M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rattles?
      09-12-2018, 05:03 PM   #155
akkando
akkando's Avatar
5863
Getting car back from 2nd free service today and I had them look into rattles. Here is what they wrote back about finding rattles.
"Rattle from armrest: we have confirmed it and we just needed to add some insulation to keep the plastic pieces from rubbing on bumpy roads or applying pressure, once that was done noise is gone
Rattle from passenger side door: confirmed it, applied washers to the Bowden cable in the door and now the noise is gone
Rattle from dashboard/rattle from rear view mirror: these actually ended up only being one rattle (although my tech and foreman did say it sounded like two at first), we had to go in an insulate the FZD switch to keep it from rubbing and once we did that there was no more noise from either area.
Rattle from drivers B-pillar: that actually was the Bowden cable in that door as well, we applied those washers and some insulation and the noise is gone"
      09-15-2018, 09:15 PM   #156
Maks///M2
Drives: 2017 M2
Originally Posted by 2M View Post
Mmm I have one coming from the speaker near the rear window
Had the same issue. Took it into Bmw.
The rear package tray has two plastic opening pieces for set belts. They need to put felt tape on the inside of the flap. Just like that have in the drivers belt buckle.
      09-15-2018, 09:17 PM   #157
Maks///M2
Drives: 2017 M2
My interior rattles so much. It's kind of annoying to drive it. Once I took the car apart. I found some clips were broken. But now that is not the case. Replaced broken clips and still have rattles. I might have to take it in. Because it's obnoxious driving
      12-01-2018, 11:52 AM   #158
mr_lab_rat
mr_lab_rat's Avatar
564
Drives: 2017 M2, 2018 X1
This is a good thread. I'll add mine.
There is rattling/buzzing noise coming from the rear, somewhere along the roof. The car vibrates around 3000RPMs (MPE) and that's what triggers it.
I'll take a look at the third brake light cover as someone mentioned but it sounds like it's coming from the roofliner light or inside of the roof (I have sunroof).
      12-14-2018, 05:17 PM   #159
MagnusT
MagnusT's Avatar
Sweden
538
Originally Posted by akkando View Post
...we had to go in an insulate the FZD switch to keep it from rubbing
FZD switch?
      12-14-2018, 05:22 PM   #160
akkando
akkando's Avatar
5863
FZD switch?
I dunno it's what they emailed me.
      12-16-2018, 12:02 AM   #161
GerardzM
Dang this is disheartening to read..for a BMW at that.
What mile are some of you guys at?
Really bad bumpy roads where you live?
I'll occasionally here the meth line slap underneath the rear seat but that's about it. 14.5k miles so far.
      12-21-2018, 03:12 PM   #162
MagnusT
MagnusT's Avatar
Sweden
538
I googled but came up empty on what that is...
      12-22-2018, 11:19 AM   #163
Downunder99
Downunder99's Avatar
Drives: 2018 BMW M2 | LBB | MT
2018 BMW M2  [0.00]
I had to have a nasty rattle fixed two times now by the dealership. Was located around the front driver door loudspeaker. First time they put some foam in and replaced some loudspeaker trim, second time they put more felt tape around the same area, after the rattle had returned. Was much more audible when cold, suspect was a cable, hardening up in cold weather, causing the rattle. Gone now ... this time for good I hope!
Oh, and the door seals make noise in cold weather when the frame twists slightly on uneven surface, same as in my previous Mini Coopers. Comes and goes, seems as if humidity in combination with temperature causes that. Keeping the seals and windows clean and treated seems to eliminate it to a great degree.
      12-23-2018, 12:28 PM   #164
Altra
Drives: 2016 AW M2
Had a rattle that was coming from my cluster gauge. Tightened the two torx screws under the cluster shroud and poof no more rattle.
      12-25-2018, 10:08 PM   #165
ES BMW
Drives: '12 E92 M3 ZCP 6MT
https://www.google.com/search?q=bmw+...hrome&ie=UTF-8
Looks like it's where the reading lights are.
      12-28-2018, 10:01 AM   #166
cadmunkey
Drives: F87 M2 LCI
Did anyone keep the photos from Albys post #81?
Sounds similar to the rattles I am having but can't see his photo solutions.
      12-29-2018, 07:16 AM   #167
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
No rattles here on my early build '17 M2. I'm at 22,000 miles and I live in the land of crap roads (NY).
      01-02-2019, 03:08 PM   #168
bmxcamel
bmxcamel's Avatar
Drives: F87 LCI, G01 m40i, E90 M3
I have a metallic/clicking rattle that sounds as though it's coming from inside the rear drivers seat door panel area, perhaps up near the B/C pillar area. Almost sounds like a cable or wire hitting bare metal. Anyone had this issue? Doesn't sound to be coming from the rear deck seat belt flaps.
      01-02-2019, 10:52 PM   #169
bmxcamel
bmxcamel's Avatar
Also, check out how my 2018 LCI came from the factory! Someone at bmw must have noticed this is a problem.
Appreciate 5
nioh_lbbm21716.50
trey1001125.00
boostm3683.00
AndrewC198910910.50
      01-21-2019, 09:58 PM   #170
Mark2016MG
Mark2016MG's Avatar
Drives: 2016 M2, 6 speed, Mineral Grey
Thank you bmxcamel for the picture of the foam insert on your anchor cover.
I tried the felt tape fix but the cover still rattled. I made a foam piece styled after your picture out of some camera case foam and it works perfectly.
bmxcamel552.50
      01-23-2019, 10:59 AM   #171
Happy Motoring
Happy Motoring's Avatar
Drives: OG M2
2017 BMW M2  [10.00]
I've got so many rattles with only 12k miles it's amazing.
Currently waiting for everything to fall apart and taking it in.
Anybody have experience with rattling from left rear seat?
      01-23-2019, 12:19 PM   #172
bmxcamel
bmxcamel's Avatar
Does the rattle in the left rear seat sound like stones/plastic hitting bare metal?
      01-23-2019, 12:26 PM   #173
Happy Motoring
Drives: OG M2
2017 BMW M2  [10.00]
It sounds like a fan hitting something as it's constant and sort of fast paced. It happens intermittently and after the car is at operating temperature. The shitty part is is that every time I take it to the dealer for issues like this I can't replicate it so they just send me home.
      01-23-2019, 03:10 PM   #174
boostm3
boostm3's Avatar
683
Drives: '18 LBB M2 6MT Exec
That seems to be very common with these rattles.. Mine has been , occasionally, in the rear passenger side area near the seat back, where that foam application was applied to the baby seat holder on the rear deck.. Ive got some rubber in there too.. but sometimes, around 3000 rpms, its there; mostly, its silent. I dont know if its temperature or humidity triggered, or the day of the week, or what, but its a real pain in the ass to deal with intermittent, but unpredictable noises.. Such is life.
Boostm3
'18 LBB MT M2 Exec pkg, Moonroof, Production 7/6/17
      01-24-2019, 09:48 AM   #175
KeepItlow
KeepItlow's Avatar
42
Drives: Car
No creaks or rattle on my MY18 M2 LCI and road here is pretty bad as well, hopefully the car stays quiet like this
      01-24-2019, 10:04 AM   #176
SConn
SConn's Avatar
I have to say, no rattles in my '18 lci so far either. It's got 8800 miles on it.
2018 LBB M2 LCI
