M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 5W40 on M2C
      10-27-2019, 11:49 AM   #1
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
5W40 on M2C
For my up coming 15K (DIY) oil change considering going 5W40 route. Debating between Shell euro or Motul 8100X. Any recommendations one over the other?
      10-27-2019, 04:22 PM   #2
Zugspitze
Zugspitze's Avatar
36
Drives: 2011 335d
If cost isn't a factor, then Redline 5W40. Otherwise, Pennzoil Platinum Euro 5W40.
https://www.redlineoil.com/Content/f...0_MO_PROD_INFO(1).pdf
      10-30-2019, 10:37 AM   #3
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
I used this oil in my last DIY oil change.
https://www.amazon.com/Pennzoil-5500.../dp/B00JMCCBRW
2011 BMW M3 Sedan Alpine White
Picked up via ED 9/27/2011 & Redelivered 11/23/2011 **SOLD**
      10-30-2019, 12:06 PM   #4
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
Just ordered it.
      10-31-2019, 01:21 AM   #5
chris719
Drives: '08 M Roadster
I would use any BMW LL-01 approved 0w-40 or 5w-40 and forget about it. It appears the Motul is LL-01 approved, so if you want to feel fancy I'd go with that.
      11-01-2019, 12:05 PM   #6
chmura
chmura's Avatar
1558
Pennzoil Platinum Euro 5W40 is LL-01 BMW approved also.
      11-04-2019, 10:31 AM   #7
CSL335i
Hungary
207
Drives: M2 and...
Another top oils in 5w40 viscosity class:
- Liqui Moly Molygen New Generation 5W40
- XADO 5W-40 Luxury Drive Black 5W40
- Shell Helix Ultra 5W40 (with PurePlus technology)
      11-04-2019, 09:06 PM   #8
Zugspitze
Zugspitze's Avatar
36
Drives: 2011 335d
NOACK is too high on Next Gen at 11%. Redline 5W40 is 6%.
https://pim.liqui-moly.de/pidoc/P001...40-41.0-us.pdf
      11-05-2019, 09:32 AM   #9
CSL335i
Hungary
207
Drives: M2 and...
Yes, you are right! if OPF is removed, than it should be ok!
      11-05-2019, 11:09 PM   #10
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
So you guys are not using your "free" maintenance from BMW? On all my BMWs, I have used the maintenance provided because the cars have always been driven less than 6K miles annually. When then maintenance runs out, I change the oil myself. I had been using Castrol 10W60 for my M5 and Z4M coupe (OE) but recently switched to Liqui-Moly 10W60 for both cars (S65 and S54 engines respectively) based on Mike Miller's recommendation. We'll see what my next Blackstone analysis reveals.
For the M2C, I plan on the same strategy. I will use the provided oil change yearly with 0W30 BMW/Shell and then decide which oil based on used oil analysis.
I love oil threads. They are legendary on M5board.com.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      11-06-2019, 01:33 AM   #11
chris719
Not sure about the LM, but I always used the original Castrol TWS Motorsport when I could because it shears down to something like a 40 pretty quickly. I always thought the 10W-60 was a panic move after the initial bearing failures on S54 and might not really be the best choice for street use.
I used to be into UOA but saw several examples of S65 engines spin a rod bearing even after several good Blackstone reports. Not saying they are useless, but I am definitely more skeptical of their diagnostic capability.
KevinM2935.50
      11-06-2019, 08:07 AM   #12
m20e3087
m20e3087's Avatar
Drives: G87
2019 BMW M2C  [0.00]
We are using the free maintenance oil changes every 10K miles, however it's my DD so mileage is adding up, so I DIY every 5K and let the dealer do the every 10K. On DIY I don't re-set the oil clock.
KevinM2935.50
      12-01-2019, 01:43 PM   #13
2PUTT
Drives: F87
Amsoil
5w40 (LL-01 rated)
these are LL-04 rated
      12-02-2019, 12:58 PM   #14
SEAT TIME RULES
SEAT TIME RULES's Avatar
1103
2020 BMW M2C  [5.00]
I bought 48 Qts of this on sale. Use it on my in between BMW 10k changes.
It worked out to $6 pr qt
2004 Mazda Rev It Up Finalist
2002-Present HPDE Instructor
      12-03-2019, 03:48 PM   #15
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro SS 1LE
Here in Germany BMW recommends 0W-40 which is funny since it hardly ever gets colder than 15F in Stuttgart area. And here the oil change interval is crazy long too. 25k kilometers, or 15k miles, or 2 years.
2017 BMW M2 German Spec
6MT, Driver's Package
--> SOLD
2018 Camaro SS 1LE. Because race car!
"Redline a day keeps the mechanics away"
      12-24-2019, 02:21 AM   #16
widetyres
279
Drives: M3 E92 DCT, 2012
In the UK they are setting 20k miles (32k km) intervals - way too long to go without an oil change imo.
(edit: doh! this is with n55 m2 and see you have m2c)
And they recommend/insist on 0w30, which is super light for a performance car. Good to know that they use 0w40 in DE - I'll use it when I diy change.
      12-25-2019, 02:37 PM   #17
Saintjah
Drives: M2C
Motul Xcess 5w-40 here.... just a change at 2500 miles and running a UOA to see how its playing so far. It did have a fuel smell to it so waiting on what the lab says
      12-29-2019, 12:17 PM   #18
AlpsRider
AlpsRider's Avatar
2865
Apparently the Pennzoil Platinum Euro 5-40, the Premium oil that Shell recommended for BMW might be discontinued. I was able to get some at $4. per quart. Get them while you can!
The new recommendation is Platinum Euro 0-40.
m20e30871150.00
      12-30-2019, 01:22 PM   #19
chmura
chmura's Avatar
1558
Where did you purchase at?
I can see that Amazon no longer has it.
      12-31-2019, 11:13 AM   #20
AlpsRider
AlpsRider's Avatar
2865
As has been stated in another thread, the Platinum Euro 0W-40 is LL-04 rated and not LL-01.
      01-08-2020, 11:14 AM   #21
Megator
Megator's Avatar
518
What oil have you bought? want to change mine some time soon. I was just going to order the BMW oil even though it is prob more expensive than it needs to be.
      01-15-2020, 06:38 PM   #22
AlpsRider
AlpsRider's Avatar
2865
The Pennzoil Platinum Euro Full Synthetic 5W-40 Motor Oil which is BMW-LL-01 is back for now. $50.77 for 6.
https://www.amazon.com/Pennzoil-Plat...9134671&sr=8-6
m20e30871150.00
