10-08-2019, 11:12 PM | #46 | |
Rep 2,577
You seemed to not get the changes with V5.8. Re-download the map and log again.
Lemania 2320
10-09-2019, 12:03 AM | #47 |
Rep 3,695
The drivability and top end of Stg 2 5.8 is so much better than 5.7 that I’ve opted to run OTS Stg 2 93 & E30 5.8 vs my Stg 2H 5.7 maps that had a little more peak power.
Would be great if we could select which turbo we had in the map configs and it would up the boost accordingly, but I know that’s getting into custom tune territory. |
10-09-2019, 10:35 AM | #48 | |
756
Rep 2,149
10-12-2019, 10:26 AM | #49 |
Rep 4,130
11-26-2019, 11:06 AM | #51 |
756
Rep 2,149
Yellowflash21369.50 AmuroRay2266.00 |
11-26-2019, 11:57 AM | #52 |
Rep 67
11-26-2019, 04:46 PM | #53 | |
Rep 78
43.5lb/min. just curious, thanks |
12-21-2019, 12:19 AM | #55 |
Rep 677
If possible could someone please cast their eye over the attached logs? N55 Stage 2 E30. Ambient temp was 32c (90f) in the middle of the day, so hot intake temps off a scorching surface.
HPFP seems to be feeling it, but I'm not sure if that's normal of should be of concern. Timing seems very different to the 93 tune (albeit my log with 93 was completd in about 15 degrees Celsius) but consistent across cylinders so I'm not sure if that's of concern. Thank you heaps in advance!! http://www.bootmod3.net/log?id=5dfd94a8c090c613428e2365 http://www.bootmod3.net/log?id=5dfd9434c090c613428e2364 |
12-21-2019, 09:18 AM | #56 | |
756
Rep 2,149
12-22-2019, 01:32 AM | #57 | |
Rep 2,577
Have fun!
Lemania 2320
12-22-2019, 02:25 AM | #58 | ||
Rep 844
12-22-2019, 06:29 PM | #59 | |
Rep 2,577
As for burble, the adjustment bar has been a hit and miss. It'd be cautious playing with it.
Lemania 2320
12-22-2019, 11:35 PM | #61 | ||
Rep 844
A buddy of mine with F80 M3 confirms that for his car too. |
12-23-2019, 10:41 AM | #62 |
Rep 361
I getting ready to bump from STG1 93 to STG2 93. Can I flash it and immediately log or should I let the DME adapt? 3rd gear from 2k-redline? Sorry I’m such a novice.
12-23-2019, 08:11 PM | #63 | |
Rep 2,577
4th gear is more indicative than lower gears, especially at top end because the boost behavior is a bit different there. Also the engine will be stressed more holding high load for longer. These days, logging BM3 OTS is really testing the octane. My observation is that the V5.8 gets more changes (for the good) than a lowered boost target. But my purpose for reviewing datalog is to know how far the V5.8 pushes with cool ambient temp when boost cap is much less of a limit to the torque.
Lemania 2320
Rock Sweden268.00 |
01-09-2020, 04:15 PM | #66 | |
756
Rep 2,149
Ambient ~26F http://www.bootmod3.net/log?id=5e179de4c090c660d027d6a2 http://www.bootmod3.net/log?id=5e179d34c090c660d027d69b My observations: Seems my HPFP isn't hitting target now, was fine in summer Coolant temp is 20+ degrees hotter than summer Timing is a bit more stable across cylinders compared to summer MAF lb/min is higher compared to summer. So making quite a bit more power. I think 20-50hp more if we assume 1lb/min=10hp Last edited by Anthony1s; 01-09-2020 at 04:44 PM.. |
