M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Engine Ticking/Knocking on Start-Up
      11-13-2019, 06:42 PM   #23
LAGWAGN
Drives: 2001 M Roadster, '24 BSM M2
The latest: The regional engineer recommended replacing all the lifters. They have removed the cams, but still need to diagnose if any other damage has been done to the internals. Hopefully there isn't any and we caught this before it became anything worse...
I'll post a final update once I have the car back.
'01 M Roadster, '24 BSM M2
      11-14-2019, 01:26 PM   #24
MPBK
Everyday I'm shuffling
Drives: '12 SG 135i DCT; '18 MG M2 DCT
This is sounding like a design flaw with the S55 engine.
      11-14-2019, 04:09 PM   #25
1mm2
Is this issue prevalent?
      11-16-2019, 04:04 PM   #26
1mm2
Originally Posted by GodfatherNiko View Post
I'll drive it til it blows up or trade it in earlier. We'll see.
I agree with this approach but it's unfortunate because I could see myself wanting to keep this one long term and modify it.
Not really worth it if it's a ticking time bomb (pardon the pun)...
      11-18-2019, 05:11 AM   #27
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
My first thought was a defective / sticky hydraulic valve clearance adjuster. Had a few of those in my time and they were always bad from cold then settled as they warmed.
It's definitely cam related as the sounds is too slow for crank at idle. (Cams run at half crank speed).
The S55 adjusters are shared with most of the BMW range, very common cheap part
https://www.realoem.com/bmw/enUS/par...&q=11337548690
Good luck, keep us informed
      11-19-2019, 02:02 PM   #28
Lazymccrazy
Drives: M140i
I have this exact same noise with a B58, so it makes sense its a troublesome common component. What a waste of money buying those injectors was!
      11-20-2019, 02:32 AM   #29
doughboy
doughboy's Avatar
1545
B58 doesn't share the adjusters with the S55 though...
But it does share them with several Rolls Royce models..
https://www.realoem.com/bmw/enUS/par...&q=11338679835
      11-24-2019, 01:22 PM   #30
LAGWAGN
Final update. doughboy Was spot on. Replacement of the alignment and decoupling elements resolving the ticking noise. I'm ultimately happy that the dealership went through all of the motions to make sure it was resolved (TSARA case opened). Sewell Grapevine BMW in Dallas did the repair, for those in the area. Really happy with their service and the knowledge of the service writer.
Getting back into the car after 3.5 weeks of an X4 was mind blowing. How these two cars come from the same company is hard to believe.
Question to the group: How comfortable would you be taking a car back that has had the top-end dismantled and put back together? I take some comfort that all moving parts looked good, e.g. no scoring on the bearings, but am a little unnerved that the engine has seen this level of maintenance at < 9k miles.
      11-24-2019, 06:43 PM   #31
1mm2
Is this issue prevalent with respect to the S55?
      11-25-2019, 02:14 AM   #32
doughboy
doughboy's Avatar
1545
I've not heard anything, and as the part in question is very common across the BMW range it would affect more than just the S55.
Just normal part failure rates I would think.
      11-25-2019, 04:52 AM   #33
Megator
Megator's Avatar
518
Drives: M2 Competition
I would ask for an extended warranty on these bits. But yeah they should have decent mechanics so I would not worry about it.
LAGWAGN272.00
      11-27-2019, 12:05 PM   #34
cookiesowns
cookiesowns's Avatar
587
What build date is your car... really wondering if I should take it in now.
      11-27-2019, 04:51 PM   #35
LAGWAGN
What's the best way to determine build date?
      11-28-2019, 12:13 AM   #36
doughboy
doughboy's Avatar
1545
Look on the build date label in the engine bay!
      11-29-2019, 05:44 PM   #37
cookiesowns
587
use mdecoder.com and type in your last 7 VIN. Prod date should then show up
      12-01-2019, 06:21 PM   #38
LAGWAGN
That's in the back, right!?
Production was 7-16-18.
      12-01-2019, 09:44 PM   #39
cookiesowns
587
An earlier build... hrmmmm
      12-02-2019, 05:43 AM   #40
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I have a 7-31-2018 build and it's fine. Don't forget that the M2C build date is irrelevant since the S55 is used in the M3/M4. They didn't just start building these engines.
www.ReTuneTheDeTune.com
      12-02-2019, 10:22 AM   #41
LAGWAGN
This.
Here is a link to a similar issue with an S55 from an M4. I don't think this is necessarily a far flung issue that most owners need to be concerned about and it was relatively minor in what needed to be replaced. There was no damage or premature wear to internals as a result.
      12-06-2019, 05:23 AM   #42
doughboy
doughboy's Avatar
1545
3-4 weeks? I assume that's waiting for parts?
I wouldn't think it's value is diminished. For a start who will know except you?
It's just a minor mechanical repair, I wouldn't be concerned at all as long as the oil is confirmed clear.
Underneath all the modern electronics and auxiliary gubbins and plastic covers, IC engines are the same old lump of metal as they've been for years and suffer from the same mechanical probelms from time to time.
      12-07-2019, 05:13 PM   #43
LAGWAGN
I assume it's waiting for the parts as well the year nearing an end. They said they couldn't excluide further engine damage and will probably pull the motor apart before deciding what to do.
We'll see, I do have a Giulia QV test drive lined up soon.
If it’s indeed the same issue as what I had, I wouldn’t be concerned with engine damage. Mine showed no damage or premature wear with 9,000 miles on the clock.
While the work to correct is fairly intensive, the repair itself is minor. I look at it as I got a free comprehensive inspection with new seals.
      12-16-2019, 03:42 PM   #44
///Driver
///Driver's Avatar
60
Drives: M2C
Update: Car is back in my hands, all seems well. The camshafts weren't properly tightened from the factory, allowing for minimal play during cold starts, while the oil viscosity wasn't quite there yet. Everything is tight right now and there is no more knocking noise on cold starts.
Glad to hear, Niko. Enjoy your new, quieter car.
