11-28-2018, 01:19 PM | #1 |
Rep 385
1st gear pop out
Has your fist gear ever popped out back into neutral? This happened to me this morning leaving for work when the car was cold. I heard a loud “pop” and at first thought it was suspension or wheel related then realized my gear shifter was in neutral. It was engaged in first because I was pulling away from the light slowly turning left then “pop”, out it came. This can’t be good.
I had some first gear engagement issues before that mostly are taken care of by going into second gear before engaging first. But this was the first time it came out of gear on its own. |
11-28-2018, 06:32 PM | #2 |
Rep 523
Oh no sad to see this happening on the M2 as well! Was an issue on my 135 for the past few years and shop said it's most likely likely synchro but nothing to be concerned avout.
It is a loud shudder and sometimes it would feel like car just got hit! Needless to say it stopped me from launching hard in first which I guess is a good thing given the challenges in laying down 1-2 gears in Ernest
18 M2 6 Spd AW - VRSF DP / CP & Race FMIC, ER TIC & GFB DV+ with BM3 Stage 2 Retired 09 135 JB4 G5 ISO w/BEF, N54 Tuning Performance DPs, BMS DCI, ER Charge Pipe |
11-28-2018, 08:44 PM | #3 | |
381
Rep 731
11-28-2018, 09:38 PM | #4 |
Rep 4,541
Drives: 2015 328d xDrive
My guess is you didn't have it fully in gear and it popped out as a result. I've experienced 1st gear not wanting to fully engage on occasion. All you have to do is slowly let the clutch out while continuing to push into 1st and it will pop into place. I think it's synchro misalignment that causes that.
NYC Bimmer259.50 ried791.50 |
11-29-2018, 09:26 AM | #5 | |
Rep 385
AndrewC198910910.50 |
11-29-2018, 09:39 AM | #6 | |
Rep 4,541
11-29-2018, 09:48 AM | #7 |
Rep 571
I agree. I've had the pop out happen on other cars, it was never anything of concern and seemed as random as a bug hitting the windshield. But definitely worth mentioning to the service advisor at your next oil change if you're continually having trouble engaging first gear. At least you're being smart about it, re-engaging by going 2nd to 1st and not just mailing it in and trying to start from 2nd and wearing your clutch.
coaxial21.00 |
11-29-2018, 12:42 PM | #8 |
Rep 88
Happened to me a couple of times in 3rd gear. But only happened when the car was still cold. Never have this issue when the car was warmed up. I think this is normal and no need to worry too much.
11-29-2018, 07:21 PM | #9 | |
Rep 13,090
If affirmative, check this thread ("High RPM 1st to 2nd gear lockout 6MT (solved: the issue was caused by clutch stop)").
///M is art ↔ Artemis
11-29-2018, 07:55 PM | #10 | |
Rep 385
Yes sir I have the BMS clutch stop! Thanks for the link I am going to try and remove it see if that helps 👍🏼 |
11-29-2018, 09:22 PM | #11 |
Rep 73
If it's a daily occurrence, it sounds like you have the same issue I did since you are popping out while from rolling away from stand still. If you pay attention you while probably notice first gear actually doesn't go in all the away when you get the gear popping out scenarios. Changed clutch stop, tranny mount, checked shifter arms and didn't yield any fixes issues to the issue. Ultimately, the only fix was a new transmission. Sorry bud.
https://f87.bimmerpost.com/forums/sh...1st+gear+issue |
11-30-2018, 01:52 AM | #12 |
Rep 121
I have a problem with the 3rd gear going in reliably. Have to remember to deliberately push it in more before letting up the clutch comparing to the other gears. It grinds 1 out of 10 times if I let go the clutch too quickly.
11-30-2018, 04:32 AM | #13 |
Rep 7,418
Dang this is really concerning because I have the really notchy 1-2 shift in my m2 and I have the bms clutch stop with 2 shims in.
Please let me know pilot if you see an improvement without the clutch stop. I remembered the car being the same way stock, but I'll have to test it back to back this summer with and without the clutch stop. Hopefully it isn't the clutch stops fault because I really hated the stock clutch throw and how long it was. |
11-30-2018, 06:16 AM | #14 |
Rep 1,237
Drives: M2 Competition
I have the BMS clutch stopp installed and use it with 1 of 3 washers. So far not the slightest issue, all gears go in smooth & fine.
But only 1875km so far...
11-30-2018, 01:32 PM | #15 |
Rep 7,418
I really didn't notice this as an issue either vs. stock but since people are reporting the exact same feeling 1-2 I've been having it's really concerning. I recall stock being the same notchiness as with the clutch stop but I'll test it out this summer.
12-03-2018, 09:36 PM | #16 | |
Rep 385
I experienced a couple notchy first gears like ppl have mentioned on here and that’s much better than the lockouts I was getting. I will keep you guys posted. Could just be a lucky 2 days. |
12-03-2018, 10:27 PM | #17 | |
Rep 7,418
I've enever had a lock out ever, just nothiness in 1-2 shifts. If I remove the clutch stop and the notchiness doesn't go away in a few days off driving the clutch stop is going right back in. |
12-03-2018, 11:50 PM | #18 |
Rep 3,402
If you're having problems with a car under warranty it always behooves you to take it in and get the problem resolved. Most are not having any problems at all so if you're having issues on a regular basis then the car is not performing as designed. No sense in living with it or trying to trouble shoot it yourself. Frankly you want this stuff addressed as early as possible so you can get as much time on the "fixed" car as possible before your warranty expires.
randyt224.50 |
12-04-2018, 01:42 AM | #19 | |
Rep 7,418
I've driven a few other F series n55 and m3/m4s with the 6mt and they all had notchiness in a few gears, so there's nothing I can do about that. I've experienced 0 cases of lockouts while up shifting or downshift (except into reverse while moving and into 1st above 20kmp/h which is normal), so there is pretty much no complaining from me except I want to check the clutch stop theory. Plus imo my local BMW dealer is full of incompetent service managers who can't get anything done. Well atleast the ones I've met anyways. |
12-04-2018, 08:32 AM | #21 |
Rep 1,016
I don't know if this is related but, on my old E36 M3 this happened a few times. Scared the crap out of me when it first happened. This was on an older car with over 80k miles, but it was the only manual car I owned that has done that.
I wonder if it's unique to BMW's design of their MT's. It seems pretty random and not serous but it is interesting. I thought it was happening because my car was old, and this is the first I've heard of it happening on any BMW besides mine, let alone a newer model like the M2. |
12-06-2018, 04:53 PM | #22 |
Rep 38
I've been having something similar happen with first gear once in a while. About 3 times now I've thought i was in first gear (pushing as forcefully as I normally do and feeling the shift arm move the same distance as normal) and as i let off the clutch it grinds before i have time to re-engage the clutch. After i put it back in neutral and move to first again it has a spot where it slightly gets hung up before it slides into gear. I'll probably go take it in to get checked when i get some time.
