M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > 265/35/19 does not work on the front of M2C
      08-19-2019, 05:55 AM   #45
mdma-zn
Drives: BMW M2C
without these tyres my car goes like these pics.... sidewards
Not sure why the pics went sidewards
      10-29-2019, 11:49 AM   #46
Old Geezer
Drives: 2019 M2C
Originally Posted by ZM2 View Post
The 265/35 rubs bc it’s a taller tire. Once you wear the tire and fender liner a few mm, it fits without rubbing.
That said a 265 on a 9” rim creates lazy turn in, and the 265 on our cars is meant to be a rear tire and has less channels for rain dispersion.
So, the widest/tallest I’d go on the stock front rims is 255/35/19. A little less lateral grip, but it doesn’t rub, hydroplanes less, and turn in is sharper.
Are you certain it's the liner that's rubbing? I've noticed that the brake ducts on my car extend 1/4-3/8" past the fender liner. Could that be what's actually getting rubbed on?
      10-29-2019, 11:57 AM   #47
Old Geezer
Drives: 2019 M2C
Originally Posted by Expert@ApexRaceParts View Post
Sidewall height is the issue with a 265/35-19. It's 14mm taller than the OEM 245/35-19 tires, which causes it to scrub the fender liner during full-lock turns.
265/30-19 is the way to go up front, which is what we use with our 19x9.5" ET28 wheels. Fits perfectly and plenty of room to spare between the tire and fender
Sadly, Bridgestone doesn't make the RE-71R in a 265/30-19, or I'd be all over it (provided they had a 295/30-19 to go with it).
      10-29-2019, 12:57 PM   #48
ZM2
Drives: 2017 LBB M2
Absolutely could be. I don’t have those on my car.
      02-15-2022, 10:58 PM   #49
Proctor750
Drives: E30 M3
Just for poops would you mind measuring from your hub to where the brake ducts WOULD be on your fender liner? I do so on mine as well and we can compare.
Also a shot of where the liner is rubbing for you.
