12-08-2018, 10:46 PM | #265 |
Rep 186
Had a busy day! Gave her a bath, then did some more work on the fibreglass sub box (will post dedicated thread when finished) and finally ordered my Active Autowerke mid pipe
12-09-2018, 01:16 AM | #267 | |
Rep 186
M-Pilot4859.00 |
12-09-2018, 01:31 AM | #268 |
Rep 466
Same as the last comment photos that didn't work posting last time
12-09-2018, 03:00 AM | #269 |
Rep 1,477
12-09-2018, 12:38 PM | #270 |
Rep 22
Big thanks to Doughboy and akkando. Got my M Performance carbon steering wheel trim fitted today. It took 20 minutes as advised but would have been impossible without their help. Its not remotely intuitive that you have to push a screwdriver into a hole behind the wheel boss to release the airbag. Im not going to post a photo as it looks just the same Doughboys, i.e. fab.
I disconnected the battery negative first as suggested and it didnt trigger a tracker alert. Not sure whether to be pleased or concerned! Its the BMW recommended Trackstar Cat 6 BTW. |
12-09-2018, 01:42 PM | #271 |
Rep 120
Yes
'19 BMW M2 Competition | BSM | DCT | Exec Pack | GC Camber Plates | Acexxon Reflectors | Pagid RS29 | Castrol SRF | 788m MP4S | 437m AD08R
12-09-2018, 02:29 PM | #273 | |
Rep 8,970
Glad you're pleased with the mod. Re battery disconnect. You only ever need to disconnect the negative. Don't touch the positive, its completely safe once the neg is removed. |
12-09-2018, 02:54 PM | #274 |
Rep 120
Aliexpress ... Seriously! they are pretty good quality too i was pleasantly surprised. Installed they feel and look like an OEM part.
12-11-2018, 03:25 PM | #275 |
Rep 8,970
Coded 6NS enhanced bluetooth and smartphone integration.....
Its a £400 cost option in the UK. Works perfectly |
///M Houbi1655.00 |
12-12-2018, 07:44 AM | #277 | |||||
Rep 288
12-12-2018, 07:44 AM | #278 | |||
Rep 288
12-12-2018, 07:50 AM | #279 |
Rep 288
Full screen car play.
///M Houbi1655.00 |
12-12-2018, 08:50 AM | #280 |
Rep 456
I just received these aircraft grade aluminium paddle shifters in the post. All I need now is the car 😁
[IMG][/IMG]
2019 HS DCT M2 Competition with Essex AP Racing Radical Pro5000r front and rear BBKs, Bilstein B16s and 763M wheels with Cup 2s
///M Houbi1655.00 |
12-12-2018, 10:05 AM | #281 |
Rep 91
NY135ivishnu114.50 |
12-12-2018, 02:49 PM | #282 |
Rep 162
Bootmod3 CS+ tune
Swapped shifter, shifter plate and handbrake to Full dry carbon and alcantara Replaced stock sunvisors with alcantara ones from Bimmermasterpieces |
12-12-2018, 04:00 PM | #284 | |
Rep 162
You can clearly see where the glue was applied, the alcantara is not equally tight around all sections etc. I believe they claim it's made by hand and it shows. To be fair however, the edges are glued on the upper ridge, which you never see and in my opinion, it's still miles ahead of the hard, plasticy regular sunvisors + no more warning labels so I'm happy enough. The actual swap was very easy to do (if you have the right torx screwdriver at least). Installed them in the driveway in the dark, so no picture. I'll try to do think about it tomorrow. |
12-12-2018, 04:06 PM | #285 |
Rep 8,970
Yeah i saw that tape seam on top. But coming from factory alcantara visors on my M6, you don't look at them in detail as they're all black/black you feel them when you touch them.
And as i have visors down all the time, then no airbag warning was a major plus for me. |
12-12-2018, 04:49 PM | #286 |
Rep 116
