08-30-2021, 07:00 PM | #1 |
youtube.com/rodoabadtv
155
Rep 248
Drives: 2017 Dinan M2, 2023 X3MC
18" 18x10.5 BMW 513M Wheels
Hey folks, I was wondering where can I find the full spec sheet for this one. It fits the M2CS so I was wondering if there's any other modification that I need for my 2017 BWM M2 in order for it to fit and not rub—Dinan coilovers.
08-31-2021, 06:39 AM | #2 | |
Rep 4,526
Rears fit wo any mods/adaption and fronts will require ~25mm spacers
Current '22 X3M LCI.. |
09-01-2021, 12:18 AM | #3 |
155
Rep 248
09-01-2021, 02:12 AM | #4 |
Rep 38
So, I actually ordered a set of 513M yesterday
Current setup is 19x9 ET29 (245/35R19) 19x10 ET40 (265/35R19) The spec for 513m 18X9 ET29 (255/40R18) 18x10 ET40 (275/40R18) So the basic wheel widths and offset is the same as the standard 437M for the M2 This is the current clearance for the 437m with Öhlin Road&Track (see attached). The widest part is the lip of the wheel on the current setup, the lip (in my imagination) would sit slightly lower on my new 255/40R18 front wheels. |
09-01-2021, 03:21 AM | #5 | |
Rep 4,526
At the rear, M2CSR runs 16mm wide spacer @ oem part no 36008328081
Current '22 X3M LCI.. Last edited by Bee Pee; 09-01-2021 at 04:49 AM.. |
09-01-2021, 07:15 AM | #6 | ||
Rep 744
The CS racing also has steering rack angle limiters. Probably to prevent rub on full lock. Not great for a street car that might have to do a 3 point turn. Part #32108431886 steering angle stop 30,5mm. Quote:
09-01-2021, 07:52 AM | #7 |
Rep 38
Gotcha, in the topic it was the 18x10 513m mentioned
With the spec of 18x10,5ET46 fitment without serious modifications will be... difficult. Comparing to stock setup you would move the inner part of the rim, circa, 35mm inwards? To OP, are you looking to run a staggered or square setup? Last edited by DonPedron; 09-01-2021 at 08:02 AM.. Reason: A number |
09-01-2021, 10:37 AM | #8 | |
Rep 744
10" 513M will fit the front with the right spacers and enough camber. Can't seem to find the spacer size but it was in the 20-30mm range.
DonPedron56.50 |
09-02-2021, 03:13 AM | #9 |
Rep 4,526
10" et40mm - min spacer 15mm to clear standard front strut with 245 wide rubber. If running coilovers/wider rubber then as above suggest min. 20mm thk spacer to ensure inner clearance.
Megator517.50 |
09-03-2021, 08:59 PM | #10 |
155
Rep 248
Additional information, if I couldn't run 18x10.5 without any major modifications then I will fall back to 18x10 which is IIRC the normal ones that fit F87?
09-05-2021, 11:49 AM | #11 |
Rep 38
To my understanding it's possible to fit the rear 437M wheels (19x10, ET40) with spacers and more camber.
With that said, are you doing this in order to run a square setup? Because the 513m equipped to M3/M4 is staggered and will fit just fine. |
09-05-2021, 09:31 PM | #12 |
155
Rep 248
I’m looking to run a square setup if possible. To be honest I’m still not sure if that’s actually economically sound given that at the track, I’m not really “saving” when it comes to the rotation part of the tires.
I know the 513m that comes with M3/M4’s fit just fine. So I may just go this route. Maybe I’m just (at the end of the day) looking for a meatier setup. |
09-06-2021, 03:07 AM | #13 | |
Rep 744
Square setups are only really worth it if you rotate tires. You can also go to 9.5s all around to make fitment up front easier. I personally ran a set of 513M for track with the above tire widths (stock suspension). Now I run some Apex wheels 9.5 Fr 10.5 Rr.
09-11-2021, 11:54 AM | #14 |
155
Rep 248
Thanks for all your feedback. I think I'll be going with the OEM 513m setup then just powder coating them like the M2CS racing wheels.
09-11-2021, 12:49 PM | #15 | |
Rep 2,680
Depending on your experience and driving skill my guess is that 9.5f and 10.5r is better on m2. |
gphung193.50 |
