M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      03-10-2017, 06:10 PM   #309
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Originally Posted by quikM2 View Post
Originally Posted by gmzanatta View Post
Not yet. I believe BimmerCode is working on Euro MDM, seatbelt chime and ID6 lite for the next update.
So if you want those items sooner rather than later how do you go about it in Canada? Have to order the cable and hire a coder to do it remotely? like a code my car type of service?
You could learn to do it yourself ...that's what I was going to do until I found out about BimmerCode.
Pm me if you want instructions for coding using E-Sys (also found elsewhere on this forum btw)
      03-10-2017, 09:39 PM   #310
jtfields
Drives: M2, X2 M35i, X6,328i,230i
Originally Posted by Em-too View Post
@BimmerCode any chance we could get this feature added to a future release?
M2 Coding - Easy Seat Entry http://f87.bimmerpost.com/forums/sho....php?t=1362147
This is pretty cool. I actually often have the kids in the back seat so I probably wouldn't code it but I can certainly see why many would.
Em-too279.50
      03-10-2017, 11:22 PM   #311
oscarin
It is possible to codify that when the alarm is connected or disconnected, it emits a beep, not because it does not come from the factory.
And the traffic signal recognition? I understood that it could be done by coding, I have a driving assistant in my car.
Thanks
      03-11-2017, 08:49 AM   #312
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Thanks
If you mean having the cars horn beep (or not) with alarm/lock engagement/disengagement, that can be done via idrive under vehicle settings. You may also be able to do it this way (although I have not tried it):
1. Press both the lock and unlock buttons on your remote for two seconds.
2. Watch for the hazard lights to flash three times.
3. Lock the doors and confirm that the horn does not sound.
4. If you want to reactivate the beep feature:
5. Press and hold both the lock and unlock buttons on the remote for at least two seconds.
6. Watch for the hazard lights to flash once. The horn should honk one time.
      03-11-2017, 12:44 PM   #313
oscarin
Thanks, I just tried the command and it does not work in my M2, in the idrive menu I do not have that option, the car is from January 2017.
      03-11-2017, 01:12 PM   #314
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Sorry, thought I read you could do through Idrive
On bimmercode, expert mode, you could try (have not done myself)-
FEM Body 3040
- CLM_HORN_AT_SECURING
Btw what is traffic signal recognition?
      03-11-2017, 01:52 PM   #315
oscarin
FEM Body 3040
Thank you!!!!!
I will try with the application, the signal recognition is an extra that indicates on the board the limitations of speed and prohibitions that the camera of the mirror is reading.
      03-11-2017, 03:51 PM   #316
BimmerSpain
BimmerSpain's Avatar
Spain
82
Drives: Coming Soon Bmw M2
Any suggestion to activate the enhaced bluetooth in expert mode??
Thanks!
      03-11-2017, 04:06 PM   #317
PiK
PiK's Avatar
Poland
61
Drives: M2 6MT
Enhanced bluetooth coding: http://f87.bimmerpost.com/forums/sho...&postcount=250
      03-11-2017, 05:13 PM   #318
BimmerSpain
Spain
82
Originally Posted by PiK View Post
Thanks,i try but i have the NBT evo and any command dont appear...
      03-12-2017, 04:16 AM   #319
BimmerCode
Drives: G31 520d
I added the following "quick coding" options:
- voltage monitoring (FEM and REM)
- seat heating temperatures (FEM)
- rain light sensor sensibility (FEM)
More is coming soon and I will also look into the seat codings @Em-too mentioned.
The HMI_VERSION function in the NBT is available in expert mode, but the ID6 coding value seems to be missing. I will fix this asap and maybe add this as a "quick coding" option.
Edit: The function is named HMI_ID_VERSION and not HMI_VERSION and this is accessible in expert mode.
Otherwise I am working on the ACSM module for the seatbelt stuff.
Appreciate 4
Em-too279.50
Alee9220.50
DCM278.00
Dabozo624.50
      03-12-2017, 01:43 PM   #320
CanadianDriver
Drives: P3D-
For users wanting to control the exhaust flap (and ASD) with an app, BimmerCode has another app that does that, based on the app's description: https://itunes.apple.com/gb/app/bimm...065360416?mt=8
REMOTELY CONTROL EXHAUST FLAP
BimmerLink also allows you to remotely control the electronically controlled exhaust flap of your car. Decide for yourself, whether the exhaust flap should be closed or open which affects the sound of your car.
ACTIVE SOUND DESIGN MUTE
If you do not like the artificially produced engine sound generated in your BMW, just mute the ASD with BimmerLink.
      03-12-2017, 04:22 PM   #321
emargul
emargul's Avatar
Drives: M3
When you get a chance, can you add the ID6 as a quick code option. I'm not advanced enough for expert mode haha. Thanks!
      03-14-2017, 02:05 AM   #322
BimmerCode
Drives: G31 520d
I will add this for the next update
emargul204.50
      03-14-2017, 06:35 AM   #323
emargul
emargul's Avatar
Drives: M3
Thank you!
      03-14-2017, 09:09 AM   #324
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
Successfully coded my car this weekend with pretty much everything I set out to do.
Only snag I ran into (hopefully someone can help out):
After programming the comfort access to fold mirrors, no delay, etc., I seem to have lost comfort access on the passenger side. Driver side still works no problem. Any thoughts?
      03-14-2017, 09:14 AM   #325
6734202
Drives: MG 6MT
Anyone try Bimmerlink??
      03-14-2017, 10:23 AM   #326
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
what have you lost exactly? Door unlock ...?
      03-14-2017, 10:30 AM   #327
gmzanatta
gmzanatta's Avatar
1823
Comfort lock and unlock on passenger side only :
Driver works just fine. Also, question on comfort access: if I set key fob to active, does it disable the handles or adds fob in addition to the handles? I didn't have a chance to play around with this.
PiK61.00
      03-14-2017, 11:11 AM   #328
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Maybe you have checked this already but under opitons, isnt there an option to set CA to unlock/lock ONLY the drivers door? (Sorry im away from my car...she's sleeping until this snow goes away!)
      03-14-2017, 11:13 AM   #329
gmzanatta
gmzanatta's Avatar
1823
Ahh good point...maybe it reset after the coding. I'll check after work.
Also, the mirrors don't fold when I close with the key fob...not that it bothers me much, but kind of weird. I tried the holding the button down trick and no luck.
      03-14-2017, 11:16 AM   #330
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I found that after coding, i lost the mirror tilt when reversing feature...this doesnt bug me much so ive not investigated why...
G3N3VA0.00
