02-26-2021, 07:49 PM | #133 |
Rep 3,696
02-28-2021, 08:17 AM | #134 |
Rep 109
Zm2.. here's a 3rd and 4th gear pull.
Crazy how soo many people want to race.. Kept up with a 2018 vette. Haha Thanks for looking https://www.bootmod3.net/log?id=603b...729b5994d9d673 Last edited by Wheats1; 02-28-2021 at 08:29 AM.. |
02-28-2021, 08:30 AM | #135 |
Rep 109
02-28-2021, 11:11 AM | #136 | |
Rep 3,696
There's still some funky stuff going on with this log. Is this with the 3.5bar TMAP installed and reflashed? Are you logging with DSC all the way off? |
02-28-2021, 11:38 AM | #138 |
Rep 109
No 3.5 tmap yet.. probably next week
What's looks funky?? Also,sent to halim.. He responded as "Looks very powerful, logs look good" Weird Yes I'm pretty sure I turned DSC off |
02-28-2021, 12:02 PM | #139 | |
Rep 3,696
You only had minor throttle closure in the 4th gear log, but both logs have HPFP below target as boost gets close to stock TMAP max. There's a possibility your Emix is higher than you think, but I'd still bet you need the 3.5bar TMAP like the rest of us so the car doesn't overreact when you get close to/above 21.6psi pre-throttle. |
02-28-2021, 12:53 PM | #141 |
Rep 3,696
03-03-2021, 02:45 PM | #143 | |
Rep 7,429
It's a really simple install so you don't need to get it professionally installed.
03-03-2021, 07:58 PM | #146 |
Rep 362
+1. I bought the same one Zack posted in the forum. Works great!
03-06-2021, 11:15 AM | #149 |
Rep 3,696
When we were chatting about PS2's, these are the data I was referring to: https://f87.bimmerpost.com/forums/sh....php?t=1766028
This is Halim's original Stage 2+ E30 thread that got admin locked b/c we had to Zelda-style battle a forum troll, which got him banned and me losing 1000-Rep points (XP hit!) in the process. He was subsequently proven wrong once I posted up my dyno curves towards the beginning of this thread. Good times. Anyways, 500+ whp on the same map simply by bolting on the PS2. What's interesting is that setup on the Stg 2 E30 map (running 3-psi less than Stg 2+) makes the same peak power as my Stg 2+ E30 Dinan turbo setup, and has a much better power curve up top. Backing down to the Stg 2 E30 map with the PS2 sounds like the map to run on hot summer track days if the Stg 2+ map is generating too much heat for the N55. |
03-06-2021, 11:34 AM | #150 | |
Rep 3,696
I was just teasing you in my earlier posts, too. Let's see some 3.5bar TMAP logs! |
03-06-2021, 11:35 AM | #151 |
Rep 3,696
I do need to note for everyone that I was having upper RPM HPFP drops outs earlier this week with temps <30F and an E50 mix with my Dorch Stage 1 and Dinan turbo.
440-450whp seems to be about the limit for Dorch Stage 1 with an E50 mix. I took the mix down to ~E42 and the car was fine. |
SeanWRT3179.00 |
03-06-2021, 12:09 PM | #152 | |
Rep 485
I remember reading some of the Zelda battle royale lol forum trolls and people that think they know it all are extremely annoying. I simply won't engage lol. |
ZM22813.50 |
03-06-2021, 02:45 PM | #154 | |
Rep 7,429
