12-18-2019, 09:26 AM | #1 |
Rep 67
Possible to get M2CS tune for M2C?
Would it be possible to simply copy files from the CS to use in the 2C? I know nothing about tuning and I love my stock car as is, but if the only difference in power production between the M2CS and 2C is software controlled, then how hard would it be to have this specific tune flashed over like any other tune?
12-18-2019, 10:21 AM | #2 |
Rep 744
Pretty much impossible since BMW is the only one with a non-compiled tune. (this is how I understand that it is not possible to simply copy an OEM tune).
However, BM3 and other tuners make tunes that approximate the M4 CS/competition tune ETC. As the M2 CS is not even out yet no one makes "replica" tune. In the meantime you can get an M3/4 "CS" tune which is likely 99% the same as the M2 CS one.
12-18-2019, 07:23 PM | #3 |
Rep 210
Just Get the new Dinan S55 tune. It's covered under factory warranty.
2020 X3MC, 2019 M2C
'14 F-150 Tremor, '99 Mustang Turbo |
12-18-2019, 07:27 PM | #4 | |
Rep 1,049
12-18-2019, 10:10 PM | #5 |
Rep 1,000
12-19-2019, 04:30 AM | #6 | |
Rep 1,027
As soon as a tuner gets their hand on its OEM software, I'd imagine they will clone it and offer it on the market Could take some time though, considered the limited number of production
Current: G87 M2 / F21 M140 / 718 GT4 | E89 Z4 35is
Gone: E92 M3 | RS3 8V | E82 1M | AMG GT-S | X3M Comp | F80 M3 | Juke Nismo RS | E85 Z4 M Roadster | R58 Coupe JCW | F87 M2C| F87 M2 | F22 M240i | F82 M4 | E89 Z4 2.0i | F56 Cooper S | E92 330i | R56 One |
Big Fabri94.50 |
12-19-2019, 11:35 AM | #9 | |
4972
Rep 10,200
12-19-2019, 12:10 PM | #10 |
Rep 1,049
The DME is what controls the engine, literally Digital Motor Electronics. For 2020, BMW changed the DME if your iStep version is past a certain number. All previous versions have been 'cracked', so they're all tune-able. AFAIK, BM3 (and most other shops) haven't cracked the new DME yet, so we can't tune our cars. Only method, as of right now, is bench flashing the ECU to backdate the DME, and then you will be able to freely tune your car.
dmboone254972.00 |
12-19-2019, 12:34 PM | #11 |
Rep 1,027
12-19-2019, 02:08 PM | #12 |
Rep 3,714
12-19-2019, 06:53 PM | #13 |
Rep 210
It's covered under the factory warranty when installed at a Dinan authorized BMW dealer.
2020 X3MC, 2019 M2C
12-19-2019, 10:19 PM | #14 | |
Rep 1,000
12-19-2019, 10:19 PM | #15 | |
Rep 4,976
Just read the Dinan warranty on their website, or read the many threads on various forums about how a Dinan warranty repair works. Or just go over to the Dinan Flash thread under the engine section and read it from the horse's mouth.
Current Car: 2018 F80 M3CS, SMB, DCT, ZEC, MPE Recently Departed: 2020 F87 M2C, LBB, ZEC, 6MT (Euro Delivery Aug. 29, 2019, totaled by an idiot in a Camry who then ran from the scene) Wife's Prior Car: 2018 F80 M3, Yas Marina Blue, DCT, Black 19s, Carbon Structure Anthracite Cloth/Leather Combination, Driving Assistance Package (Euro Delivery Oct. 9, 2017) |
12-20-2019, 05:38 AM | #16 | ||
Rep 7,594
Drives: '19 M2C
Dinan and other tuners can upload older software into the ECU so it can once again can be modified. Basically installing the version of ECU software BMW had before they locked it down. Luckily my car has not been updated and is unlocked.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) Last edited by ChrisK; 12-20-2019 at 09:57 AM.. |
dmboone254972.00 |
12-22-2019, 08:48 PM | #18 | ||
Rep 210
Repairs still not coming out of owner's pocket for the same period if something should happen. Close to the same as you can get. 🙂
2020 X3MC, 2019 M2C
Brandt51887.50 |
12-23-2019, 10:49 AM | #19 |
Rep 3,842
I believe that the M2CS original tune will be similar to the M4CS. However the M4 CS has 285/30 ZR 20 rear tires. I would think that with the M2 CS tune they would have taken that into consideration otherwise the rear tires would spin like a top in lower gears. BM3 allows you to lower the power by gear in order to prevent too much wheel spin.
12-27-2019, 08:41 AM | #20 | |
Rep 251
12-27-2019, 09:44 AM | #21 |
Rep 3,842
Trust me, the M4 CS tune on the M2C in MDM mode will spin the tires off :-). That's why I don't think that the M2 CS tune will be exactly like the M4 CS tune. Also they would have taken into consideration manual the transmission that the M4 CS doesn't have.
12-27-2019, 01:25 PM | #22 |
Rep 151
M4CS is rated 453 hp / 443lb-ft. M2CS is rated 444 hp / 406 lb-ft. So it's all but certain the tunes are different.
In terms of putting power down, given the M2CS torque is the same as the M2C, there should be no difference in it's ability to put the power down relative to the M2C. The M2CS will simply hold power a little further up into the rev band. Maximum in-gear acceleration should be no different, but the M2CS will maintain that acceleration for longer and higher into the rev band. Also, it's important to remember that 265 width tires on an M2 are not going to put the power down the same as 265 width tires on an M3/M4. The M2's shorter wheel base likely helps with weight transfer and loading of the rear tires under acceleration. It may be a negligible difference, but I wouldn't assume the M2 is necessarily the same as an M4 in this regard. To summarize, the M4CS having 285 width tires is somewhat irrelevant since the M2CS has a shorter wheelbase and less torque. Also, the M2CS tune should be just fine on the M2C - no need for torque limitation in lower gears as the torque is no different.
2019 M2 Competition 6MT - ED October 5, 2018
2018 Honda Accord Sport 1.5T 6MT (daily driver / family hauler) |
