06-18-2017, 01:45 PM | #265 |
Rep 46
Update to my above post with video. This started as the "soda can crunch" noise while coming to a stop and then slowly degenerated into this. This lasted for about 10 minutes on and off and the sound has since disappeared, but I can sort of get it to make a light screech when I turn a sharp and slow left. Can't get it into the dealership until Wednesday.
06-18-2017, 09:57 PM | #266 |
Rep 13,107
My dealer ordered the shields, but told me that the whole rear axle needs to be removed to fit those. So he asked me if it's worth the hassle. I refrained (perfect factory set-up: if it ain't broken, don't fix it).
But, seriously, isn't this rather unscrewing/screwing a few bolts instead of the invasive operation of taking off the whole rear axle ?
///M is art ↔ Artemis
06-19-2017, 01:10 AM | #267 | |
Rep 817
06-19-2017, 01:22 AM | #268 | |
Rep 1,514
06-19-2017, 10:34 AM | #269 | ||
Rep 4,254
///M Power
08-11-2017, 01:21 PM | #270 |
Rep 390
Soda can noise on late 17
My F87 was delivered April this year, after 5000 km I started hearing like the soda can noise, particularly when cruising at very low speed, sounds like a have a piece of metal scratching the road... intermittently and comes from the left side of the car i'd say.
I looked at the suspect left rear wheel shield plate, and i have the updated sheilds which are quite open, so there is little chance i have small gravel in. The sound coming from the left side make me think it's not the dif, also i can't reproduce this at will... Anyone got this sound again with the "updated" shield plates ? |
iRasF8713.50 |
08-11-2017, 01:56 PM | #271 |
Rep 462
I have an April 2017 build and I've had the soda can noise once in 8000 km. It happened at 1-2 second intervals for less than a minute as I was leaving a parking lot, and was super loud, then stopped and never recurred. So my guess is it can still happen with the new plates. It's annoying when it happens, but I wouldn't lose sleep over it.
08-11-2017, 03:28 PM | #272 |
Rep 390
This drove me crazy, it's very annoying in the city. After some help of my wife telling me exactly which wheel the noise came from, i decided to get some flexible thin plastic sheet and insert it between the plate and the disc brake and fiddle around to find the rock or the thing stuck.
After few minutes i hit a "hard" spot but it was stuck kind of too hard for the plastic sheet to remove the thing stuck. I noticed that the plate was quite thin and flexible so i twisted it back an forth slightly and used the plastic sheet again... and bingo ! some gravel stuck with tar (remind me i've been on road freshly under construction not long ago...) on the plate came off ! |
08-11-2017, 07:11 PM | #273 |
Rep 1,514
I have the new shields fitted to my 2016, since having them installed i have heard the soda crunch noise twice in approx 4000 kms.
I still believe they are a huge improvement over the previous shields, i used to hear the noise almost weekly. |
thaalrasha621.00 |
08-11-2017, 07:45 PM | #274 |
Rep 6,637
After having them installed I have heard it zero times since. Was weekly before.
10-15-2017, 07:03 PM | #276 | |
Rep 199
Thanks Dan
10-16-2017, 03:14 AM | #277 | |
Rep 6,637
I had Peter Pan put in the heat shields and that fixed it for me. If you search for soda can crunch sound you should find a thread that has the part number. Peter Pan resisted changing it at first because their tech couldn't reproduce the sound. I have two videos of it happening on my car but they said a tech had to hear it while in my car. I told them let's cut out the middle of this retarded dance with me complaining several times and them saying they can't reproduce several times it until they can. That will make it easier on both of us. If they don't I will drive by the front of the dealership filming until I get the sound to happen then I will post it to the BMW related forums saying Peter Pan refuses to fix this sound on a new M car. After that they said they would install the new brake shield as a one time courtesy. Maybe now they will be more likely to install the part when asked? |
10-16-2017, 09:41 AM | #278 |
Rep 199
Thanks...I'll see what the guys at Weatherford have to say about it....
See you out there
10-16-2017, 12:55 PM | #279 | |
Rep 6,637
http://f87.bimmerpost.com/forums/sho...54&postcount=3 |
10-20-2017, 03:35 PM | #280 |
Rep 21
I've been having the noise pretty regularly since i got my car last november. was told i originally had the "new" plates at end of last year, then they swapped them for the "new new" plates (with 4 holes instead of 2, i got to see them) earlier this year (around april).
About a month ago it came back and was worse than before, lasted a few days before i got it loose. Then this morning it was the worst its ever been. A pure grinding sound so loud it was heard from my house when i pulled out. Dealer cleaned it out for me and said theres a new bulletin stating they should modify the plates to cut two more holes in them. They didnt have time to get it done today, so I took car home for the weekend. This is the first im hearing of the dealership modifying the plates themselves, anyone have experience with it? I'll try to get a copy of the official bulletin |
10-21-2017, 08:18 PM | #281 |
youtube.com/rodoabadtv
155
Rep 248
Drives: 2017 Dinan M2, 2023 X3MC
Do you guys drive on roads with a lot of gravel or roads that have a lot of debris?
10-23-2017, 03:31 PM | #283 |
Rep 390
The new heat sheild have a shape that doesn't trap debris in. However it's not impossible to get some sticky gravel / tar and little rocks that will remain inside. Should be easy enough to remove though.
12-28-2017, 12:42 PM | #284 |
Rep 17
Screeching sound from wheel (?)
Just picked up my 2018 LCI on Saturday, and already have a service appt for dealer to look at cause of a high-pitched screeching sound coming from one of the wheels. Its noticeable at very low speed (starting from stop - when car is quietest) and seems to vary with speed. It sounds like an upside down dinner plate briefly pushed on a granite countertop.
Based on research on these forums, I am guessing/hoping its just a pebble in heat shield/rotor, but curious if anyone else has noticed it on theirs and have any ideas so I can direct the dealer accordingly... thanks in advance! |
12-29-2017, 11:18 AM | #286 | |
Rep 13,107
As Prodigy. suggested: wiggle the brake shield right behind the brake disc (rotor) to make the pebble move position. See 00:53-02:41
geogerf115.50 |
