M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Rattles?
      04-02-2020, 07:01 PM   #221
bmxcamel
bmxcamel's Avatar
Drives: F87 LCI, G01 m40i, E90 M3
Originally Posted by bmwv View Post
Originally Posted by PackPride85 View Post
Good info. Would like to see one for the rear deck rattle...another popular noise.
I had 2 rear deck rattles. One from the plastic covers and really difficult to find from this plastic wire harness attached to the body on the right side of the car behind this vertical side part of the backseat close to the c pillar.
Been trying to fix the second issue you mentioned since I bought the car. Any photos?
      04-02-2020, 07:53 PM   #222
bmwv
Drives: 325i Manual, M2 LBB DCT
2017 BMW M2  [0.00]
2006 BMW 325i  [0.00]
No but basically u reach on top of that vertical soft thing and there is something u can push to release It.https://www.newtis.info/tisv2/a/en/f...ity/1VnXdK8HIJ
When u remove it and take some pictures i can point u to the part that rattles. It this plastic with a few wires somewhere up there. It has been a year since i did that. Sorry i dont have better instructions.
bmxcamel554.00
      04-07-2020, 08:05 AM   #223
Fedorov
Fedorov's Avatar
162
Drives: BMW 330i G20
Originally Posted by heavyD^2 View Post
I have had one rattle. For the longest time I thought it was coming from the passenger door panel but I realized anytime I had a passenger in the car there was no rattle so it's something to do with the passenger seat. It hasn't been bad enough for me to track down but I'll probably look into it closer in the spring as I think it's something either under the seat or on the plastic on the side of the seat.
Did you figure it out? What was it if so..?
      04-07-2020, 01:41 PM   #224
squixs
Germany
109
Drives: BMW M2 Competition
Curious as well
      04-08-2020, 08:18 AM   #225
heavyD^2
heavyD^2's Avatar
3689
Drives: X3M Competition
Hey fellas. I'm already out of the M2 and into an X3MC. I think that may have been more of a cold weather rattle as it did go away.
Fedorov162.00
      04-15-2020, 07:42 PM   #226
jessetaylor1
Drives: 2018 AW LCI
Got what I believe is one of the rattles that have been irritating me forever. It sounded like loose plastic rattling around when going over rough bumps. This is the bottom of the driver side A Pillar.
Wrapped the contact area with some felt tape laying around from BMW. Let's see if this fixes it. I think it will.
The sound was very pronounced when I was moving it around and tapping the wires against the metal.
bmwv107.50
      04-16-2020, 02:42 AM   #227
squixs
Germany
109
Please report back if it has helped
      04-16-2020, 11:27 AM   #228
jessetaylor1
Drives: 2018 AW LCI
The felt tape helped about 90%. Gonna go back in and add some more tape of some kind.
There is also a rattle in the driver side door that's bothering me, so expecting the same type of issue once I take off the door trim.
bmwv107.50
      04-19-2020, 05:00 AM   #229
bmwv
2017 BMW M2  [0.00]
i have also some noise coming from this area. Pleases let me know if u find something.
      04-25-2020, 12:10 PM   #230
nexusonemeover
nexusonemeover's Avatar
Drives: MY20 F87 LBB 6mt
By no means a car known for its fit and finish; the BSRs are driving me nuts. Just 700 miles and I seem to find a new noise each time I drive it. Body creaking, seat noises, door rattles... came from an F30 that was built like a tank. This, Lincoln logs?
2020 M2C 6mt ** 2019 X3 ** 2017 340i 6mt - retired ** 2016 Cayman S 6mt - retired ** 2015 Porsche Macan Turbo - retired ** 2013 X1 xDrive 28i - retired ** 2012 328i 6mt - retired
      04-25-2020, 01:16 PM   #231
2nd chance
Belgium
64
Drives: 2018 M2 LCI
Weird... Driver window down and only when turning right (LHD), I hear a very annoying rattle coming from the (left) rear.
Sounds like some "heat insulation" with a little pebble stuck in-between the sheet or loose sheet (@ the wheel? Exhaust?).
What the hell is this... Dealer closed so where do I start looking?
      04-25-2020, 03:20 PM   #232
TrentMeister
TrentMeister's Avatar
2860
Drives: g82 comp
Today I disassembled my center console and found the rear a/c assembly sounds similar to bacon frying with even the lightest touch or movement.
Greased her up with silicon slapped her back together and VOILA!! Still noisy lol..
Upon further inspection I found that during driving the passenger seat shifts from left to right about 1-2 mm causing the "creaky click" combo of sounds I deal with when the seat applies pressure to the center console lid.
So I reclined the seat and slid it all the way back and bam, just like that.. I can drive with the windows up in a noise free environment... for now.
At the end I of the day I know for certain that lubrication of the plastic on plastic clips made a dramatic difference.
Kind of annoying I can't just have my seats in normal positions but at least the interior is quiet now👍🏼
      04-29-2020, 12:27 PM   #233
jessetaylor1
Drives: 2018 AW LCI
This didn't fix the issue. It seems worse now. BMW built this car with thin plastic pieces inside everywhere I guess.
      04-29-2020, 11:52 PM   #234
m2rs4_official
I've been getting the odd " tin like " rattles since getting my car back from the dealers particularly around the left hand door and around the dash area.
PS: My vehicle is a RHD
Instagram: m2rs4_official
Proud owner of Amelia & Rae. Yes, I named my vehicles
2018 BMW M2 LCI (Wedge Performance Tuned + Pure Turbo Stg 2 Upgrade)
2019 Audi RS4 Advant
      04-30-2020, 12:29 AM   #235
MrOhnoez
Drives: '21 GLI, '79 beetle, '99 M3
I have one in my overhead rear dome light.
Drives me nuts. just a slight plastic buzzy sound.
      05-06-2020, 12:38 AM   #236
bmwv
2017 BMW M2  [0.00]
Same here very faint and intermittent. My wife says i am crazy.
      08-29-2020, 02:39 PM   #237
squixs
Germany
109
Does anyone of you have experience with rattles that appear to be coming from the rear light dome? It’s pretty loud around 2.5K RPM with MPE and Fabspeed cat
      08-29-2020, 02:45 PM   #238
fleetfoot
fleetfoot's Avatar
Drives: 2017 M2, 2013 E92 328i
Clean fix for rear deck latch covers
I just got a 2017 M2 and the only rattle I inherited is around the rear deck, which I'd notice during WOT above 3k rpm. With help from previous posts, I narrowed it down to the latch covers.
I tried a few different fixes, but using cabinet door foam bumpers ended up being a clean solution I can live with for the long term. I took one bumper, cut it in half, and then tried placing it in a few different spots. Pictured below is the optimal setup based on my testing. If you add more than one bumper, the latch won't stay shut. If you put it too far forward or back, the cover still vibrates.
2017 F87 M2: MGM, 6MT, AA Tune, Eibach Pro-Kit, Fabspeed Catted Downpipe, Evolution Racewerks FMIC+Chargepipe, Autosolutions SSK, CDV Delete, Vorshlag Plates, PFC-08 pads, Apex EC-7 18x9.5"
2013 E92 328i M-Sport: BSM, 6MT, 3IM+AA Tune, BMW PE, M3 control arms, Eibach Pro-Kit, Bilstein B8, BMW SSK, CDV Delete, Apex EC-7 18x9"
      01-10-2021, 06:02 AM   #239
Joshd63
Joshd63's Avatar
53
Drives: BMW 2015 F32 430d
For anyone that still has the high frequency wasp like noise when under say 2krpm Coming from the passenger seat think I have fixed it by putting two cable ties around the white ecu under the passenger seat. The rattle seemed to be coming from the ecu casing rattling with its insides so I just tied the cable ties around the whole unit to compress it ever so slightly and it seems to have fixed it
      01-15-2021, 07:55 AM   #240
MikeM2UK
Drives: BMW M2C 2019
The passenger side rattle i found was the join between the plastic panel that covers the AC filter and the bottom left plastic kick panel near the carpet. If you feel at the top of that panel you will find that it taps against the AC filter panel. Hope that explains it ok, I put some packaging foam behind the kick panel and cured it.
      01-21-2021, 10:16 PM   #241
8oldmarsh
Drives: 2017 BMW 330i
330i weird warning signal after mobile phone charge
Dear all, my 2017 330i recently has some weird things happened to her ... when I charge my mobile phone I got warning saying the “front high beam light malfunction” and “SOS calls disabled”. When I parked the car and shut the power down, I heard thumping noise like heartbeat, the noise went away after a few minutes. The next morning when I started the car all is normal, but when I starting plug my mobile phone charge via USB port, the same warning signals come back in a few minutes. It is so weird and wonder why? I took the car to a local BMW repair shop, they could not find anything wrong with the electrical system. Does anyone here experience similar thing? Otherwise the car runs great . I only put 32K on it. Thanks a lot. George
      02-06-2021, 06:38 PM   #242
biggripper
biggripper's Avatar
725
Drives: 2024 G80 M3 Comp xDrive
Originally Posted by jmh600cbr View Post
just started getting a rattle in the back seat at about 8000km it only happens when i go over a bump, super annoying. I tried putting the seats down and it didn't fix it. I'm going to have to take her in.
This sounds like what I'm experiencing. Any luck fixing it?
CURRENT///G80 M3CX | Isle Of Man Green | Kyalami Orange | Bi-Color 826M Wheels
FORMER ///F80 M3 ZCP | Yas Marina Blue | Black | DCT | Black 666M Wheels
FORMER ///F87 M2C | Alpine White/Orange | DCT | Black 788M Wheels
FORMER ///F87 M2C | Sunset Orange/Orange | 6MT | Black 788M Wheels
FORMER ///F82 M4 | SSII | Full SO | 6MT | Black 437M Wheels
