06-11-2020, 11:19 AM | #47 | |
Rep 3,129
I assume the numbers you posted are the peak gains. We advertise/show +16whp/+50wtq for those specific data points. Other factors could be at play -- ambient temp, type of dyno, were the before/after run the same day/same dyno, adequate cooling used, etc. |
06-11-2020, 11:35 AM | #48 | |
1448
Rep 1,414
06-11-2020, 12:38 PM | #49 | |
1448
Rep 1,414
Baseline: Tuned: |
AmuroRay2282.50 |
06-11-2020, 12:42 PM | #50 |
Rep 2
I will be swapping my Dinantronics elite stage 1 for the Stage 1 flash tomorrow. Hope it's the right decision. Will keep you posted.
06-11-2020, 03:59 PM | #51 | |
Rep 3,129
Having 2 different dynos on 2 different days its hard to make a real accurate assessment of a before and after. For any real accuracy in a delta, same day/same dyno is the only way to go. One other note is that the pulls were run quite differently (starting at 2k versus 2.7k) which shifts peak RPM. May just be a difference in how each operator does pulls but it also may be indicative of running the car in different gears between stock and tuned as well. Regardless it makes a direct overlay really difficult. Still, if you just take the data on face value ignoring all the other stuff mentioned and just take the median pull for both (Stock=Green, Tuned=Red) you still get some respectable deltas even when you ignore the shift. Also, on the tuned run by itself it measures a max power of 361 WHP / 416 WTQ. We advertise 358 WHP / 416 WTQ. What did the butt dyno tell you in your limited ownership out of curiosity? |
243Racing1447.50 |
06-11-2020, 04:03 PM | #52 | |||||
1448
Rep 1,414
For me, since I'm trying to build a car to the limits of the series I'm running in, the horsepower just isn't enough. Even running full slicks, with my comp weight set impossibly low, I'd still need to be close to 380 to the wheels. The massive dropoff in the 2nd and 3rd runs scares me, too. On my baseline, with near identical ambient temps, that didn't happen. Further edit...sorry. I didn't post in this thread to complain - only to share information! Last edited by 243Racing; 06-11-2020 at 04:43 PM.. |
06-11-2020, 05:14 PM | #53 | |
Rep 3,129
The comparison to tuned peaks (yours versus advertised) taken on its own without any other data I find interesting is all in that it is damn near identical to reported. My statement about the deltas being consistent is true given good data. The delta in this case is immaterial as the data is flawed. I stand by the statement that if this was run on the same dyno, similar days , same gear / pull procedure you would see delta's much closer/same as advertised. This isn't to slam the information supplied just to point out that it is skewed is all and needs to be taken with a grain of salt. In terms of your series requirements -- If you want 380 to the wheels you need a quality intercooler at absolute minimum to shift the efficiency in your favor at the top end (and also assist in staving off heat soak), especially if you are only running 93. In our testing these are typically good for around 8-10whp on the platform. As a comparison, the stage 2 flash in development (Non-M2 N55) on 93 with the big turbo (stage 1) and intercooler is around 385whp at the peak but with a torque jump up to 445wtq. The M2 version may get slighly more than the non-M2 N55 but not by much. That’s all to say the peak numbers are really limited by fueling. |
243Racing1447.50 |
06-11-2020, 08:28 PM | #54 | |
Luxury at the redline :)
9105
Rep 7,563
Putting the numbers aside for a moment, do you feel or notice a discernible difference increased power? What does you butt dyno have to say? |
06-12-2020, 09:19 AM | #55 | ||
Rep 6,635
06-12-2020, 09:25 AM | #56 | |
1448
Rep 1,414
For a 'safe' street tune, I would recommend this - like I said my only concern was the rapid degradation on the successive runs. Cooling mods may help - but this tune is advertised for otherwise stock vehicles. |
Poochie9104.50 |
06-12-2020, 09:27 AM | #57 | ||
Rep 6,635
06-12-2020, 02:34 PM | #58 |
Rep 289
This is where I have a bit of an issue. If the car can only manage a single pull at these numbers, I’m not sure Dinan should be advertising their stage 1 as a flash tune only. An intercooler is clearly a necessary addition.
06-13-2020, 11:44 AM | #59 |
Rep 4,146
The car is already near it’s maximum potential on the stock catalyst. Similar stage 1 tunes on the M2 lose power because they can’t overcome the heat and back pressure closer to redline.
Someone asked about TMS - https://f30.bimmerpost.com/forums/sh...ghlight=Turner 350- 360whp is about the limit for pump gas stage one, and that’s likely not even consistently without at least an intercooler. If you plan to go beyond that, Dinan’s tune isn’t for you. |
Poochie9104.50 |
06-13-2020, 12:56 PM | #60 | |
1448
Rep 1,414
06-14-2020, 01:46 AM | #62 | |
9105
Rep 7,563
As they say, you can't get blood from a stone and at times of heavy, consistent loads, I feel my motor reaching its mechanical limits. So I know it's not bullcrap. Sure, you can just get another aftermarket tune that juice the shit out of the boost pressure, without much regard for all the OEM safeties and limitations, to make up for the hardware shortcomings, as BMW tends to do with all their 4 cylinder turbos but you're just reducing the longevity of the motor and putting more strain on the powertrain. It's a vicious and asinine compromise, IMHO. The Dinan S1 tune sounds like the software is maxing out as much as it can can safely squeeze out of the N55 motor. I mean, it doesn't cost them anything to just turn up the boost over a more reasoned safe flash but if they're also saying, in literal terms, that the motor is already running at its capacity, then there is only so much more a flash can eek out of the N55. So I guess this flash can be interpreted as peak but not consistent power. |
AmuroRay2282.50 |
06-14-2020, 02:08 AM | #63 |
16539
Rep 8,424
Agreed.
Can it be shipped to a dealer/reseller or do they need the car?
06-14-2020, 06:32 AM | #64 |
6637
Rep 4,145
Drives: '18 M2 6MT
06-14-2020, 09:15 AM | #66 |
Rep 1,153
I think it may be most accurate to say that it's the turbo and the HPFP. N55 engine internals can handle quite a bit more power.
