M2 Technical Topics > Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls > 1200 Mile Service - Trans and Diff?
      08-19-2019, 06:05 PM   #1
MisterGoober
Drives: Searching!
Just got back from my 1200 mile service and my dealer is saying that it's an oil change only and not the transmission and diff?
Has anyone else had the 1200 mile done on their 2020? Can you confirm if the dealer did the diff and trans? Anyone have links to what should be included at each service interval?
      08-19-2019, 06:48 PM   #2
speedsnice
Drives: 2020 M2 Comp
I got my 1,200 service last Friday and they did engine oil and diff, it was on my invoice.
2023 X3 M40i @b58x3
2020 M2 Competition @s55m2
      08-19-2019, 06:52 PM   #3
MisterGoober
Drives: Searching!
I called the Genius Line and supposedly for 2020 only the oil is required?!?
      08-19-2019, 07:02 PM   #4
speedsnice
My car is a 2020, the third part number on the service receipt is for the fluid that is used on the rear differential. I use the same fluid on my e36 M3 when I service it.
2023 X3 M40i @b58x3
      08-19-2019, 07:25 PM   #5
hlm2c
Drives: M2C
Transmission is lifetime. I did oil change and diff fluid during my break in, but I'm overseas and warranty doesn't cover servicing.. I paid for everything out of pocket.
dtmurf481.50
      08-19-2019, 09:08 PM   #6
KevinM
KevinM's Avatar
2936
Drives: 2002 M5;2007 M Coupe;2020 M2C
2020 M2 Competition  [10.00]
2007 E86 M coupe  [8.38]
2002 E39 M5  [9.00]
Yes, engine oil and diff fluid. I don't believe in BMW "lifetime" fluids and will be changing the tranny fluid at 50K miles.
2020 F87 M2C Hockenheim Silver/MT
2002 E39 M5 Sterling Gray/Caramel
2007 E86 Z4M Coupe Silver Gray/Black
2021 Kia Telluride (hauler)
      08-20-2019, 06:43 AM   #7
MisterGoober
Drives: Searching!
Thanks for the responses. Especially to Speedsince.
I didn't recognize the short line item for XJ-SAF. It was sitting there next to oil, filter, crush washer etc.
The service advisor didn't recognize the XJ-SAF line item either apparently, because he told me they didn't do the diff fluid anymore when I asked (i'm sure they are clueless and aren't involved much is what the techs actually are doing).
After going through the invoice again, looks like it was done, just not easy to recognize. Thanks to others for posting their receipts. Wouldn't have known otherwise.
speedsnice1198.50
cptobvious2531.50
      08-20-2019, 06:46 AM   #8
somberlaine
somberlaine's Avatar
Drives: 2020 M2C (ED 6/6/19)
They changed diff fluid on my 2020. Not sure if it makes a difference but I had my 1200 service done in Germany.
      08-20-2019, 11:21 AM   #9
buckybadger
BMW forever!
buckybadger's Avatar
Drives: BMW
They did oil and diff update. No transmission update.
However this diff update completely messed up the steering feel. The on center now has lot of slack and overall steering feels disconnected and less taut. I have already checked all my tire pressures multiple times and have no alignment issues. I have not hit a single pothole so far.
So it has to be the update that messed everything up. My dealer denies that and I'm thinking to take my car elsewhere.
I believe some of the other folks might be experiencing the same issue.
I own a 2019 M2C, built end of September 2018 and delivered in November 2018.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-20-2019, 01:52 PM   #10
M Fifty
844
Drives: M2 & 330CI
Changing the differential fluid is "highly unlikely" to have changed the steering feel as it will only have an effect when you're putting enough power though the transmission to cause the differential to fully or partially lock (so basically breaking traction).
Or were you talking about something else entirely?
      08-20-2019, 06:33 PM   #11
buckybadger
BMW forever!
Drives: BMW
Something else entirely.
Dealership did a 1,200 mile service and they updated "something". I didn't do a good job of reviewing the notes at that time when I picked up my car. But that "something" messed up the steering.
If any else having same issue then please chime in.
2020 BMW X5
2019 BMW M2C
2014 BMW 335i
2009 BMW 328i
      08-29-2019, 06:58 AM   #12
ColoradoSpringsM2C
ColoradoSpringsM2C's Avatar
Drives: BMW M2 Competition
2020 BMW M2 C  [0.00]
Mine goes in on 9/11, the dealer said oil and diff. I'll pay attention to how it handles after.
      08-29-2019, 08:46 AM   #13
mcvaughan
mcvaughan's Avatar
Drives: F87 Competition
Just had my service done. No diff fluid change.
Matt
      08-29-2019, 10:43 AM   #14
CTSean
Drives: LCI BSM MT M2
Assuming you're talking about your break-in service, then they did it wrong
https://www.newtis.info/tisv2/a/en/f...nce/1VnYk48ozi
      09-04-2019, 09:14 AM   #15
gsrbri
gsrbri's Avatar
Drives: F87 6MT
If you have the 6MT, changing all fluids is sensible. Significant amounts of metal in the transmission after the running-in period. They will only comp the Engine and Rear Diff.
I think it was $120 for the 6MT change, including fluid (at least in my case).
      10-20-2019, 10:01 AM   #16
mcvaughan
mcvaughan's Avatar
My indy shop inspected and found nothing in the diff fluid. No need to change it.
Matt
      10-22-2019, 07:51 AM   #17
BMW 16 5-0
Drives: M2 Competition
My 2020 goes in on Friday. I will let you know...
      10-22-2019, 08:59 AM   #18
nioh_lbbm2
nioh_lbbm2's Avatar
1717
The DCT is not lifetime fluid. ZF themselves released a video to combat the stupid claims from automakers that their transmissions use lifetime fluid. ZF recommends regular fluid changes too
      10-22-2019, 09:28 AM   #19
Triple Seven
Drives: 2023 M240i, 2020 M2C (sold)
Dropping my car off right now for the 1200 service. Service advisor said that they unlimit the full amount of horsepower after this service? Mentioned around 100 hp or so. Is that true??
      10-22-2019, 02:05 PM   #20
Triple Seven
Got her back, doesnt feel any faster.
      10-22-2019, 05:16 PM   #21
CTSean
it is not true
      10-22-2019, 05:25 PM   #22
Triple Seven
it is not true
Didnt think so, I wonder why they say such things.
