02-05-2020, 06:46 PM | #45 |
Rep 7,422
There's also a stupid hole beneath the amp that goes to the fender well, and if you spray too much water in that area it'll pass through into the cabin. I plan to use hydro guard mesh for that area so it can still breath.
02-05-2020, 07:27 PM | #46 |
6632
Rep 4,145
Drives: '18 M2 6MT
02-05-2020, 09:12 PM | #47 |
Rep 7,422
02-06-2020, 01:10 AM | #48 |
Rep 426
Yeah, as previously said. There is that vent next to the amp which you can see on this picture, and there is some dried water stains. Additionally I taped it on the bottom part. It can get wet even without tinting work, just from water getting behind the wheel fender.
02-06-2020, 04:51 PM | #49 | |
6632
Rep 4,145
Drives: '18 M2 6MT
02-06-2020, 05:57 PM | #50 |
Rep 7,422
If the water makes it past the fender liner yes, do huge puddle of high pressure water.
02-06-2020, 06:37 PM | #52 |
Rep 7,422
02-06-2020, 11:22 PM | #53 |
Rep 7
I'd sure like to know. It was one of the reasons I went for an LCI instead of a competition M2. My thinking was that the N55 is more mass produced and less high strung, meaning less problems. Time will tell if I'm right...
Arregueti9.00 gandapanda55.50 |
02-07-2020, 01:29 AM | #54 |
Rep 7,422
Less issues (almost non-existent) with things like the crank hub that's for sure.
02-07-2020, 05:42 AM | #55 |
Rep 789
2017 with about 20K km (stored in winter). Zero issues so far. N55 seems bulletproof, and sounds fantastic. Just the strange habit of wearing out rear tires fairly fast.
I did notice the hard shift from 1 to 2 when powering through a left turn. Miss the occasional shift that way. Thought it was just me. |
02-08-2020, 12:06 PM | #57 |
844
Rep 1,962
02-08-2020, 03:02 PM | #58 | |
Rep 176
02-08-2020, 04:46 PM | #59 | ||
Rep 1,899
cptobvious2531.50 |
02-09-2020, 02:02 PM | #60 | |
Rep 447
Region and type of car determine if it's lucrative, LA is extremely competitive so it can be slim margins.
2020 M2 CS AW 6-spd
Previous M Cars: M2C, M2, F80 M3, E46 M3, Z3M Coupe, E36 M3...and some other fun rides. |
02-10-2020, 02:04 PM | #61 |
Rep 3,402
42,000 miles and 27 track days and not a single issue. Can't say that about my Cayman though.
VisualEcho6632.00 koastal375.50 |
02-10-2020, 03:51 PM | #62 |
6632
Rep 4,145
Drives: '18 M2 6MT
So, from this tiny sample, and one other thread we have:
Key not working properly - 1 Valve tick - 2 1-2 shift resistance - 1 IDrive issues - 3 Steering rack notchy - 1 Charge pipe crack - 1 And the right rear turn signal error that should get fixed under warranty - a whole damn bunch Amp issues from water - quite a few Looks like the IDrive is the weak link. |
03-10-2020, 11:10 PM | #63 | |
Rep 103
Is the valve tick fixed under warranty? Occasionally getting it myself, fairly light. Add the Valvetronic actuator and shaft issue- 3 including myself in this thread. Has anyone gotten this repaired under warranty if the dealer couldn't reproduce. Ive only seen it once or twice in a year of ownership. |
03-10-2020, 11:17 PM | #64 | |
Rep 7,422
Since you identified valve tick and valvetronic issues, i'm thinking the noise you're hearing for valve tick is actually the direct injectors which do make alot of noise (totally normal) or the hpfp. It has to be reproducible or you have to have video evidence. BMW is making it really hard for people to get major warranty work these days, with dealers having to submit PUMAs and supply alot of diagnostics and proof. It took my dealer a day or two to get into contact with bmw in germany before they could replace my key.
Killed by Death12395.00 |
03-11-2020, 08:32 AM | #65 | ||
Rep 103
03-11-2020, 09:28 AM | #66 | |
Rep 7,422
Good luck, I hope you're able to get it warrantied.
