07-29-2019, 07:18 PM | #1 |
Rep 309
255/275 vs 265/285 Tires?
I'm putting new Brixton RF7 wheels on my 18 M2 and can't decide on size. I can do 255/275 or 265/285. I'm dropped a little on HAS springs. Will 265/285s fit without rubbing or should I be more conservative with 255/275? If the latter, do I still need spacers for flush fit?
07-30-2019, 09:26 AM | #2 |
never could compete with Lloyd Braun
5275
Rep 5,378
You'll need to provide a bit more info on your new set-up.. what size are the wheels? I'm assuming 19s? How wide? Offsets? etc.
2022 G80 M3 6MT | Skyscraper Gray | Kyalami Orange
2018 F87 M2 6MT | Alpine White (sold) 2016 981 Cayman 6MT | Jet Black (sold) 2015 F80 M3 DCT | Tanzanite Blue | Gold Brown (sold) 2013 E92 M3 6MT | Mineral White | Fox Red/Black (sold) |
08-02-2019, 11:31 AM | #3 |
Rep 309
08-02-2019, 04:44 PM | #5 |
Rep 309
08-02-2019, 10:24 PM | #6 | |
756
Rep 2,149
However, I have a set of Sottozero 265/285 winter tires (haven't mounted yet) and they are A LOT wider than the 255/275 5P's. A lot wider than I'd imagine other 265/285 tires would be. With your wheels being 1/2" wider than OEM, I would go with 265/285 because I don't like the stretched tire look. Theoretically, on your wheel, compared to OEM wheel/tire, 255/35 will be 6mm closer to the suspension and stick 4mm further out. 265/35 will be 11 closer to the suspension and stick 9mm further out. |
08-03-2019, 09:18 AM | #7 | |
Rep 309
08-06-2019, 10:55 AM | #8 |
5275
Rep 5,378
I think someone on here is running these wheel sizes (titan7 wheels, not 100% front offset is the same as yours) but with 265/30 and 295/30 PS4S front and rear. That size seems to work with maybe a touch of camber in the front and rear to avoid rubbing.
08-06-2019, 04:16 PM | #10 |
Rep 521
Unfortunately there aren't a ton of tire options at 265/30 295/30. I'm torn right now as I have 9.5/10.5 wheels coming in and can't find RE71s in those sizes. Might just go 255/35 and 285/35
08-06-2019, 04:47 PM | #11 | |
HALA MADRID!
939
Rep 2,879
it's not available on RE71s or Indi500s, but the michelin and conti's are available, and perform perfectly fine.
F87 M2 Competition, Sunset Orange, Exc, DCT. **SOLD** F80 M3 Mineral Grey/Sakir Orange, Exc, DCT... ED 6/2015 **SOLD**E90 M3, Interlagos Blue / M individual two-tone, ZCP, ZP2, ZCV, DCT, ED. |
JTO245274.50 |
08-12-2019, 07:16 AM | #12 |
4693
Rep 2,541
Maybe need a spacer to push the front out a bit? Obviously a different animal - but with Ohlins R&T and a +28 wheel I had to go with a 7mm spacer to clear running 2.8* of camber. Might be ok with a more street friendly camber setting though. I run a 265/35/18 PS4S up front on the street - should be pretty equivalent to a 265/30/19.
JTO245274.50 |
