M2 Technical Topics > N55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > Stage 2+ E30/racegas 100-200kph, 1/4 mile, dyno etc results thread
      07-17-2022, 04:08 AM   #507
Leaveatrail86
Drives: Bmw M2
Originally Posted by AmuroRay View Post
Are you fbo? E85?
And after you went back to stock is it okay now?
      07-17-2022, 09:26 AM   #508
AmuroRay
AmuroRay's Avatar
2283
Drives: M235i
Originally Posted by Leaveatrail86 View Post
Are you fbo? E85?
FBO, no E - I’m changing back this week plus a slew of goodies.
      07-17-2022, 09:38 PM   #509
Leaveatrail86
Drives: Bmw M2
Things seem to change with e85. Let me know how it goes
      08-08-2022, 10:14 AM   #510
designatedposter
Drives: m235i
Anybody try latest version for n55 ewg? 7.3
M235i rwd 6mt
      11-02-2022, 01:43 AM   #511
Mr_M//
124
Drives: 2017 M2/M3
I’m running the NGKs gapped to .20 at the beginning I had miss fire before I upgraded the HPFP. Anything over 5k misfire.
My idle is the not the greatest sometimes the exhaust make noises
After the HPFP it ran good E30-E56. At E60+ it misfires a little so I kept it at E55.
      11-02-2022, 07:51 AM   #512
ZM2
Drives: 2017 LBB M2
I’m running the NGK’s at their out of the box gap of 0.030”, E50-55, and a TTE460 @ 480whp on this map, and my car runs smooth with no issues. Gapping down is not needed.
      11-04-2022, 02:22 PM   #513
Mr_M//
124
Drives: 2017 M2/M3
Originally Posted by ZM2 View Post
I’m running the NGK’s at they’re out of the box gap of 0.030”, E50-55, and a TTE460 @ 480whp on this map, and my car runs smooth with no issues. Gapping down is not needed.
I believe that’s the case as well, I gepped them .20 when I first install them then I was to lazy to open up the gap since I knew I’m going to change my set up.
but definitely I needed to open the gap up.
ZM22813.50
      11-04-2022, 06:37 PM   #514
///393
///393's Avatar
829
Drives: X6
This sub-forum should be renamed spark plug chat
      11-08-2022, 09:09 PM   #515
ericlr1225
ericlr1225's Avatar
Drives: 2018 M2 LCI 6MT
Spent one afternoon going thru the whole thread, I'm super impressive about those experiences and great info from you. Immediately ordered Dorch stage 2 hpfp and ready for rocket journey. I decide to quit playing around shitty 91 in California anymore. I think I get enough info I need from your posts except :
I intend to stick with stock turbo at the moment and I have CSF Intercooler.
Is stage 2+ E30 OTS v5.9 kinda pushing too much with those bolt-ons? Cali is hot.
What are the pros/cons to run it with stock turbo?
Are 0.026'' NGK + Eldor coils gonna run it fine? (copied your set up from another thread). I have another new pack of 330 ready to swap.
Any other maintenance/preparation I need to do to get start?
Thank you
ZM22813.50
      11-08-2022, 09:43 PM   #516
ZM2
Drives: 2017 LBB M2
Thank you
Thanks!
You’ll be fine with Stg 2+ E30 and stock turbo with FBO, you’ll just want to shift at 6k to maximize the power band. And run E40-50.
I’m now running the NGK’s at the out of the box gap of 0.030” with the Eldor’s and they’re doing great, but the 330’s at stock gap should be good too.
Make sure you have a 3.5bar TMAP. And the PTF Flexfuel sensor and Stg 2+ MM makes it super easy to autoscale based on actual Emix to get a little more power. I think that’s it?!
Shout out to PilotxERAU who just joined this club with the only other stateside TTE460 I know. He even did the turbo swap himself after he waited a month to get it. That’s dedication!
      11-08-2022, 10:03 PM   #517
ericlr1225
ericlr1225's Avatar
Awesome, I will post some logs when it gets ready next week. Cheers!
      11-12-2022, 07:15 PM   #518
PilotxERAU
Drives: 2018 F87 M2
Thanks!
😆 I am a bit nutty.
