04-05-2019, 07:11 PM | #1 |
1287
Rep 1,675
Recommended tire pressure ?
Spoke to the wheels guy at the dealer today, and he said i should keep the tire pressure to about 4 psi less than the max thats listed on the tires
I have 763m wheels w pilot sport cup 2, what should i keep the pressure at? You non Canadian ppl are lucky, my tpms is worthless, doesnt even show any numbers or temperature reading |
04-05-2019, 07:34 PM | #2 |
Rep 2,700
I plan on buying Cup 2 also when my PSS are worn and I was thinking of runnin them at the normal 35psi pressure on the street and letting them heat up to 37-38 at the track and see from there.
The lower your going to run them the more confortable they will be. I think its depends what your after. I was also upset at first about the canadian speed sensor tpms but afterwards I got over it because a lot a ppl can't change mode and get stuck in comfort at the track because of the pressure variation and we don't have this problem.
04-05-2019, 07:38 PM | #4 |
Rep 2,700
Physical TPMS sensors are only mandatory in the US, our pressure monitoring system is based on the abs sensors and simpler.
04-05-2019, 07:45 PM | #5 |
756
Rep 2,149
04-05-2019, 07:50 PM | #6 | |
1287
Rep 1,675
04-05-2019, 07:51 PM | #7 | |
Rep 1,899
NEVER inflate your tires to anywhere NEAR the MAX psi listed on the tire itself. That is the MAX pressure that can be exerted on the tire from road imperfections, bumps, etc. The normal operating PSI is listed on the door jam on the driver side. 35PSI on cold tires. the owners manual has a different psi for higher speeds |
04-05-2019, 08:08 PM | #8 | |
Rep 3,843
04-05-2019, 09:16 PM | #9 | ||
Rep 4,341
04-05-2019, 09:20 PM | #10 |
Rep 6,937
Drives: 2018 M2 AW DCT
The recommend tire pressure for road use is 35 psi all around on cold tires.
You need to be a little careful. If some of the car has been sitting in the sun, the tires exposed to the sun will read higher than those on the other side. |
04-05-2019, 10:31 PM | #11 |
Rep 7,438
I heard it requires new modules which costs a crap load of money to retrofit. I'll do some more digging because this would be so handy on the track to just look at a live feed from the sensors instead of manually checking each tire. Then all I would have to do is measure tire surface temps with an IR cam for camber adjustments.
04-05-2019, 11:02 PM | #12 | |
Luxury at the redline :)
9105
Rep 7,563
They no longer utilize the ineffective ABS algorithm form of measurement, as before. All 2018+ Canada spec vehicles just needs to be coded to include the temperature, as it is decoded, standard, for some strange reason.. Enabled TPMS on Canadian Car (2018 F30) https://f30.bimmerpost.com/forums/sh....php?t=1575298 |
04-05-2019, 11:13 PM | #13 | |
Rep 7,438
04-06-2019, 04:52 AM | #14 |
Rep 2,577
I do 30psi cold (10+C or 50F+F shown by TPMS), 5 psi lower than bmw recommend. Want to do even a tad lower TBH, as it is getting warmer everyday.
Keep in mind, TPMS always reads some 2psi lower than physical gauge. Meaning real pressure should be about 32psi cold in my case when TPMS says 30. Also, you need to lower tp especially when upgrading to wider and shorter tire, in order to offset the greater stiffness - a key but very often neglected factor to grip. There is no wheel damage concern whatsoever from using a lower TP. The vertical deformation difference (easy maths) is too little to be noticeable. MPG wouldn't suffer much if any either, because with our kind of car, MPG primarily depends on how you treat the pedal.
Lemania 2320
04-06-2019, 03:35 PM | #15 |
Rep 252
I'm in Canada, mine shows tire pressure and tire temperature.
2019 M2 Competition | LBB | Manual
2014 335i F30 xDrive MSport (bye) 1988 535i E28 (RIP) |
04-06-2019, 03:53 PM | #16 |
Rep 7,438
You have the M2C so it probably was updated to have TPMS, you can tell by your valve stem if it is metal(TPMS) or plastic/rubber (No tpms).
04-05-2021, 06:09 AM | #17 | |
Rep 73
Michelin recommend 37.725 PSI/ 2.6 Bar for the Cup 2s (specifically for the M2C) vs the 2.4 Bar for PSSs. So, I suspect 'it depends' on the rubber too and not quite so straightforward as just 'it's 35'? |
04-05-2021, 01:45 PM | #18 |
Rep 201
On the street I am running 35 front and 33 rear wit PSS.
2021 M2C, HS, 6MT, ZED, 763M w/spinners, AA single, AA axle back, Turner High Kick, Turner shifter support, M pedals, honeycomb reflector delete, BC Racing DS series
04-11-2021, 10:42 AM | #19 |
Rep 2,873
Manual shows 35/35 for M2C but 32/32 for M2CS, which probably means on the Cup 2's? This is for under 100mph, they up it to 41/42 (M2) and 41/41 (M2CS) for over 100mph. Pressures for track tires are usually a lot less than street tires; some of the Rcomps run best close to 30psi hot.
03-09-2023, 09:02 PM | #20 |
New BMW owner
326
Rep 843
I guess my CDN 2018 LCI also has no TMPS, it's rubber.
04-21-2023, 06:05 AM | #21 |
Rep 303
I run 32,32 with PSS, I always end up a few PSI less than 'recommended' for me tyre pressures are the same as damper settings part of the set up if you move away from non standard suspension. Plus dont forget they are catering for two or more very heavy people in cold weather at high speeds and better to be over inflated than under
