05-06-2023, 01:32 PM | #1 |
Rep 263
how to code direction
Hello, with ESYS who can tell me how to code the direction, I want to try that of the f87cs. What parameter I have to modify in the EPS module. THANKS
05-08-2023, 04:57 PM | #2 |
Rep 1,805
For what car?
05-08-2023, 11:37 PM | #4 |
Rep 858
Drives: F87 M2CS
If you want simplified coding and have no background with esys, I'd suggest you just use the ProTool app. It's very user friendly
MY18 F82 M4
Austin Yellow / Black / DCT / MPE |
chris7197334.00 |
05-09-2023, 07:55 AM | #5 |
Rep 1,805
M2C uses the M2CS setting... there's no difference.
N55 M2 uses a different one.
chris7197334.00 |
05-09-2023, 11:41 AM | #6 |
Rep 263
I discovered it after asking the question, there is still the F82 GTS option but I would have liked to have a lighter steering wheel especially for parking on the road but from what I have read the F82 GTS is even heavier than the m2c
05-09-2023, 06:56 PM | #7 |
Rep 1,805
F82 GTS setting had felt unnatural for me and the car felt like it always wanted to change lanes on the highway. It didn't feel safe so I went back to stock.
05-09-2023, 07:10 PM | #8 |
Rep 858
Drives: F87 M2CS
I used to run GTS steering on my f82 m4. It had significantly helped remove that dead center feeling. My stock m2cs steering honestly feels even better than the GTS but I think part of that also has to do with lighter wheels and CCBs. I haven't even bothered to try GTS steering on my CS as I think it's already the best of the 3 I've had so far (stock f82, f82 GTS coding and now my f87cs)
MY18 F82 M4
05-13-2023, 11:27 AM | #9 |
Rep 4,672
I've got the GTS steering on mine. I immediately noticed a little more road feedback in the wheel. Subtle, but it's there. This is in the sport steering setting. I haven't tried the other settings.
05-15-2023, 03:28 AM | #10 | |
Rep 7,429
This is my protool review, if you scroll down there will be instructions on how to code the EPS (Ctrl F EPS and you should find the link). The instructions are protool specific, but if you look at which ecu's I coded, it will transfer to esys because the coded ecus are the same, and protool does everything esys does.
