07-29-2019, 07:38 PM | #1 |
Rep 33
When to change rotors
This is my first full year of tracking a car. Learning a ton. One thing I've asked folks at events is when you know it's time to replace the rotors. I've gotten a wide variety of answers. Hoping someone here can help. I'm 10 days so far on my M2C running Pagid Yellow RS29's. Starting to notice cracks around the cross drilled points on the face of the rotors.
Secondarily have people noticed increased wear based upon pad choice. |
07-30-2019, 05:49 PM | #2 | |
Rep 660
07-31-2019, 06:43 PM | #3 |
Rep 115
Some small cracks in drilled rotors for tracked cars are normal. Just make sure none of the cracks are at the outer edge of the rotor or connecting the drilled holes, otherwise you should replace them. If you are planning to track the car frequently, I could recommend that you ditch the drilled rotors and at least go with something slotted or even J-hooks or Brembo type-3. Drilled rotors are not normally recommended for extensive track work because of the cracking at the holes. I am not sure who is making replacement rotors for the M2C. Maybe Girodisc?
2020 BMW M2 Competition (ED - May 20th )
2017 Ferrari 488 GTB 2016 Porsche Cayman S 2015 Mercedes E63 S AMG |
08-01-2019, 08:46 AM | #4 | |
Rep 379
https://www.bmwblog.com/2014/04/13/n...-brake-system/ This being your first year tracking your car you will most likely give your brakes the most punishment. The Pagid RS29 is a great pad although are known to be a little rougher on rotors. The two biggest things that will cause you to wear and abuse rotors at this point is your braking technique and traction control. In short, as you learn, and at some point run with DSC Off your brakes will stay much cooler and not wear, etc. like they will now. Heat is the killer. I suggest letting a performance shop or BMW dealer help you determine when the replace the rotors, at this point. There is not one answer as there are so many variables at play: 1 - Drivers braking technique - most important 2 - DSC On or Off - On will heat the brakes up much faster, as you start driving faster. It will first cause the rear pads and rotors to heat up fast and wear fast. When you run with DCS Off your fronts will wear twice as fast as the rear pads, general speaking. Don't rush turning it off if you still run with it on. 3 - Pads - which pads, when were they installed, mixing of pad materials, etc. It is best to run a single pad type per set of rotors. Switching of OEM pads back and forth with after market can create mixing of compounds which can create issues (ie bad vibrations, over heating, etc.) 4 - Tracks that you are driving on - some are much tougher on brakes then others Personally, I was able to get about 25 track days in on my front rotors last year. Still have the same rear rotors on, about 10 (4 x sessions per day) days in this year so far, four different tracks. I drive with DSC Off. Hope this helps!
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 Last edited by M2joey; 08-01-2019 at 08:53 AM.. |
Kankles1484.50 Capt Canuck704.00 |
08-01-2019, 08:55 AM | #5 | |
Rep 582
01-30-2021, 05:04 AM | #6 |
Rep 1,823
Thread revive. This is what my rotors are looking like after 7 days and ~20k miles of street use. What do you guys think? keep rolling or start looking for replacements?
I'm leaning towards monitoring the larger cracks, but keep going. I have 1/2 of the material left on the PFC08 pads still.
2017 BMW M2 German Spec
01-30-2021, 09:58 AM | #7 | |
381
Rep 731
At a Point above 7,000 RPM.
5.M0NSTER3353.50 |
01-30-2021, 12:50 PM | #8 | |
Rep 427
5.M0NSTER3353.50 |
01-30-2021, 05:23 PM | #9 | |
Rep 582
In terms of cracks, those rotors are completely fine, I would run without issue. I replace my front rotors roughly once every two years and they look way worse than yours.
2017 BMW M2 5Spd, 2007 VW Touareg, 2023 Yamaha MT09 SP
https://www.instagram.com/dvas99/ https://www.youtube.com/channel/UC2j..._as=subscriber |
01-30-2021, 06:17 PM | #10 | |
6637
Rep 4,145
Drives: '18 M2 6MT
02-10-2021, 12:34 PM | #12 |
Rep 1,823
Final update from my side. Had the car serviced by BMW Dealer in Heilbronn. They measured the rotors as 2-3mm thicker than minimum, and told me to keep running on them. Thanks for the suggestions everyone!
03-16-2021, 02:49 PM | #13 | |
Rep 379
Former BMW CCA National Capital Chapter HPDE program Chairman 2021-2022 |
