M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > DIY: M Performance exhaust
      02-28-2018, 11:13 AM   #67
horsepower_and_hounds
Drives: BMW
Install done myself, everything torqued to spec and position marked. After 1800mi absolutely no movement with the clamp or piped...just tips rattle like crazy. Tips are torqued tight and set screws have loctite. They don't move either. It is a resonating vibration rattle so to speak. I might try moving the exhaust back some but still need room for rearward movement due to heat expansion
      02-28-2018, 12:03 PM   #68
Bee Pee
Bee Pee's Avatar
1779
Drives: AW M2 DCT
Have you tried cold start with tips off ?
I ask as heard from 2 MPE owners here in the uk that have cured their buzzy/rattly cold start by wrapping tape around exhaust tailpipes before re-installing the tips - all quiet ever since.
If you try yrs with tips off for a few days and it’s better then maybe their fix might work for you??
      02-28-2018, 02:48 PM   #69
Drives: BMW
Interesting...never crossed m mind
It is quite annoying but does not last long. If I din't think it led to my Titanium MPE cracking on the M4 then I would never think about it..... I am just always concerned it will lead to a failure
      02-28-2018, 04:06 PM   #70
subliminalaudio
subliminalaudio's Avatar
314
Can you share your impressions on the back reflectors ?
I'm debating on non painted vs glossy black
      02-28-2018, 07:38 PM   #71
Drives: BMW
I did the matte black slat.... the color matches the other lower grills on the front. Gloss black will look out of place
      03-01-2018, 06:58 PM   #72
look585
look585's Avatar
311
Drives: M2CS
2020 BMW M2 CS  [10.00]
Originally Posted by AGM2 View Post
That is good news I bought my MPE today from my local dealer, it’s coming next Friday, I asked the dealer to cut the stock resonator to add it in case I need it and they said no problem. I’ll keep it in case it’s a drone. They said this is the last version of the MPE and they fixed the drone and vibration from the first Version. We’ll see. Can’t wait.
http://babyclips.net/play-baby-clip-...cGO2TWXNM.html
I just gone mine today.
How do I know if I have last version?
Thank you.
      03-01-2018, 07:21 PM   #73
18EM2
Public Last Class
18EM2's Avatar
Drives: 2018 M2 DCT LBB
2018 BMW M2  [0.00]
Are the pipe diameters the same from stock to MPE? What is the OD?
      03-01-2018, 07:25 PM   #74
18EM2
Public Last Class
18EM2's Avatar
2018 BMW M2  [0.00]
I measured my MPE and what's left of my stock exhaust; main pipe is 3" then splits to 2".[/QUOTE]
I just saw this post so I have my answer.
      03-01-2018, 08:13 PM   #75
Drives: BMW
This is actually a better example of the updated interface. Same as the MPE on the F80/82, they just have two pipes
      03-01-2018, 08:27 PM   #76
look585
look585's Avatar
311
Drives: M2CS
Two pipes?
The one in the pic looks like mine.
Should I put on the existing resonator? I don't want drone.
What do you guys think?
      03-01-2018, 08:29 PM   #77
Drives: BMW
Originally Posted by look585 View Post
Two pipes?
The M3/M4 S55 MPE is a true dual exhaust but has the same interface pipe over pipe connection as ours
      03-01-2018, 08:32 PM   #78
look585
look585's Avatar
311
Drives: M2CS
OK got it now.
Sorry, I'm bit of an idiot. lol.
You think I should the stock resonator?
      03-01-2018, 09:10 PM   #79
AGM2
AGM2's Avatar
Drives: M2 LBB 17
OK got it now.
Get the Fabspeed DP , I got my DP on may last year went a got my car 9 miles on the odometer and I installed, cero issues dealer no problem
Yesterday after add the MPE Exhauston WOW I got a new car !!!! Sucks the drone at 3k rpm but I got my stock resonator...
best money torque sound this is a much better car
      03-01-2018, 09:11 PM   #80
AGM2
AGM2's Avatar
Drives: M2 LBB 17
OK got it now.
Drive the car with out the resonator is not bad well for me !!!
But keep the stock resonator in case
      03-02-2018, 07:09 AM   #81
AGM2
AGM2's Avatar
Drives: M2 LBB 17
OK got it now.
Here is my cold start movement 5 seconds flaps closed
How do a stick a video with the phone app!!
Bee Pee1779.00
      03-23-2018, 01:05 PM   #82
qnet
qnet's Avatar
Drives: 18 Jeep Wrangler, 18 M2 LBB
I couldn't help myself and just pulled the trigger on this exhaust.
      03-23-2018, 05:37 PM   #83
MR_M2
Drives: 2017 M2 6MT, 2022 X7 M50i
BMW M2  [0.00]
BMW X7 M50i  [0.00]
Good choice! Time to unleash the (new) beast.
qnet681.50
AGM2297.50
      04-02-2018, 09:33 PM   #84
qnet
qnet's Avatar
Installed exhaust over the weekend. it wasn't too tough of a job. The downloaded instructions I found, and this thread, definitely helped. Like m3Ruder, the hardest part for me was cutting the pipe, but I knew this coming in, having experience cutting my M235i exhaust. That material is thick and it takes awhile with the pipe cutters I've used before.
The MPE opening it also very tight fitting on the cut factory pipe, and it was tough getting the exhaust pushed on.
I really like the sound and it's different than what I expected. It's like the factory exhaust, just deeper and more burbly. I like that the normal-mode (sport-mode) is deeper and more aggressive than stock exhaust sport-mode. The flaps open/track-mode is really nice, but I try to avoid that mode in my neighborhood.
seis-speed2430.50
gily88.50
      12-13-2018, 09:36 AM   #85
williammm
Drives: BMW F80 M3 (2016)
Anyone here has the installation guide to share with me?
      07-23-2019, 05:15 AM   #86
dman1011
Drives: X1
Where abouts did you find the instrcutions? i wasnt able to see it on this thread?
      07-25-2019, 10:20 PM   #87
qnet
qnet's Avatar
It's been a while and I don't remember. I have to wait until I can get to my personnel computer to see if I bookmarked it.
      07-26-2019, 03:05 AM   #88
saam_99
hi guys, I am a new owner from Spain. I want ask you something:
I had a MPE installed, but always I turn off the car, I have to pulse the button installed in the trunk for activating remote controller bluetoot, so for me it is so irritating do is again again…
So anyone knows the way for having the exhaust flaps always open in track mode?? unplugged the flaps in the exhaust maybe??
can anyone help me?
thanks.
