M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Anyone painted/obscured the M2C exhaust muffler ?
      09-25-2018, 05:53 PM   #111
MR.
MR.'s Avatar
Originally Posted by Foyc55 View Post
Next mod
What am I looking at here?
Front mount intakes
That looks cool... Fitment OK?
I heard something was made slightly different to the M4 S55 set up by BMW.
MR
      09-25-2018, 06:19 PM   #112
Foyc55
Drives: HS M2 CS
Next mod
Front mount intakes
MR
I'll let you know tomorrow. It is not as cut and dry as it is on f80/82. Crossing my fingers!
96 318Ti with S52 turbo (11.1 @138), 03 E46 M3, 15 F80 M3 YMB, 17 C7 Z06, 19 M2 Comp
      09-25-2018, 08:44 PM   #113
hellrotm
4143
Drives: F80
Next mod
      09-25-2018, 09:13 PM   #114
DelGriffith
DelGriffith's Avatar
Drives: 2019 SO M2C
Next mod
The wallet and the wife are getting VERY nervous about the pending M2C!!! You guys make my home life very difficult...
'02 E39 M5-Gone
'07 E60 M5-Gone
'07 E64 M6 Cab-Gone
'17 F87 MG M2-Gone
'19 F87 SO M2C
///M Houbi1655.00
ChrisK4449.00
      10-16-2018, 03:57 PM   #115
E21-myfirstlove
Drives: F10 M5
What are people doing to hide the muffler outback? People have mentioned painting it with high temp paint. Has anyone done this? I assume it would require removing the exhaust to do it properly. Has anyone done it with the exhaust still on the car? Any pictures from anyone? Thanks
      10-16-2018, 03:59 PM   #116
mdejesus6513
Drives: M2 2019 LBB
Yeah. I'm really interested in this topic. What can we do to get rid of that eyesore of a muffler? Would the CF diffuser reduce its ugliness?
      10-16-2018, 04:25 PM   #117
COChris
COChris's Avatar
Drives: M2C
Straight pipes.
      10-16-2018, 07:46 PM   #118
E21-myfirstlove
Drives: F10 M5
The diffusers i have seen do not go that low.... if they did, that might look awkward in a different way. Will have to see the aftermarket options in a while, but a black exhaust would hide a lot
      10-16-2018, 07:52 PM   #119
FSU_Logan
Drives: 2019 M2C DCT
Most of the aftermarket options do block it a bit more than stock... but not nearly enough. Painting it seems to be the only option.
2019 M2C DCT | Alpine White
Full AA exhaust (catless DP/signature exhaust) | M Performance Coilovers | Need to find some new wheels!
      10-16-2018, 08:10 PM   #120
devo
Drives: Bimmers & Porsches
Painting is fine, just be prepared to repaint frequently; or straight pipes ^
'19 M2C HS, 6-Spd, Slick Top, MComp Wheels
'18 GT3 White, 6-Spd, Buckets, PCCBs
      10-16-2018, 08:37 PM   #121
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
How safe are these paints? The exhaust gets really hot especially on track days. For example, certain parts of the titanium MPE muffler on my M4 turned blue after a few track days due to the heat. VHT Flameproof paint is rated up to 2000 F but I still want to make sure painting the muffler is safe. Last thing I want on the street or on a track day is the paint to catch fire. Again, I wouldn't care if the paint fades away or peels of with the excessive heat but is it safe or is there any chance of fire by any means?
The pic below isn't from my M4 MPE and mine wasn't nearly as bad but posting it just to give an idea how hot these exhausts can get under extreme circumstances (I assume this is after many track days):
Poochie9104.50
CSBM52722.50
      10-16-2018, 09:13 PM   #122
warrenw
Food Critic
warrenw's Avatar
South Korea
1086
Drives: 19 AW M2C, 21 M340i
I reeeeeeeeally want to paint mine.... But I'd need to rent a lift.
      10-16-2018, 09:14 PM   #123
Davil
Davil's Avatar
6525
Ha. It’s painted itself in M colours.
I’m going to polish mine so it is nice and shiny.
COChris888.50
      10-17-2018, 03:24 AM   #124
Alec02
Alec02's Avatar
Slovakia
85
Drives: M2C SO MT
What about Macota Tubo or Motip Heat Resistant - both up to 1472 Fahrenheits (800 Celsius)?
      10-17-2018, 03:45 AM   #125
chris719
Drives: '08 M Roadster
I think the surface needs to be prepared carefully if you want these high temperature coatings to last. Otherwise just be ready to re-spray every couple years.
      10-17-2018, 05:04 AM   #126
Alec02
Alec02's Avatar
Slovakia
85
Drives: M2C SO MT
Motip recommendations:
Before use, carefully read and observe the warning texts on the label!
Pre-treating surface:
Remove old loose paintwork and rust, then sand
Surface should be clean, dry and free of grease.
Do not prime! Best results when used on bare metal.
Painting:
Cover surface not to be treated with masking tape.
Shake can for 2 minutes before use.
Spray to test compatibility on an inconspicuous area.
Spray several thin layers at intervals of ca. 2 minutes.
Keep a spraying distance of 25-30 cm.
Perfect results can be achieved when the surrounding temperature is ca. 20°C.
No primer necessary. The best results will be achieved on bare metal!
Leave to dry for 1 hour.
Once dry, heat for 1 hour (160°C) so that the lacquer coat hardens.
The thinner the coat, the higher the heat resistance.
For more information use this link:
https://www.motipdupli.com/en/produc...9/tm-1369.html
cptobvious2531.50
      10-17-2018, 07:46 AM   #127
Cavpilot2k
Chief Warrant Officer
1025
Drives: like a damn lunatic
The 2000 degree paints should work fine.
That blue/purple coloring is indicative of temps still well under 1000 degrees.
2000 degrees is glowing bright orange hot, bordering on yellow hot, like out of a blacksmith's forge (well past even red-hot). If your exhaust gets that hot you have other problems, and likely are catching other things on fire.
"Prius" is Latin for Eunuch.
"Hrothgar": 2012 135i: 6MT M-Sport, BSM/Blk; Nav, Premium, Convenience, HK
Dinan Stage 2 +PPK /// BMW PE /// VRSF CP /// K&N /// Koni Sports /// RSFB Inserts /// MPS4S 225/255 /// Other Stuff
      10-17-2018, 10:32 AM   #128
OGM2C
OGM2C's Avatar
243
Drives: '19 M2C
Yep, using high temp satin black paint designed to be used on log burners.
awesome work I also have a bsm m2c and I think I'll give this a shot - would you mind taking a picture from a less flattering angle so I can see what's going on under there better? (1) low to the ground behind the vehicle (2) under the vehicle.
'19 BMW M2 Competition | BSM | DCT | Exec Pack | GC Camber Plates | Acexxon Reflectors | Pagid RS29 | Castrol SRF | 788m MP4S | 437m AD08R
M2C_PLUS1774.00
      10-17-2018, 10:42 AM   #129
COChris
COChris's Avatar
Drives: M2C
Guessing this one blew past 900 C
Cavpilot2k1025.00
      10-17-2018, 10:48 AM   #130
AlpsRider
AlpsRider's Avatar
2865
I read in a thread somewhere that a guy used a paint brush to apply the paint with good results. He didn't want over spray on his car. It's an interesting thought, I don'k know how well it would turn out though. Anyone try a paint brush application?
      10-17-2018, 02:25 PM   #131
Shekels
Drives: M2C HS Nov 2018
That’s what I’ll do if people who’ve done it can recommend a decent paint I can get from amazon uk or eu.
It doesn’t need to look perfect, just block out the visible bits.
      10-17-2018, 08:25 PM   #132
hellrotm
4143
Drives: F80
Not any hotter than headers. In the past I have used VHT Flameproof ceramic coating for headers on a muffler box. Never had any problem with discoloration or flaking paint.
M-Pilot4859.00
