cold dry roads ...
      12-11-2018, 06:31 PM   #10
X54TH
Member
X54TH's Avatar
899
My tire guy can get Michelin Pilots Alpine in 245/35 and 255/35. They are all out of 265/35. He's suggesting to stick with the Michelins and go with 245/35 all around. This was the cheapest out of the three options:
The other 2 options he gave me are:
ContiWinterContact™ TS 830 P 245/35 and 265/35 these are $130 more
Pirelli WINTER SOTTOZERO™ 2 245/35 and 265/35 these are $400 more
Any thoughts here?
      12-11-2018, 07:41 PM   #11
M-Azing
Antonito
20
Drives: BMW 335i
Any thoughts here?
Prefer the staggered set up - looks just as great as the stock summer tires and ride/handling is very similar. Snow traction is decent enough for Toronto-never got stuck .With this set up, was not desperate to put summers back on.
      12-11-2018, 08:02 PM   #12
X54TH
Member
X54TH's Avatar
899
Any thoughts here?
Awesome. What brand of winter tires did you go with?
2019 X5 Alpine White M-Sport
Software Version 11/2022.31
2023 M2 (HEA) Brooklyn Gray
2021 330i XDrive Alpine White M-Sport
      12-12-2018, 04:41 AM   #13
M-Azing
Antonito
20
Drives: BMW 335i
Any thoughts here?
The Pirelli Sottozero II
      12-12-2018, 07:53 AM   #14
twboy1999
Drives: 1994 honda accord
Any thoughts here?
245/35/19 for your oem rear wheel
might not work
it will be very stretched
2019 M2 HS 10000km and counting
      12-12-2018, 08:01 AM   #15
X54TH
Member
X54TH's Avatar
899
Any thoughts here?
might not work
Decided to go with the PA4 245/35R19 and 255/35R19. The 255's should work in the rears.
M-Azing19.50
      12-12-2018, 08:34 AM   #16
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Yes 255/35/19 would work front and rear
Current '22 X3M LCI..
      12-13-2018, 12:29 AM   #17
dubzz24
dubzz24's Avatar
117
Yeah 255/35r19 will work fine in the rear (it’s what I’m running), but it is a bit stretched which leaves the lip of the rim exposed and more susceptible to chips / rash / damage etc. I’d personally go for 265 on the stock rear rims if I could do it over but you’ll be fine either way.
      12-13-2018, 09:24 PM   #18
bjams
Drives: OG M2 LBB
I got a set of ferric grey 437Ms for winter, but ordered 4 of the "front" wheel version. Square setup with PA4s in 245/35R-19.
It's excellent, and the car still looks great and drives very similar to summer, but slightly softer on bumps (which my fiance appreciates!). I've had no issues at all keeping traction, save for the one night I had to make a late grocery run in some fresh snow. I still made it, but had some fun throwing the back end around on turns.
X54TH899.00
      12-20-2018, 03:34 AM   #19
warrior808
Germany
What did you do with your OEM tires? I read that RFTs can't be remounted. I was thinking about putting winters on my OEM 788M rims and then taking the tires from the 788M and putting them on some Apex S10 rims.
      12-20-2018, 05:25 AM   #20
M-Azing
Antonito
20
Drives: BMW 335i
The OEM tires on the M2 are not runflats
      12-20-2018, 06:25 AM   #21
warrior808
Germany
This isn't what I was told. I don't pick my car up for another 3 weeks, after I get back from vacation, and can check them then. In the mean time, I sent an email out to the salesperson to ask him this.
      12-20-2018, 06:53 AM   #22
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
The stock Michelin or continental tires are not run flat.
