M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > Right turn signal malfunction
      01-15-2022, 06:35 PM   #1
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.68]
I see that the administrators closed my old right turn signal malfunction thread.
So I guess I need to start a new one.
Two years after I thought my dealer had fix this problem, I just started to get the dreaded right turn signal malfunction message.
I go to the dealer in a little over a week. I guess we will see what they do this time. Good timing though. My warranty is up at the end of this month.
      01-15-2022, 08:30 PM   #2
Sundinisagod
Drives: 2018 BMW M2
Yeah this is the only thing I’ve had go wrong with mine. It was repaired last June, I think the whole rear tail light assembly replaced.
DanG10660.50
      01-16-2022, 02:01 AM   #3
zellatc
Drives: M2 LCI
If it helps, I had the same issue with the rear left. I just dismounted the light, cleaned the contacts thoroughly and so far so good (since 6 months)
Appreciate 6
DanG10660.50
W///7494.00
///MPhatic13862.50
///M TOWN16539.00
qnet681.50
      01-16-2022, 08:18 AM   #4
Al Bundy's Dodge
Drives: 2018 M2 6MT
Had same issue with both of mine with in the last 12-18 months, and had both housings replaced under warranty. No issues since.
But if it returns out of warranty I just plan to code out the bulb check using Bimmercode. I tested this for a bit before having my right side replaced and it worked without issue.
But also hoping that if it fails again it's within 2 years since there is a two year warranty on parts.
2009 328i xDrive 6MT (Retired and I miss her)
2015 335i xDrive 6MT (Retired and I dont miss her)
2018 M2 6MT (Never retiring)
DanG10660.50
      01-16-2022, 10:26 AM   #5
Tag
this is the way
Tag's Avatar
18151
Drives: N-1 starfighter
I wouldn't stress over this. Since this issue was already covered under warranty before and has come up again while still under warranty you are covered. The dealer should also cover it if it happens again outside of warranty as a good will repair, especially since it's a safety issue. If they don't talk to a manager, go to another dealership or call BMW NA and express your frustration.
DanG10660.50
      01-24-2022, 08:01 PM   #6
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Got service done today. They found 106 turn signal malfunctions. Replaced the right turn signal assembly.
Hopefully this will cure the problem.
      01-25-2022, 06:45 AM   #7
Fined
ghost user
243
Drives: M2 | 997 GTS
I had the same issue with the rear left once in 2019 and once in 2021. I did the old engineering standby.. gave it a good smack and it started working again. The fix, while it only lasted 1-1.5 year(s) each time took me literally one second so I'm ok with the effort involved.
///M TOWN16539.00
      01-25-2022, 07:36 AM   #8
///MPhatic
The Seeker
///MPhatic's Avatar
13863
Drives: OG M2 • Exige
So it's a contact issue? Corrosion or just condensation? Bad seal?
      01-25-2022, 09:02 AM   #9
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Inspection on my taillight showed no corrosion or connector problem. They had a back and forth discussion with BMWNA on trouble shooting and finally a solution. The solution was to replace the taillight. It took them all day to fix it through.
Since it is a new part I now have a two year warranty on the right taillight.
///MPhatic13862.50
BTP 446.00
qnet681.50
      01-25-2022, 09:18 AM   #10
///MPhatic
The Seeker
///MPhatic's Avatar
13863
They didn't try to fix mine at all, they just replaced it.
DanG10660.50
      01-25-2022, 10:08 PM   #11
JustAWhisper
Drives: 2003.5 M3, 2018 M2
There is a huge long thread about this on the technical forum.
I had my passenger taillight begin to throw errors about a year ago. I took it to the dealer and they tried to pretend that they couldn't see any errors and that it was probably a one time thing. I had to wait for it to go off again and then immediately drove to the dealership without touching my turn signal (*cue BMW driver jokes*). They ended up replacing the entire taillight under warranty. Hasn't had an issue since.
However, now my driver side taillight recently started giving me occasional errors. My warranty expires in March so I'll have to figure out how to convince the dealer to fix it before then.
In the technical thread, there have been a lot of discussions about root causes for people who don't want to spend $700 replacing a taillight out of warranty. Unfortunately, I don't think anyone has definitely identified the issue. As already mentioned, some folks found removing, cleaning, and replacing helped, while others have not had such luck. Someone figured out that disabling bulb monitoring with bimmercode prevents the errors, but at least one person has also caught their car on fire doing that, so I wouldn't recommend that.
It's a weird issue.
      01-26-2022, 07:16 AM   #12
DanG
DanG's Avatar
2018 BMW M2  [7.68]
It's a weird issue.
As I said earlier I am the one that started the long thread on right turn signal malfunction.
The wiring and connectors were fine on my taillight. But they did read 106 error messages. It is documented on my repair order.
BMWNA had them replace the taillight assembly.
      02-01-2022, 11:39 AM   #13
zellatc
Drives: M2 LCI
Hi, sorry I didn't reply earlier, I didn't check the mentions.
I did not see condensation/corrotion/burnts/rustiness. It happened during summer (wet area near the sea). I opened, cleaned all the contacts properly with circuit cleaner and so far, no issues.
Mine is an LCI, if it helps
///MPhatic13862.50
BTP 446.00
DanG10660.50
      02-04-2022, 11:28 AM   #14
steve457
Drives: 2019 M2C
I'm at the dealer currently having my '19 M2C rear lights replaced due to the malfunction, and my service advisor just told me that BMW extended the warranty on the rear units to 10 years. I'll see if I can get a screenshot of the notice he was reading later, but for those of you out of warranty it might be worth a try to check with your dealer.
Update: I just took a look at the service note and it doesn't actually say the tail light assembly warranty has been extended, but instead just mentions the taillight assembly side mounting tabs. So unlikely the entire assembly warranty has been extended.
      02-04-2022, 01:17 PM   #15
GoneIn4Secs
1287
Drives: BSM F87 LCI (DCT)
So you get a message in the cluster when this happens right?
      02-04-2022, 02:25 PM   #16
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Yes a message appears on the dash. The signal also does a quick flash.
      02-04-2022, 02:38 PM   #17
steve457
Drives: 2019 M2C
Correct. In addition the malfunction is stored in the computer so the dealer could just scan the car to see that the problem occurred. In my case, they found that the malfunction has been occurring for the past year on both the right and left sides, so they replaced both tail lights.
DanG10660.50
      02-07-2022, 01:54 PM   #18
Jackhammer909
can you provide a link to the old thread? I just bought a used M2 and would like to learn more about this issue.
It did happen for me once when I signaled, that the flasher was quick, like there was a burned out bulb, but when I tried the signal again, it was normal.
I'd like to read that thread for more info.
      02-07-2022, 02:25 PM   #19
DanG
DanG's Avatar
2018 BMW M2  [7.68]
Here you go: https://f87.bimmerpost.com/forums/sh...al+malfunction
      02-07-2022, 02:58 PM   #20
Jackhammer909
thanks.
      02-15-2022, 06:33 PM   #21
Fly M2
Fly M2's Avatar
24
Drives: 2018 BSM M2
I was not so fortunate. I had the same issue with both taillights right after the warranty expired. $500 each
DanG10660.50
      02-15-2022, 07:54 PM   #22
mikeyymonster
mikeyymonster's Avatar
Drives: 2021 M2C
Damn thats terrible
2021 M2C
2014 M235i
Instagram: @mikeyymonster
DanG10660.50
