M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > Are all wheels of same diameter, width and offset the same?
      08-15-2019, 11:11 PM   #1
bi0hazard
bi0hazard's Avatar
132
Drives: '17 m2
As the title says. Are wheels from different manufactures same, if the diameter, width and offset match? For example, 18 x 9.5 ET 35 wheel...is it going to be the same dimension between different brands, or am I missing something?
thanks!
17 m2: CSF Turbo FMIC, Fabspeed DP, BM3 Stage 2, VRSF Charge Pipe, Schroth quick fit, Vorshlag CC plates, Apex 18x10, BMS Clutch Stop.
      08-16-2019, 09:06 AM   #2
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Dimensionally, yes. However, there are other things to consider such as concavity and barrel clearance. What specifically are you trying to sort out?
Motorcity BMWCCA Member
Instagram | YouTube
twin fed1175.50
      08-16-2019, 02:27 PM   #3
bi0hazard
bi0hazard's Avatar
132
Drives: '17 m2
Just general question. I'm shopping for some cheap autocross wheels.
      08-16-2019, 03:20 PM   #4
M Fifty
844
Drives: M2 & 330CI
thanks!
Cheap wheels tend to weigh more for a given size. And, may be more easily (but not necessarily) damaged.
Barrel diameters vary.
Everything else? Stiffness, fragility, ease of repair - not so much.
      08-16-2019, 03:24 PM   #5
ApexWheels
ApexWheels's Avatar
1427
Drives: M3
As DetroitM2 mentioned, there will be a huge disparity in regards to spoke and barrel profile which has a dramatic impact on for brake clearance. Beyond that, the other important factors to consider are weight, load rating (strength), construction, certification, warranty coverage and so forth.
Even if a wheel design from two different companies looks similar at the surface, they can and will be drastically different for the reasons mentioned above.
-Ryan
detroitm22427.50
      08-16-2019, 08:17 PM   #6
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Since he replied. Check out Apex wheels. They're affordable and very tuff for track use. Well respected brand that doesn't break the bank.
Instagram | YouTube
      08-19-2019, 07:29 PM   #7
bi0hazard
bi0hazard's Avatar
132
Drives: '17 m2
Found these dirt cheap. This should fit, right?
Color: Gunmetal
Brand: VMR
Offset: 33
Hub Bore: 72.6mm
Bolt Pattern: 5x120
Rim Diameter: 18
Rim Width: 9.5
I agree, Apex is definitely a great option. Super popular with my friends. But I really just want a beater wheel for the occasional autocross, so looking at all my options.
      08-21-2019, 06:58 AM   #8
detroitm2
detroitm2's Avatar
2018 BMW M2  [0.00]
Color: Gunmetal
Brand: VMR
Offset: 33
Hub Bore: 72.6mm
Bolt Pattern: 5x120
Rim Diameter: 18
Rim Width: 9.5
All the 18" VMR wheels will not clear the M2 brakes.
Instagram | YouTube
