08-19-2019, 08:46 AM | #1 |
Mr Wonderful
58
Rep 780
Winter Wheel Setups on OG M2 18"/19" options
Picking up a '16 LBB this week and just looking forward towards winter so I can shop for the right deal instead of having to get something in a pinch.
I've always run 18's on my M cars but just was going to confirm they'll clear these brakes if I did say a cheap set of V703s. What are optimum offsets and widths to be able to run a 245 square combo? Or are the stock 19's well sized to run some 245 squares on them? I'm a touch concerned it's not a lot of sidewall for Midwest winters. However if people run them often and do fine, I'd just get rubber and get some BBS or something in the spring for the summer set. Thanks.
08-19-2019, 09:41 AM | #2 |
Rep 427
I ordered my winter wheels and tires from tire rack as a set. The wheels show ‘no longer available’, but they’re an 18x8.5 et30. Tires are 245/40r18.
I also run 18" track wheels from ApexRaceParts. They have a good fitment guide on their website. Some of their 18" wheels do not clear the front calipers, so you’re wise to key in on caliper clearance. I believe they do some winter packages seasonally. I’m not familiar with the VMR wheel you’re looking at, but I’d think VMR or a dealer could confirm. 245 on the 10" rear wheel would be pretty stretched. A 9" (front) wheel is on the wider end of the range for a 245 from what I recall. I think I’ve seen folks go with 255 square with this approach though. |
08-19-2019, 11:13 AM | #3 | |
Mr Wonderful
58
Rep 780
08-19-2019, 11:17 AM | #4 |
Rep 2,526
FYI, 18" VMR wheels will not clear the M2 brakes. You'll need to go with 19" if you want to go with VMR's.
08-19-2019, 11:48 AM | #5 | |
Mr Wonderful
58
Rep 780
Apex are nice but I've run into a lot of quality issues with them bending easily on Chicago winter roads.
08-19-2019, 12:50 PM | #6 | ||
Rep 2,526
08-19-2019, 05:48 PM | #7 | |||
Mr Wonderful
58
Rep 780
You don't think less sidewall was an issue?
08-19-2019, 08:09 PM | #8 | ||||
Rep 2,526
08-19-2019, 09:42 PM | #9 | |||||
Mr Wonderful
58
Rep 780
08-20-2019, 09:41 AM | #10 | ||||||
Rep 2,526
08-20-2019, 09:57 AM | #11 | |||||||
Mr Wonderful
58
Rep 780
245s it is
08-20-2019, 08:21 PM | #12 |
Rep 2,526
If you're going with oem wheels, I wouldn't put smaller than a 255 in the rear. Not sure a 245 will stretch to a 10" wheel.
08-20-2019, 10:01 PM | #13 |
Rep 1,092
I'm running these - https://www.canadawheels.ca/720form-...-u-beam-spokes
The 18x9 ET30 is perfect fit and works well with 245/40 tire. They are super light at 19lbs and should be under $200 if you can find US dealer (the link I sent was in CAD) Here is what they look like on the car - https://f87.bimmerpost.com/forums/sh...1&postcount=51 |
08-20-2019, 11:04 PM | #14 |
Rep 4,516
My oem 18" winter set up
640m in orbit grey cw MPA4 235/40/18 all round
Current '22 X3M LCI.. |
08-21-2019, 07:02 AM | #15 |
Mr Wonderful
58
Rep 780
See that would be very appealing for sizing
08-21-2019, 07:04 AM | #16 |
Mr Wonderful
58
Rep 780
Yeah you're right... ugh not sure why I thought it was only 9.5" in the rear.
08-21-2019, 09:10 AM | #17 | |
Rep 4,516
235 or 245 or 255 all round 235/255 - oem alt staggered winter 235/265 245/255 245/265 - same as summers 255/265
08-21-2019, 09:13 AM | #18 | ||
Mr Wonderful
58
Rep 780
Those are the M3/M4 18's correct?
08-21-2019, 11:15 AM | #19 | |||
Rep 4,516
Not to be confused with 513m - oem summer wheel option - wider @ 9"/10". E92 m3 oem 18" wheel (270m - see attached photos) is another option (8" et 20mm) - you could run either all round 235 or 245 F&R or staggered 235/245
08-21-2019, 07:30 PM | #20 | ||||
Mr Wonderful
58
Rep 780
Thanks for the help I'll figure something out
08-22-2019, 12:30 AM | #21 |
756
Rep 2,149
I would be cautious about running 18" in winter. Especially if your location uses road cinders and gravel for extra traction. The gravel may get stuck in between the brake caliper and wheel barrel, causing scratches in the wheels.
08-22-2019, 01:23 PM | #22 | |
Mr Wonderful
58
Rep 780
I'm in Chicago we only use salt and salt spray but ice is another issue I can see. No need to go down that road.
