M2 Technical Topics > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Bimmercode topics
      09-30-2017, 07:48 PM   #1123
M2018
Originally Posted by boostm3 View Post
Stephen said ASD can be re-enabled via expert mode.. Anybody have a proc to do this?
Originally Posted by TT1351 View Post
I think you would just have to switch back to "unknown value" from the main menu, I don't think you need to go to expert. Not certain however as I deleted mine via the cable method.
Has any one successfully tried quick re-enabling ASD using expert mode coding yet?
      10-01-2017, 10:58 AM   #1124
rich8566
rich8566's Avatar
Drives: M2 + Z-4
2014 BMW M235i  [0.00]
Vgate iCar 3 or iCar 2) WiFi version
Originally Posted by Caduceus View Post
I've purchased and successfully used this app. Of note, I'm using the Vgate iCar 3 (not 2) WiFi version and it hooks up and works just fine without any compatibility issues.
Great app and some hidden gems in "Expert Mode" such as being able to change the trigger point for the 2 stage low fuel warning.
Looking forward to accessing the seat belt module if/when Stephan gets into it.
If he can crack the instrument backlighting he will be a God.
Help - i have a 2017 M2 - do I need iCar 2 or iCar3? Per the app instructions I ordered the iCar 2 WIFI version connector.
      10-01-2017, 11:56 AM   #1125
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
That’s what’s recommended and works. I have the same set up.
rich8566608.50
      10-02-2017, 01:19 AM   #1126
OSee
Drives: M2 Sold
I found that setting your iPhone to not automatically join wifi networks and going full airplane mode (with wifi on obviously) works best for maintaining a connection to the icar adapter. iPhone (with iOS 11 dev beta installed) kept on disconnecting from the adapter (because no internet I assume) and searching for greener pastures.
The hell would have happened if it did something like that mid coding?
      10-02-2017, 09:23 AM   #1127
geogerf
geogerf's Avatar
116
Drives: MY17 LBB M2
2017 BMW M2  [0.00]
I hope that’s not the case with iOS 11. Didn’t happen before.
      10-02-2017, 08:32 PM   #1128
CLH
CLH's Avatar
Drives: 2018 M2 LBB 6MT
I tried to code mirror fold-on-lock on my MY18 today and it doesn’t seem to have done anything. Connected the adapter, read the ECU, navigated to the right section, set the option active, and coded. Locking the car has no effect on the mirrors. I know the coding happened as there was a “reset” type effect when the coding completed (dinging and radio off/on).
I haven’t tried to code any other options yet. I’m being a bit cautious until I know things are working right.
What am I missing?
Chris H. - In the sunny PNW!
My handy Speed-in-Gears calculator
      10-02-2017, 08:48 PM   #1129
Benzima
Benzima's Avatar
1324
Drives: 2017 BMW M2
What am I missing?
Did you leave mirror adjustment knob on the left side?
      10-02-2017, 08:48 PM   #1130
OSee
Drives: M2 Sold
What am I missing?
Set the Comfort Lock delay to No Delay (can't remember exactly language so double check please). Problem solved. I had the same issue initially.
CLH116.00
      10-02-2017, 08:51 PM   #1131
OSee
Drives: M2 Sold
Has anyone successfully turned ASD back on after coding it off?
      10-02-2017, 09:30 PM   #1132
CLH
CLH's Avatar
Bingo - works now. Thanks!
      10-03-2017, 12:56 PM   #1133
ModestV8
Is there an updated excel sheet with the updates by the creator? I think the last excel sheet I downloaded didn't things such as the seat moving back before entering, seatbelt sound off, etc. Correct me if wrong please, thanks!
      10-03-2017, 01:48 PM   #1134
lax01
Drives: 2017 M2
I was tracking things here but I haven't seen any new codes to add: https://docs.google.com/spreadsheets...it?usp=sharing
Not sure if that is what you are referring to...
      10-03-2017, 02:13 PM   #1135
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
I just received a request to fill out a survey re my experience!....this will be interesting. what could i possibly say...
"ill never be back because you ask too many questions!" "NOT CODER FRIENDLY" lol
But in all seriousness, my take-away from all this is that this visit could have gone so much better...had they just been cool about the whole thing and politely warned me about making modifications to the car etc (even though i would not consider what i did a MOD)....instead i felt like i was being called into the principals office...you know that sickening feeling you would get in your gut cause you knew you were in hot water...just seemed very hostile from the get-go. You would think i had just committed a serious crime.
I just dont get this kind of attitude. Warranty work = money in their pocket. Now im not suggesting that they simply turn the other way no matter the situation since they have a reputation to protect with HQ but geez, be real with me, advise me, TREAT ME LIKE A CUSTOMER!
But too bad for them...no second chances here.
Thanks all for your opinions and recommendations..
bollinm25.00
      10-03-2017, 02:23 PM   #1136
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Originally Posted by zenmaster View Post
I'm not sure why they won't touch the car with coding. Sounds like they think it will either interfere with diagnostics or is potentially causing the problem you are complaining about.
Is there any coding that could cause battery drain?
They said they cant diagnose further my problem because of my coding...that it would raise a flag against my car.
They blamed faulty coding for my battery issue....That certain systems dont shut down properly as a result..therefore a constant, slow drain on my battery even with car turned off.
      10-03-2017, 02:47 PM   #1137
zenmaster
Drives: '17 M2
That is actually plausible. However, it certainly is not an issue with most dealers and most of the coding options.
      10-03-2017, 02:58 PM   #1138
Spa2k
Drives: '13 JCW
That's entirely possible; I had a similar problem with an OBD II device on my Subaru WRX several years ago. The dealer should be able to identify the battery drain overnight, if not immediately. The real problem is that if you presented your car to them as having a warranty problem, the service writer likely put in on the computerized service order - and, unfortunately, your car already may be flagged as modified in BMW's system. If they didn't do that, they did you a favor.
Take your car to a reputable European shop and pay for the diagnosis. Then you'll know for sure.
Dabozo624.50
      10-03-2017, 10:00 PM   #1139
akkando
akkando's Avatar
5865
It's missing disable rev match for MT M2s.
      10-03-2017, 11:21 PM   #1140
lax01
Drives: 2017 M2
Link? What's the info? I'll add tomorrow
      10-03-2017, 11:26 PM   #1141
akkando
akkando's Avatar
5865
Info here http://f87.bimmerpost.com/forums/sho....php?t=1418405
      10-04-2017, 01:42 AM   #1142
cookiesowns
cookiesowns's Avatar
587
lol. if your car was hooked up at all to ISTA+ FASTA data is collected and sent automatically. If you were to be flagged it would have been flagged already. Dealer is blowing smoke, avoid them tho. They can still "manually" flag you if the foreman is enough of an asshole.
      10-04-2017, 11:04 AM   #1143
gmzanatta
gmzanatta's Avatar
1823
Drives: LBB 6MT M2 # 660/713
I think we need to make an important distinction here as to what type of coding though.
You could get flagged if you modified the code in the car. This can be things like a tune, changes to make it work with aftermarket parts like deleting CELs, etc.
You will not get flagged by turning on/off features already existing in the BMW software with something like Bimmercode non-expert mode. You make only selections and adjustments on what?s already there.
Heck, there?s even dealers out there who will code the mirror close function for you since pretty much every brand out there now does this.
      10-04-2017, 01:20 PM   #1144
Dabozo
Dabozo's Avatar
625
Drives: M2 BSM MT
Dont beleive the car was hooked up...that was why they did not further investigate my complaints...so in a sense, like Spa2k said before your post, they did me a favour in a roundabout way. I realize this. My beef was how they handled the whole thing...the way they treated me (like a criminal) ...especially the shake down for $500 to put car back to factory defaults. Not cool.
