M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > NEW RELEASE: Dinan Performance Engine Software for the F87 M2 (N55)
      06-04-2020, 02:13 PM   #23
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Originally Posted by boostm3 View Post
Does the cost listed for the flashes include dealer labor for the install, or is that an additional fee?
That would be additional. Labor rates vary immensly across the globe and we can't dictate what a dealer would charge for their labor.
243Racing1447.50
      06-04-2020, 02:33 PM   #24
VisualEcho
VisualEcho's Avatar
Drives: '18 M2 6MT
2018 BMW M2  [10.00]
Dealer has to install?
No interest.
      06-04-2020, 04:52 PM   #25
JudasBeast
Drives: 2018 BMW M2
Can you (or should you) run the 93 octane flash if using an ethanol blend? For example, Husky premium 94? Thanks.
      06-04-2020, 05:10 PM   #26
Dinan_Engineering
Drives: Any BMW
Realistically you would want to run the 91 octane (AKI) mapping for Husky 94 (RON). In short stints its probably not going to really matter but over the long haul and the health of the motor stick to the 91 mapping.
      06-05-2020, 06:28 AM   #27
243Racing
1448
I have some custom coding for the MDM, Diff and EPS. Will this software overwrite that?
      06-05-2020, 07:18 AM   #28
Dinan_Engineering
Drives: Any BMW
Coding that is tied to other modules (MDM, ABS, Suspension, etc) will be unaffected with the engine software. So the ones you mentioned will be retained. The only time they would be lost would be with a full factory reflash/i-level update.
243Racing1447.50
      06-05-2020, 05:15 PM   #29
///M²
///M²'s Avatar
283
Drives: 2017 BMW M2 6MT
2017 BMW M2  [0.00]
FYI, we are AKI in Canada.
'17 BMW M2 LBB 6MT MPE
'13 BMW 335i Estoril Blue - sold
      06-05-2020, 05:16 PM   #30
243Racing
1448
Im getting this done next week, will share the results.
AndrewC198910931.00
      06-06-2020, 10:33 AM   #31
Dasnub
This was exciting until I read I have to switch maps at a dealer. I have plenty of access to 93 octane but there are times I end up in an area with only 91. Wouldn’t want to end up stranded unexpectedly... how far could you drive the car (taking it easy obviously) without having to be too concerned?
Also, whatever happened to the whole “the N55 is tapped out?” thing from Dinan themselves? How much are we affecting long term reliability? Is this really possible without even an intercooler upgrade?
tranck500.50
      06-08-2020, 08:36 AM   #32
Dinan_Engineering
Drives: Any BMW
I stand corrected. Tells you how often I travel to our neighbors in the north.
If you arent bouncing it off the rev-limiter and doing full obnoxious pulls or anything there is little concern of using 91 on the 93 octane mapping for a tank of gas. Is it ideal? No, but as long as you don't abuse it you should be fine.
In stock form the N55 M2 is pretty close to tapped out. 2 factors are the primary contributors to this-- the turbo and more importantly fueling. A larger turbo and intercooler will definitily help the top end and improve efficiency for some additional power, but only to a point. The car is more fueling limited then anything. Fueling with DINANTRONICS was indirectly controlled (and limited in scope) so there was little gain with a piggyback itself (stage 1) until some hardware was accompanied with it (stage 4 - turbo and intercooler). With a flash that is turned on its side a bit and we now have direct control of the fueling and are able to maximize what is already there. Getting very similar numbers without any modifications to what you saw with stage 4 previously in the process. When released, what you will see with the flash based big turbo mapping is that peak power is only minimally improved but the top end power lasts longer and will be flatter. Unfortunately it will still be fueling limited as that is simply what the pumps can handle.
Poochie9104.50
      06-08-2020, 08:48 AM   #33
Nick2016M2
Nick2016M2's Avatar
Drives: 2016 M2
2016 BMW M2  [0.00]
Is there any improvement in the "lag between shifts" issue seen on the 6MT? Currently being discussed here:
https://f87.bimmerpost.com/forums/sh....php?t=1699999
      06-08-2020, 08:52 AM   #34
Dasnub
Very interesting, thanks for the detail. I was always under the impression that the turbo and IATs were the big limitations on the N55. These are pretty impressive gains for a Stage 1 reflash. In your opinion does that make a HPFP upgrade a priority over the intercooler or turbo?
      06-08-2020, 09:10 AM   #35
Dinan_Engineering
Drives: Any BMW
Waiting on response from the software guys. Not sure personally...
If you are going for big power then yes a HPFP is equally as important as the turbo and intercooler.
      06-08-2020, 09:22 AM   #36
243Racing
1448
What do you consider “big power” for the n55?
I’m really looking to be in the 380whp/420wtq area, to optimize my power to weight ratio for series rules. Stock was 355/382
      06-08-2020, 10:05 AM   #37
Dinan_Engineering
Drives: Any BMW
They have never experienced the phenomenom described so are unsure if it was specifically addressed I'm afraid.
Over 400 WHP you need more fuel so that would be considered "big power" on the platform in my eyes.
243Racing1447.50
      06-08-2020, 10:26 AM   #38
Dasnub
The lag issue is definitely a thing on the 6MTs. Very frustrating- there are some recent long threads on it. Any tuner that solved this would get my business even without a power bump.
Do you feel like the stage 1 tune is going to have a significant impact on longevity/reliability over stock without changing the IC and turbo as well? The tune really puts me where I’d like to be in terms of power but don’t want to do it at the expense of those things, as this is a 25k/yr daily driver.
Put another way- is this stage 1 tune or full stage 4 a more reliable option?
243Racing1447.50
      06-08-2020, 11:22 AM   #39
Dinan_Engineering
Drives: Any BMW
Flash stage 1 is more reliable then DINANTRONICS Stage 4 simply because its more comprehensive and has finer (and direct) control over a multitude of parameters.
243Racing1447.50
      06-08-2020, 11:25 AM   #40
Nick2016M2
Nick2016M2's Avatar
Drives: 2016 M2
2016 BMW M2  [0.00]
I agree. I wonder if they even utilized a 6MT for testing or if it was DCT. I can't imagine they wouldn't be able to replicate the issue if it was a 6MT
      06-08-2020, 11:27 AM   #41
243Racing
1448
Forgive me, but I thought the 'solution' to the lag issue was to shift over 6krpm?
I was having the same (or similar ) issue, but I was shifting around 5500 at the track. This last event I shifted over 6k and never had the lag that I was experiencing previously.
      06-08-2020, 01:07 PM   #42
Dasnub
It masks the issue (boost gets rebuilt at higher rpm faster,) but does not actually correct it.
243Racing1447.50
      06-08-2020, 02:06 PM   #43
Dinan_Engineering
Drives: Any BMW
Primary car involved for flash development was an employee owned DCT M2 that is onsite.
243Racing1447.50
      06-08-2020, 02:09 PM   #44
Dasnub
Would be worth having your guys maybe look at some customer logs here... sounds like other tuners are working on it:
